Old 06-22-2009, 03:26 PM   #1
somaguchi
Member#: 202740
2016 Wrx
Ice Silver Metallic
Default Sdrive or Htr z3
I'm looking at getting either Sdrives or the Htrz 3. Which one would be the better pick? There's only a couple of dollar difference between the two.Thanks.
somaguchi is offline   Reply With Quote
Old 06-22-2009, 04:00 PM   #2
mosc
Member#: 177401
2015 STi White
What about the General UHPs?
mosc is offline   Reply With Quote
Old 06-22-2009, 04:22 PM   #3
somaguchi
Member#: 202740
2016 Wrx
Ice Silver Metallic
haven't looked into them. worth it?
Old 06-22-2009, 06:51 PM   #4
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
They are NOT in the same league as the HTRZ3.
Best avoided unless you like sidewalls that roll over and play dead...
OP: go with the Sumitomo.
Spenk is offline   Reply With Quote
Old 06-22-2009, 07:12 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Old 06-23-2009, 04:49 PM   #6
dkmesa300zx
Member#: 105301
Interested in the same question. Anyone running S Drives or HTR ZIII?
dkmesa300zx is offline   Reply With Quote
Old 06-23-2009, 05:33 PM   #7
chanmanWRX
Member#: 100221
2007 WRX LTD
i got the htrzIII in 245/40/17. good bang for the buccckkk
chanmanWRX is offline   Reply With Quote
Old 06-23-2009, 07:02 PM   #8
DeathPool
Member#: 186966
2004 WRX Sedan Stg.2
I just finished breaking in my HTRZIII's in 235/40/18. I usually go for the "cheap" performance tires and these are the best tire I have ever ran. My only gripe is that I can feel the sidewalls flexing on very sharp turns, but they stick amazingly regardless.
Also, I believe these run wide. My 235's look like 255's.
Tires I have ran in the past were Falken Ziex512 and Ziex912.
DeathPool is offline   Reply With Quote
Old 06-23-2009, 08:07 PM   #9
DivineStrike
Member#: 162037
2007 VW GTI Black
2007 CBR600rr White
HTRZIII's imo are best bang for the buck. they perform pretty close to the old Kumho MX's (which they're rating is 220 while the sumitomo have a tread rating of 300, so you get some life and grip) but better in the wet. I'll probably buy the HTRIII's again for my dd wheels. I only need two at the moment and thats all I'm going to buy because I'm might be changing climates in the foreseeable future.
@ the above post... I think the sidewalls are pretty stiff at least on my 225/40/18's. My right rear tire has a leak and its gotten below 10psi and you can barely tell its low. just bump up the pressure ~_^
DivineStrike is offline   Reply With Quote
Old 06-23-2009, 08:35 PM   #10
lionken07
Member#: 13660
16 BRZ Limited 6MT
04 WRX 5MT
I have the S drive in 225/45/17 and they are awesome. What kind of driving will you be doing mostly? I use the car for DD, so it needs to handle good in the dry as well as the wet. About 5,000 on mine now and they as still as good as new.
lionken07 is offline   Reply With Quote
Old 06-23-2009, 10:15 PM   #11
DivineStrike
Member#: 162037
2007 VW GTI Black
2007 CBR600rr White
My DD tire debate is between keeping the HTR's or going with the kumho SPT's since I was looking on tire rack and they both tested really close with the HTR's with a slight upper hand.
Old 06-24-2009, 06:51 AM   #12
Spenk
Member#: 7164
2000 Miata LS
If the HTRZ3 were available in 235/40-17, that's what I'd be running right now...
Old 06-24-2009, 08:43 AM   #13
Tire Rack Moderator
Member#: 1215
ext. 4362
another vote foth e HTR ZIII
Old 06-25-2009, 09:56 AM   #14
Yoo Shin
Member#: 87327
2010 12 parsec Evo X
I still kill threads
And another vote for the HTR ZIII. They do run wide. I have 225s on a 7" wide wheel (yes I know too narrow) and they're wider then I expected. They would fit great on a 8" wide wheel.
They have a 300 rating, yet I'm coming close to burning thru my first set at about 15k miles. Still for the price that's not bad especially for the way I drive.
Also, another aspect that is often left un mentioned, is that they're fantastic in the wet and heavy rain.
Yoo Shin is offline   Reply With Quote
HTR Z3 vs Hankook Ventus V12 Evo somaguchi Tire & Wheel 7 06-16-2009 06:55 PM
how wide can 225 htr z3 stretch to? jacky599r Tire & Wheel 11 05-10-2009 04:01 AM
Anyone driven a BMW Z3 coupe or M Coupe? FunkerVogt Off-Topic 31 08-18-2005 02:11 AM
HTR+ or ASX or Ziex 512? impreya Tire & Wheel 2 10-18-2004 10:28 AM
