Welcome to the North American Subaru Impreza Owners Club Tuesday March 3, 2015
Old 06-23-2009, 12:25 AM   #1
recharged95
Member#: 12037
Default Are these defective tires
had an alignment about 7-8mos ago. Also had a 4 tire rotation/rebalance. Sometime since then, the rear tires have developed a cracking condition on the outside shoulders at spots around the full shoulder:
Is this a sign of a defective tire(s)?
I also noticed the inside tread of both rears are wearing faster (not bald, but definitely faster). Went to the place of purchase (Costco) and the manager said since the tires are 3 yrs old, no warranty applies and I need to buy new tires at the full price--not considering I actually need 4 tires to keep the AWD happy and that the tires have about 15K left in them (>1/4" tread). He also said the cracking is from the alignment (??). I believe the wear problem is from the alignment, but the cracking sounds like a defective product? I've had Contisport contacts bald on one side (excessive chamber) and the tires never cracked like this. I'm wondering how safe this is after fixing the alignment or should I just get 4 new tires?
recharged95 is offline   Reply With Quote
Old 06-23-2009, 01:30 AM   #2
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
d0000000000000000000d...ya need more negative camber...ya cornering on the side of the tread
and ya need the toe set to '0'
yer alignment is ****...real ****
Old 06-23-2009, 12:59 PM   #3
recharged95
Member#: 12037
thanks, i think the alignment shop f-ed the alignment, likely didn't tighten bolts somewhere...
Old 06-23-2009, 01:36 PM   #4
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
I don't see anything wrong with the tires pictured
Old 06-23-2009, 02:14 PM   #5
ommmjido
Member#: 35746
08 White GRB
Wrong Fitment Crew #001
d000000000000000d, if Scotty saids there's sth wrong, there's gotta be sth wrong. coz he's just koo like that!
ommmjido is offline   Reply With Quote
Old 06-24-2009, 01:03 AM   #6
recharged95
Member#: 12037
the belts are cracking @ the shoulders. This is happening to both rear tires. Front tires are fine.
In the 1st pic, center, the there's a 'popped bubble' and it appears the belt or something is almost exposed. I'll try to get a clearer pic. The 2nd pic, there along 1/2 the shoulders. It has a look like nails are coming out of the tire if that helps.
Scotty, with the insides wearing, isn't that excessive negative camber: the insides appear wearing faster and the outside shoulders are cracking and it's cracking to a point I can pull rubber chunks off...
Old 06-24-2009, 11:58 AM   #7
leftbraned
Member#: 173364
2003 wrx
Buy some new tires. Even if you have a defective condition most manufacturers won't warranty tires with uneven wear ie: camber wear.
And stop buying tires at the grocery store.
leftbraned is offline   Reply With Quote
Old 06-24-2009, 10:05 PM   #8
trueno16v
Member#: 175170
2005 WRX Wagon
owl + bungee cord= my a$$
clean up aisle two, someone spilled milk
trueno16v is offline   Reply With Quote
Old 06-24-2009, 10:34 PM   #9
krzyss
Member#: 8365
2013 Ford Focus SE
What is wrong with costco?
Where did you do your alignment? You may choose some other place.
Krzys
krzyss is offline   Reply With Quote
Old 06-24-2009, 11:31 PM   #10
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
NO-NO-NO!!!
toe-toe-toe!!!!!!
and those pictures suck and maybe it is too hard to REALLY tell what is up
but it looked TO ME....like there was NO negative camber and the tire was being cornered on the sidewall
if the pic was better---it would be easier...but that looks like(way) insufficient negative camber
Old 06-25-2009, 12:30 AM   #11
recharged95
Member#: 12037
You're right Uncle Scotty...
I just realized that when the wifey originally took the car in for rotation a year ago a front wheel shimmy started afterward. Then we took it in for a rebalance 4mos ago and the Costco guys said they "reversed" the tires (took off rim and mounted inside-out) to "fix" the shimmy. It did and the car ran pretty smooth since.
So even though I see the cracks on the "outside", they were really on the "inside" for the last 2.5+ years. And since they're balding on the inner trends now suggests someone either mucked with the alignment@Costco or we got screwed by the alignment shop from the start. CRAP.
Thanks for the analysis & advice guys...And yes, it's back to Kuhmos, and Tire Rack, and a better shop....
Here's some more pics for your enjoyment (both rear tire, outer trend--NOTE the inner trends are balding quickly):
Are these good tires for snow/all season? roloc31 Tire & Wheel 11 04-08-2008 10:19 PM
Are these Goodridge lines defective? FromageTheDog Brakes, Steering & Suspension 7 09-21-2006 10:38 PM
Are these good tires? DaveDaBurner Brakes, Steering & Suspension 8 07-16-2002 04:27 PM
Are these tires any good? RedlineRex Brakes, Steering & Suspension 2 01-03-2002 06:45 PM
are these ok tires? the spacecowboy Brakes, Steering & Suspension 32 12-16-2000 02:02 AM
