Old 06-21-2009, 08:47 PM   #1
06WhiteWRX
Member#: 108194
2006 wrx
51E
Default fitment issue... need help.
hey guys,
so im lowered on tien flex coilovers and have the 18x9 rota g forces. before i had 225/40 tires on these wheels and they were way too stretched. now i bought these tires that i thought would fit (245/40)but now are giving me lots of rubbing issues. i should have gotten 245/35 because of how low i am but if i can make these tires fit without selling them it would be awesome.
now they dont make rear camber plates for my coilovers and my shop (andrewtech) doesn't want me to go any more than -2 degrees rear camber.
i know ill be sacrificing some handling but i don't auto x my car i daily it. what are my options? i have the rears rolled... do i have to pull them too?
thanks in advance for any input.
06WhiteWRX is offline   Reply With Quote
Old 06-21-2009, 08:50 PM   #2
mosc
Member#: 177401
2015 STi White
The easiest tire size fittment wise for 18x9" rims is 235/35/18
mosc is offline   Reply With Quote
Old 06-21-2009, 08:53 PM   #3
06WhiteWRX
Member#: 108194
2006 wrx
51E
yeah should i just sell the tires?
Old 06-22-2009, 09:53 AM   #4
mosc
Member#: 177401
2015 STi White
245/40/18 is stock 08-09 STi size. Shouldn't be too hard to sell em
Old 06-22-2009, 09:56 AM   #5
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
So much fail in this thread. First, you bought wheels that don't fit. Then you bought tires that don't fit the wheels. Then you bought tires that fit better on the wheels, but don't fit the car. Now you have someone telling you to run 235/35-18 tires.
A proper size tire for that rim, on your car, would be 255/35-18, but that will never fit without a lot of fender work. I'll at least ask this, are your fenders rolled? If not, that's the first thing you need to do.
Old 06-22-2009, 11:14 AM   #6
davidsti1
Member#: 210923
2001 RSTI Twinscroll
FullRace BW8374 ripper
+1 ^^^ ppl post and post. they will make spend more money then you allready did.
imo and from what i learnd here you need fender rolling and or pulling and 255/35/18
will do it
im about to do it myself..
davidsti1 is offline   Reply With Quote
Old 06-22-2009, 11:53 AM   #7
mosc
Member#: 177401
2015 STi White
Not that he's posted an offset but I doubt 255/35/18 is what he's looking for. He has massive rims and likely an offset 10-20mm from stock. He obviously is looking for something that doesn't require massive fender work. 235/35/18 maximum rim size is 18x9" which he has. Hence the OBVIOUS recommendation. The tire is 2.8% wider than the rim so it won't be like he had before with the 225/40/18 (although this tire is spec'd to handle 18x9" rims in most cases) tire on there which is actually narrower than the rim. 255/35/18 may look more... filled out... but it is hardly the only tire size that works on an 18x9" rim. The rim is good for 235/35/18 to 265/30/18 or maybe even 275/30/18 if you wanted to push it.
Are the rims a good choice for his car and situation? HELL NO. I didn't recommend the rims though, I just recommended the narrowest tire he can get away with.
Old 06-28-2009, 09:34 PM   #8
06WhiteWRX
Member#: 108194
2006 wrx
51E
my front fenders are barely rolled but my rears are rolled flat. i'd rather not pull my fenders.
im wondering if more camber in the rear is what i need i think its -1.5.
i already am stuck with these tires and theyre not selling. so if i can make it work i will. right now the cheapest alternative is what im considering. but if you guys are telling me that the tires will never work and its better and safer to spend the money and get the right size then ill consider that too.
for the meantime im borrowing my friends 18x7.5 works.
Old 06-28-2009, 11:58 PM   #9
mosc
Member#: 177401
2015 STi White
next time buy rims with a near stock offset?
Old 06-29-2009, 10:44 AM   #10
Tire Rack Moderator
Member#: 1215
ext. 4362
what offset are the wheels? and yes you need to change tire size as those are too tall
Old 06-29-2009, 12:43 PM   #11
ommmjido
Member#: 35746
08 White GRB
Wrong Fitment Crew #001
No one uses a 235/35/18 tires, nor anyone makes a 265/30/18 or 275/30/18 tire. Like Luke have said 245/40/18 is too tall. If u don't want to chAnge tires then u'll have to raise ur car or pull ur fenders. But I'd suggest going to 235/40/18 and make minor adjustments to make them fit.
ommmjido is offline   Reply With Quote
Old 06-29-2009, 01:12 PM   #12
06WhiteWRX
Member#: 108194
2006 wrx
51E
what minor adjustments would i have to make to fit the 235/40s?
i dont wanna raise my car up. u talking about pulling the rear?
Old 06-29-2009, 01:19 PM   #13
mosc
Member#: 177401
2015 STi White
You can get KDW2's in 235/35/18...
Old 06-29-2009, 02:11 PM   #14
ommmjido
Member#: 35746
08 White GRB
Going from 225/40/18 to 235/40/18 isn't that big of a change, so if u run -2 rear camber u'll probably only need a slight pull or might not even need it depends how low u are. 245/40/18 is just too tall in general forthe 5speed and it would take quite a bit more pullng to make them fit. So I would highly recommend u switch to 235/40/18.
Old 06-29-2009, 02:23 PM   #15
06WhiteWRX
Member#: 108194
2006 wrx
51E
thats what im thinking. but im still afraid of rubbing. i dont wanna pull the rears tho.
maybe ill just do 235/35 to be safe.
Old 06-29-2009, 02:34 PM   #16
ommmjido
Member#: 35746
08 White GRB
Well u gotta pay to play, u can't expect to be slammed with aggressive wheels while not runnng camber, pullng ur fenders and not stretching ur tires at the same time.
Blouch 20g/aps inlet fitment issue..please help 1 Stock Rex Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 24 04-13-2009 08:50 PM
OT Computer Gurus: Sound Card Issues, Need Help huckedup16 Off-Topic 6 01-03-2004 01:32 AM
Electrical Issues Need Help! mRgUnN Electrical & Lighting 8 05-20-2003 04:31 AM
URGENT: Electrical Issues Need Help mRgUnN South East Region Forum 5 05-19-2003 01:56 PM
Boost Issues, Need Help kdawg Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 12-08-2002 03:25 PM
