Vancouver Impreza Club
Old 06-21-2009, 08:34 PM   #1
Impwrxza
Member#: 164395
2004 2.5 RS
Purple-ish
Default Code P0302 misfire #2
Hi guys,
I have just ran into a problem with the cel code P0302, apparently it has to do with a misfire. The check engine light comes on and then the car would make sparking/popping sounds during acceleration, sometimes resembling something exploding..
It would drive "normal" but with the engine light on. Any idea how myself or any shops will be able to fix this? or Will I have to visit the dealer?
Thanks.
Impwrxza is offline   Reply With Quote
Old 06-21-2009, 08:41 PM   #2
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Check spark plugs/change them.
Check spark plug wires.
Check coil packs.
Swap coil packs between #2 and #4. See if the code goes to cylinder 4. If it does most likely the coil pack.
Could be injector problem as well.
alcoolaid is offline   Reply With Quote
Old 06-21-2009, 08:51 PM   #3
Impwrxza
Member#: 164395
2004 2.5 RS
Purple-ish
i can't seem to find a how to thread to this, is this going to require some good mechanical knowledge?
Old 06-21-2009, 08:59 PM   #4
alcoolaid
Member#: 134949
'07 SWP STi
If you aren't too mechanically inclined I'd probably take it to a subaru tech. That doesn't mean you have to take it to the dealer though.
PM 5 Zigen??
Old 06-21-2009, 09:04 PM   #5
Impwrxza
Member#: 164395
2004 2.5 RS
Purple-ish
ok thanks, i'll send him a pm.
How to fix CEL code P0302? tonecold Newbies & FAQs 34 10-21-2010 09:44 AM
#2 Misfire CEL Code P0302 SkunkBug02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 09-15-2009 12:47 PM
HELP! P0302 Misfire Detected in Cylinder #2 awd-box-turbo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 09-03-2008 02:05 PM
cel code p0302 eggpattern Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-13-2006 08:49 AM
Check Engine Code P0302, "#2 Misfire" hillman Legacy Forum 5 06-26-2001 03:14 PM
