Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 06-20-2009, 11:37 PM   #1
jfries89
Member#: 213364
2005 Baja Turbo
Default dead turbo (i believe)
I was driving to Daytona today to pick up a car with some friends when i feel like a kind of pop and then my 05 turbo a/t started losing power. then i start hearing a steady ticking when I'm pressing the gas and when i let off it goes away. I'm pretty sure the bearing went out. But just to be on they safe side, what else could it be? And if it is the turbo, what does it take to put in an STi turbo?
jfries89 is offline   Reply With Quote
Old 06-21-2009, 07:28 AM   #2
kingofl337
Member#: 200340
2005 Baja Turbo
Dark Blue
When a turbo goes bad usually it stars making a harsh fluttering sound of metal on metal.. What you describe sounds more like you blew a hose.
kingofl337 is offline   Reply With Quote
Old 06-21-2009, 08:30 PM   #3
jfries89
Member#: 213364
2005 Baja Turbo
Definitely a bad bearing. Uber-ridiculous amounts of free play. So tell me more about swapping in an STi turbo. Which turbos can I use? Ive heard that i need the STi ecu and inter cooler as well. Anything else I need to get?
Old 06-21-2009, 09:48 PM   #4
Hawk296
Member#: 14555
1995 Impreza L
Baja
You can use the stock intercooler with the STi turbo, its a pain to stretch the IC hose (y-pipe) to try and get it to work (its not a perfect fit) Or you can rig another y-pipe setup.
you can have your ECU re-flashed to work with the VF-39.
Or you can use a wrx turbo (earlier model years before the LGT style intake manifold).
Hawk296 is offline   Reply With Quote
Old 06-21-2009, 10:12 PM   #5
jfries89
Member#: 213364
2005 Baja Turbo
whats involved in getting a re-flash? im not looking to make a crazy fast car. just would like some more power. what r some cost estimates of a re-flash?
FS: NoVA: Draco Performance Turbo Blanket for Small Frame Turbo. adjasont Engine/Power/Exhaust 4 06-05-2010 03:15 PM
Oil and Coolant Mixing: Dead HG or Dead Turbo? williaty Service & Maintenance 9 11-16-2009 10:03 PM
Dead turbo TheMadScientist Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 01-05-2009 02:51 AM
Oil consumption - dead turbo? jmlmr2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 09-20-2007 05:55 PM
Dead Turbo? xthemotherloadx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-19-2006 12:25 AM
