Old 06-21-2009, 12:42 AM   #1
Aleksey
Member#: 23445
2007 STI
Default Misfire cyl#4 ONLY on cold engine
Not just another "I got misfire, what do I do" thread, so read on
Yeah, I got cyl #4 misfire and I'm gonna do the coil swap, sparkplug swap, check grounding etc, but before I start messing with it I just wanted to see if anyone had it the same way I do:
I get P0304 about once a week regardles of the ambient temperature or milage driven. I get it within a minute or two after I start the car so the engine is relatively cold. It doesn't matter if I leave the car idling, if I rev the engine a few times or if I just drive away without letting it idle for a bit - if the code pops up, it pops up no matter what I do. But as I said, the code pops up about once a week, give or take a day or two.
Due to this special behaviour I thought I'd see if anybody had some extra thought on this issue. Thanks in advance.
P.S. The car is a daily driver and almost stock - APv2 Stage 2 and COBB downpipe are the only mods.
Aleksey is offline   Reply With Quote
Old 06-21-2009, 10:02 AM   #2
b0nd18t
Member#: 155876
2007 STI
Blouch Dom3
i wouldnt consider a downpipe and stage 2 reflash to be almost stock first of all. But your on the right path by changing out spark plugs and coil, maybe run some injector cleaner as well. Do a compression check since you're already removing the spark plug. Seems like the standard procedure for a misfire, ill be doing it this week as well
b0nd18t is offline   Reply With Quote
Old 06-21-2009, 11:08 AM   #3
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
^ compression check.
robbieshonda is offline   Reply With Quote
Old 06-21-2009, 01:34 PM   #4
flycaster
Member#: 60142
2011 WRX
Grey
Frankly, before I did anything else I'd swap injectors first and see if the CEL moves. So many of these odd misfires are injector related, that should be at the very top of the checklist. Just my $0.02.
flycaster is offline   Reply With Quote
Old 06-21-2009, 02:18 PM   #5
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
Maybe a sticking valve ? Too tight of valve clearance
sense of nature is offline   Reply With Quote
Old 06-21-2009, 02:29 PM   #6
Aleksey
Member#: 23445
2007 STI
yeah, after searching NASIOC on this issue and added this to the check list too.
Old 06-21-2009, 02:30 PM   #7
Aleksey
Member#: 23445
2007 STI
Just wondering, is there a software I could use to automatically snapshot all the OBDII data when a code pops up? I don't think ECUExplorer has this feature, does it? I'll also ask in the proper forum, but just throwing in the idea - after searching around I don't think anyone mentioned this as another way to narrow down the problem cause.
Old 06-21-2009, 04:50 PM   #8
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
The ROM Raider logger is pretty good. If you have an access port, you could use the AccessTuner RACE logger too. The engine roughness monitor value is available in both. I run a twin disk clutch and ended up needing to adjust the misfire detection sensitivity in the ECU to get my CEL to go away.
While our issues are surely different, you should read this thread and try the same things that I tried in an attempt to solve your issue.
http://www.iwsti.com/forums/2-5-lite...-misfires.html
dexterous is offline   Reply With Quote
Old 06-22-2009, 02:32 PM   #9
SimonJ
Member#: 135309
Start with the basics
1) Swap coils
2) Swap plugs
3) Swap injectors
Then, and only then should you start with the more complicated diagnosis.
SimonJ is offline   Reply With Quote
Old 06-22-2009, 06:42 PM   #10
Merp
Member#: 199106
PMme 4 Speed Density
Patches on OEM ECU
1) Swap coils
2) Swap plugs
3) Swap injectors
While you're swapping the plugs, do a compression test.
Merp is offline   Reply With Quote
Old 06-23-2009, 01:54 AM   #11
Aleksey
Member#: 23445
2007 STI
Thanks everybody for your replies. I'll update once I have results.
Old 06-23-2009, 02:00 AM   #12
Aleksey
Member#: 23445
2007 STI
That was interesting thread to read, glad you sorted this out. I haven't played with ROM Raider before, will download and check it out too. Thanks!
Loud clacking noise on cold engine startup with video deepsouthwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 04-10-2009 08:36 PM
Misfire on hybrid engine Splinter Built Motor Discussion 0 08-11-2008 01:27 AM
Flat spot on cold engine jemyers 'Old School' Subaru Forum 6 01-18-2008 07:02 PM
Accessory noise, metallic "chirp" when blipping the throttle on cold engine? Davemeister Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 06-09-2006 03:06 AM
Initial hesitation on cold engine acceleration MaddMax Legacy Forum 4 09-14-2003 10:32 PM
