Welcome to the North American Subaru Impreza Owners Club Saturday August 2, 2014
Old 04-26-2002, 06:47 PM   #1
gypsymoth
Member#: 6072
01 Silver 2.5 RS
04 Silver WRX STi
Default mild steel vs. stainless steel
What are you thoughts on equipment made from mild steel vs. equipment made from stainless steel?
Chieh
Chieh's Web - http://Chieh.CameraHacker.com/
gypsymoth is offline   Reply With Quote
Old 04-26-2002, 08:31 PM   #2
RawCode
Member#: 3115
2002 Impreza 2.5RS
Mild steel unless treated in some way (i.e. Ceramic coating, High temp paint) will rust rather quickly, but it is cheap and easy to make sharp bends with.
Stainless looks real nice, takes forever to rust, but is spendy and is generally more brittle so it is hard to make sharp bends...
RawCode
RawCode is offline   Reply With Quote
Old 04-27-2002, 05:53 AM   #3
obyone
Member#: 16523
JDM Maxxpro
RawCode
Any performance/HP difference between the two? Weight difference?
obyone is offline   Reply With Quote
Old 04-27-2002, 09:55 AM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Stainless steel parts make way more horsepower because they are prettier.
Old 04-27-2002, 06:30 PM   #5
obyone
Member#: 16523
JDM Maxxpro
So that means that I can add some blue lights to my stock exhaust, and put a mini wing on the muffler tip to give me some more power? .......Or maybe I should add another hamster under the hood?
Old 04-27-2002, 08:26 PM   #6
RawCode
Member#: 3115
2002 Impreza 2.5RS
The only think is that SS will last longer if mild steel is not coated. SS also looks nicer.
The only thing that really affects performance is the type of bends, inner diameter, and coatings to retain heat.
RawCode
Old 04-28-2002, 12:19 AM   #7
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
Another factor to consider is also the gauge of piping used, as it will affect the time it takes for the rust to go through it (un-treated mild steel). Generally T304SS systems will probably outlast your car's lifetime (given the proper gauge pipe) and same type of use on both.
Some grades of stainless retain more heat than non-treated mild-steel.
GTBGUY is offline   Reply With Quote
Stainless Steel or Mild Steel? BoozeRS05 Normally Aspirated Powertrain 5 03-01-2007 02:37 PM
Mild Steel vs. Stainless Steel Honkey3k General Community 6 05-15-2004 05:15 PM
titanium vs stainless steel catback tino Factory 2.0L Turbo Powertrain 11 04-06-2004 10:13 AM
OEM brakelines vs. aftermarket Stainless Steel turboICE Brakes, Steering & Suspension 3 01-25-2004 01:09 PM
The properties of 321 stainless steel vs 304 as seen in exhausts fengshui-fu Factory 2.0L Turbo Powertrain 14 01-11-2003 07:38 PM
