Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 06-23-2009, 11:58 AM   #1
Jrags87
Member#: 119324
2005 Impreza WRX STI
Crystal Grey Metallic
Default Low boost /w warmer weather
Quick question .. past few days its been about 75 - 85 degrees out
max boost in 4th will hit anywhere from 16 - 17 psi according to accessport
its tuned for cobb stage 2 @ 17.5
i've already tried an ecu reset
does weather really have that much effect on max boost? or could there be other issues like leaks.
thanks
Jrags87 is offline   Reply With Quote
Old 06-23-2009, 12:06 PM   #2
sarcasmo
Member#: 50301
2004 BMW
330i
Are you using the AP as your engine management? I'm not really sure how flexible it is on the boost maps (i.e. does it pull boost when it's hot and humid to help save the engine), but my 03 tapered back boost on really hot days when it was in stock form. I guess what I'm saying is that your results don't seem odd to me.
sarcasmo is offline   Reply With Quote
Old 06-23-2009, 12:07 PM   #3
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
seems normal, i boost slightly higher when it is cold out
06HAWKMAN is offline   Reply With Quote
Old 06-23-2009, 12:07 PM   #4
lionken07
Member#: 13660
16 BRZ Limited 6MT
04 WRX 5MT
That's pretty much how it is for most of us.
lionken07 is offline   Reply With Quote
Old 06-23-2009, 12:08 PM   #5
bcware
Member#: 190724
2008 2.5i Sedan
Lightning Red
Is the loss consistent, or is it only happening during warm weather?
Hoses and tubes can become much more flexible during high heat and could possibly form a leak.
The access port is using an off the shelf map, correct? You individual mods could result in a pressure drop.
bcware is offline   Reply With Quote
Old 06-23-2009, 12:12 PM   #6
Jrags87
Member#: 119324
when it was colder i would boost on target .. maybe slightly higher
i guess my question should be does the ecu pull boost because of higher temp
btw mods are pretty standard stuff .. cobb downpipe .. catback exhaust .. stock airbox
Old 06-23-2009, 01:39 PM   #7
Ysidro
Member#: 197418
07 WRX Ltd
The Mighty Evo;Fun CRZ
I would guess it would pull the timing and boost for safety reasons.
My car would not hit its target boost, and respond kind of slugglish when hot so does my last car, the evo. But as the tempt changes, it makes adjustments by itself.
On a hot day,on a long trip, I always pull over at a rest stop for some coffee to let my car cool alittle bit.
Ysidro is offline   Reply With Quote
Old 06-23-2009, 02:03 PM   #8
corms333
Member#: 210149
03 wrx sedan
blue
It wont hit as high as boost when its hotter compared to colder air. Cold air is more dense than warm air.So not as much air is going in a short explanation.
corms333 is offline   Reply With Quote
Old 06-23-2009, 02:10 PM   #9
Badler
Member#: 133597
This. It doesn't pull boost. Normal.
Badler is offline   Reply With Quote
Old 06-23-2009, 02:44 PM   #10
ryan2.5
Member#: 167205
2004 N.F.D
04 STi. FP Red + Meth
very normal
ryan2.5 is offline   Reply With Quote
Old 06-23-2009, 03:00 PM   #11
william_c
Member#: 214984
2008 Impreza 2.5i
Gas expands with heat, which should increase pressure. Is the ECU pulling back boost to combat expansion from heat?
william_c is offline   Reply With Quote
Old 06-23-2009, 04:27 PM   #12
Badler
Member#: 133597
No. Read above.
Old 06-23-2009, 05:26 PM   #13
corms333
Member#: 210149
03 wrx sedan
blue
Has nothing to do with the gas expansion. It has to do with the air temp as well as altitude. Both affect how dense the air is. If you live at see level and drive to a mountain with a much higher altitude. It would be PROBABLY be about the same as what your seeing now.
