Old 06-23-2009, 07:55 PM   #1
mikehoyer
Member#: 103896
2000 Civic EX
Default Stock 07 WRX Wagon Intermittent Bucking Stumbling/Hesitation/Bucking
So...
Stock 2007 WRX Wagon
47,700 miles now on the car. (9/9/09)
I've been having intermittent engine problems with my car since I bought it new. The car will start to act up every few months and then the problem will go away. The problem seems to be mainly in the 2500-3000RPM range. I'll be cruising on the highway, and the car will start to buck when going up a small hill. The problem will persist for an hour or so, and then go away.
I've brought my car into the dealership for the problem. They datalogged the car while it was "acting up", and there were no problems detected from any sensor while the car was acting up.
So far, what has been done:
Flashed with a different map
Cylinder #3 was misfiring so replaced all the plugs
Removed and inspected the intake and exhaust pipes.
Used 440 fuel injector cleaner
Dry Gas
Had an EFI treatment done with BG products.
Dealership cut a hole in the fuel sock.
mikehoyer is offline   Reply With Quote
Old 07-10-2009, 05:21 PM   #2
mikehoyer
Member#: 103896
2000 Civic EX
I brought the car back to the dealership on Monday. Subaru wanted the tech to do some more datalogging on my car. I got word from Subaru today that they think the problem was due to carbon buildup. They are saying that the ethanol in fuel now causes lots of problems with the EFI system, and I should have an EFI maintenance done for $115. Whatever was stuck somewhere in my engine has aparantly let go, and it's working fine now.
Old 07-10-2009, 05:35 PM   #3
Bullwinkle1983
Member#: 172332
2006 WRX
Drive it harder more often. If you go WOT more often, you'll be less likely to have valve/misfire/buildup issues.
Seriously.
Bullwinkle1983 is offline   Reply With Quote
Old 07-10-2009, 06:48 PM   #4
Lboogie
Member#: 171611
2014 FiST
Blk
Maybe they just reset the ECU by unplugging the battery. So the issues might come back after a couple hundred miles.
The ethanol angle sounds more like dumb dealership talk. I've run E85 in my tank (4-5gallons mixed with remainer of 91 in tank) many many many times...no misfiring. I also am close to 50k mi, no carbon buildup issues.
Not only that but we have the crappiest 91octane fuel here in California, don't know what its like in your neck of the woods or if you are lucky to have 93oct at the pump.
Lboogie is offline   Reply With Quote
Old 08-18-2009, 10:05 PM   #5
mikehoyer
Member#: 103896
2000 Civic EX
Update:
I think the EFI treatment worked because my car feels more powerful overall. My guess is that I was getting really ****ty gas when I lived in Philadelphia. I think I'll get another EFI treatment in a few thousand miles to get rid of anything that might be lingering on the valves.
Old 08-23-2009, 06:10 PM   #6
mikehoyer
Member#: 103896
2000 Civic EX
The dealership told me to bring the car in while it's acting up. The problem is that I'm usually on a long trip while the problem is happening.
Old 08-24-2009, 01:49 AM   #7
iheartscooby
Member#: 183964
2007 STI Cobb stage1
dirty rims grey
Sounds a lot like the 07 STI ECU problem. Only fix for me was a tune.
iheartscooby is offline   Reply With Quote
Old 08-24-2009, 03:14 AM   #8
kh15
Member#: 132400
2006 WRX
but what is the exact cause? ie. what tables need to be adjusted?
kh15 is offline   Reply With Quote
Old 08-29-2009, 05:24 PM   #9
mikehoyer
Member#: 103896
2000 Civic EX
Update:
SOA recommends that I let the dealership try to recreate the problem I'm having. I'm leaving the car with the dealership for a few days while I'm on vacation. SOA wants to datalog the car while it's acting up. The problem is that the dealership already datalogged the car while it was acting up and there were no visible problems from any sensor. This feels like I'm just jumping through another hoop, but that's all I can do right now without suing.
Old 08-29-2009, 06:11 PM   #10
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
I suspect a bad coil pack.
bcblues is offline   Reply With Quote
Old 08-29-2009, 07:32 PM   #11
afviper
Member#: 89493
2001 330ci
I am not sure how the lemon law works but you may want to look into it.
afviper is offline   Reply With Quote
Old 09-09-2009, 06:13 PM   #12
mikehoyer
Member#: 103896
2000 Civic EX
Update:
I dropped off my car on 9/3/09 at the dealership. Luckily the car was bucking when I dropped it off. The service group leader drove the car with the service manager and myself in the car. For whatever reason, they did not datalog the car while it was acting up. The two of them decided that the fuel sock was collapsing, and that was causing the bucking.
