Welcome to the North American Subaru Impreza Owners Club Friday December 19, 2014
Old 06-20-2009, 11:35 PM   #1
THE_DON
Member#: 213543
2006 impreza wgn
red
Post Tire Rubbing
i was planning on getting the ROTA SVN's 18x8.5, i havent done anything to the suspension or havent rolled the finder yet, everything is still stock i was wondering if it would rub
THE_DON is offline   Reply With Quote
Old 06-20-2009, 11:44 PM   #2
car_cursed
Member#: 85327
More projects than
you can shake a stick at.
depends on the tire size, a 235/40 should be okay, much wider you will need camber or fenders rolled
car_cursed is offline   Reply With Quote
Old 06-21-2009, 06:39 PM   #3
steve
Member#: 4718
~ too
many to list
It would help if you told us what car you have.
On a GD chassis, set up by a knowledgable alignment shop, you can run an 18x8.5" with a higher offset without any issues outside of a mild rub on the inner fender.
I had no issues outside of the little inner rub when running 18x8.5, +48, although they fit better when I ran a small spacer to create an effective +45. This was with 245/40/18 RT615 tires.
Any number lower than a +35, and you have some work to do.
steve is offline   Reply With Quote
Old 06-21-2009, 09:40 PM   #4
THE_DON
Member#: 213543
2006 impreza wgn
red
its a 2006 impreza wagon 2.5i
Old 06-22-2009, 04:26 PM   #5
Wagon2.?
Member#: 174397
Default I have an 04 with those wheels
I have an 04 wagon with stock springs and struts but with strut tower braces and 22mm sways on hard. I have Rota SVN 18X8.5 with a +45 offset I believe. I have 235/40/18's Potenza RE050's. They are a little big on the inside it barely fits and I mean it rubs a little when I say that...not too bad, just on the rim guard rubber on the tire hits the strut. Also you will have to roll your fenders if you actually intend on turning hard at all especially with people in the car. I didn't roll mine far enough back and it still hits a little. I am about to fix that and try to get some stiffer springs and struts and lower it like 1". We'll see how that goes though. If you want pics let me know and I wil throw them up.
I think 225/40/18's would fit no problem.
Wagon2.? is offline   Reply With Quote
Old 06-26-2009, 01:42 PM   #6
THE_DON
Member#: 213543
2006 impreza wgn
red
yeah throw me some pic i would like to see
Tire rubbing, Cobb springs, 245 width tires, please help Jay04WRX Tire & Wheel 8 04-12-2010 01:42 PM
Tire rub. Best tire size? ^jynx^ Tire & Wheel 3 03-01-2004 10:20 PM
Will these tires rub? Will those tires rub?? Let's get it STRAIGHT!! GooseMan Brakes, Steering & Suspension 11 10-23-2001 10:28 PM
Ok, tire rub=not good SCRAPPYDO Southern California Impreza Club Forum -- SCIC 1 07-11-2000 01:53 AM
Will 225/45-17 tires rub Petrie Vancouver Impreza Club Forum -- VIC 0 04-18-2000 09:26 AM