Hot temps = less air
Cold temps = more air
Old 06-23-2009, 05:42 PM   #14
Deserted1
Member#: 110902
2010 Toyota Tacoma
Super White
you guys do realize there are correctional values in your maps based on intake temps right? Ie wastegate Correctional value (IAT) when reading 212 correct WG by 32% and such.... the ECU knows when its getting hot and how to correct to save you.
Deserted1 is offline   Reply With Quote
Old 06-23-2009, 05:45 PM   #15
corms333
Member#: 210149
03 wrx sedan
blue
^^To save your car from blowing up? Not correct your map so it hits the max boost your map is set too.
Old 06-23-2009, 05:49 PM   #16
02wrxRally
Member#: 205994
'02 Bawkeye WRX
'04 tOtaledBS | '68 MGBGT
And isn't this the whole reason we have intercoolers? To cool down air for better density/more power. My car always feels peppier in the winter vs summer. Hot days are nature's heat soak.
02wrxRally is offline   Reply With Quote
Old 06-23-2009, 05:52 PM   #17
corms333
Member#: 210149
03 wrx sedan
blue
^^ yeah but its alot easier to get that cold air cold than it is summer air to the same density of a cold day.
Old 06-23-2009, 05:56 PM   #18
02wrxRally
Member#: 205994
'02 Bawkeye WRX
well obviously. It's getting up to about 100deg today here - not saying any intercooler will make it like a -20 day in february
Old 06-23-2009, 05:58 PM   #19
corms333
Member#: 210149
03 wrx sedan
blue
Exactly intercoolers can only do so much man.
Old 06-23-2009, 10:06 PM   #20
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Uhh, no. That's not how boost works. Please make sure you know what you're talking about before giving advice
Audiosavvy is offline   Reply With Quote
Old 06-24-2009, 07:27 AM   #21
mostasz
Member#: 170512
2012 WRX
Ice Silver
Nothing unusual here...
mostasz is offline   Reply With Quote
Old 06-24-2009, 10:38 AM   #22
phlegmon
Member#: 26223
2016 Focus RS
1992 NSX twin turbo
^^^ THIS. There are quite a few tables in the ECU that account for both air temperature (IAT) as well as altitude (and other factors). Your ECU will use these tables to adjust timing, fueling, and WGDC (amongst other parameters) based on air temp, coolant temp, altitude, knock, etc. etc. If you use ECUflash/romraider, you can see exactly what these tables do and adjust them, as necessary.
Ignore the majority of everything else posted in this thread. Gotta' love nasioc and all of the internet experts
phlegmon is offline   Reply With Quote
Old 06-24-2009, 10:49 AM   #23
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
Agreed. With less air density, the smallish stock turbo is becoming less efficient (READ: More hair drier).
As far as the post above, heat shouldn't be the entire equation... In addition, it should take a bit more heat than 75-85 ambient temps to cause it to limit boost. Spray your intercooler before your next run.... I would definitely knock being bigger deciding factor timing and such being pulled.
yamahaSHO is offline   Reply With Quote
Old 06-24-2009, 11:10 AM   #24
Jrags87
Member#: 119324
i did another run and at the time noticed my intercooler spray nozzle was clogged up .. so it wasn't spraying any water and was running with an extremely heatsoaked intercooler
i fixed it and the boost climbed a little bit, making me think its pulling because of the ambient temp
Old 06-24-2009, 11:46 AM   #25
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
It's definitely the heat, however, I'm willing to bet it's that combined with a small turbo that is giving you the lower boost and tapering off sooner.
Cold Weather = Low Boost for 08 STI gungaslow Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 110 12-27-2013 01:47 AM
warmer weather=rich running? ptaaty Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 05-27-2005 05:53 PM
What oil is recomended for warmer weather, 10W 30 or 5W 30? Tommi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 04-15-2004 02:18 PM
clutch chatter more often in warmer weather six1five Transmission (AT/MT) & Driveline 1 04-02-2004 12:06 AM
Utec in Humid warmer weather kenchan Engine Management & Tuning 10 07-06-2003 10:26 AM