I returned on 9/9/09 to pick my car up. They cut a hole in the fuel sock to let more fuel get to the pump. I told them the last time I brought my car in while it was acting up there was no problem with the fuel pressure. They told me to bring the car in again when it was acting up and they would replace the fuel pump. I told them I was not happy with that resolution, and I was going to speak to SOA. I spoke with SOA, and SOA told me the same thing the dealership did. I told SOA I'm done working with them, and they can talk to my lawyer.
Let the fun begin...
Old 09-09-2009, 08:59 PM   #13
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
The fuel sock is there for a reason! How is cutting a hole in it any sort of resolution?!
It's there to provide filtration of large particles that may damage the fuel sending unit (fuel pump). With a hole in it, it's now possible for some piece of crap to be easily sucked up and lodged in the pump unit. While this is an outside chance, it's at least enough of a chance that Subaru felt the need to include the sock in the first place.
Old 09-09-2009, 09:23 PM   #14
Krang
Member#: 134272
Chapter/Region: HIIC
2007 Sti, UGM
Rotated EFR 6758
Did the dealership really cut a hole in your fuel sock? Really? Because they just voided their own warranty, lol.
Krang is offline   Reply With Quote
Old 09-10-2009, 09:12 PM   #15
mikehoyer
Member#: 103896
2000 Civic EX
Yeah, it's pretty ridiculous. The fuel sock increases the inlet surface area of the pick-up tube so debris can't block fuel flow. I was pretty dumbfounded when they told me what they did.
Old 09-19-2009, 08:24 PM   #16
mikehoyer
Member#: 103896
2000 Civic EX
Update:
I was surprised when my car started bucking on the highway today. I was sure the hole they cut in the fuel sock would have fixed the problem.
Yeah...
Old 09-24-2009, 03:42 PM   #17
Daluv
Member#: 159325
Im chasing down the exact same problem on my 06 STi... cahnged the 02 front sensor and the PCV valve .. no luck
Daluv is offline   Reply With Quote
Old 09-24-2009, 08:18 PM   #18
bcblues
Member#: 17256
04 STi
I'm still thinking coil pack......
Old 09-25-2009, 08:10 AM   #19
Daluv
Member#: 159325
How can you explain that the coil pack can failed at lower rpm and not at high rpm?
Also, I dont see any misfire in my logs...
Old 09-25-2009, 10:21 AM   #20
DCales
Member#: 131509
2006 Impreza WRX
My 06' would do something similiar to this before purchasing an accessport. I really think that you should look into either an AP or having it dyno tuned. I replied to another post about a car that runs poorly intermittently and rec. the same thing. They may be able to find something that is not setting a DTC and improve the drivability.
On a side note the EFI system cleaning most dealers sell is a joke. Ive been a tech at several dealers and will say that our cars should not have a cabon issue with such low miles miles esp. when using 91 or 93 octane fuels. At best they wiped out the throttle body, added fuel treatment, and ran cleaner through the intake. I personally own the justice brothers fuel induction tool and paid $35 for it. I can get the cleaners for $20 at the local parts dept and do it myself for much cheaper.
Good luck with getting this figured out let us know if anything works for you.
DCales is offline   Reply With Quote
Old 09-25-2009, 01:55 PM   #21
bcblues
Member#: 17256
04 STi
Intermittent missing always triggers a red flag for me on the coil pack. If you have ruled out a clogged injector, that is still my best guess....
Old 09-25-2009, 02:24 PM   #22
Daluv
Member#: 159325
ok I understand that. I am only trying to understand the logic behind it...
Old 12-19-2009, 10:08 PM   #23
mikehoyer
Member#: 103896
2000 Civic EX
I'm selling the WRX. Anyone interested? It hasn't had any problems in awhile. I'm sure it's any easy fix if you know where to look. I just don't have the money to fix the car right now, and I could use the money for other things.
07 OBP WRX Wagon
54K miles
Urethane Rally Armor mud flaps
SOLD
Located in New Hampshire
Live Free or Die
Old 09-03-2016, 03:07 PM   #24
Tinker2
Member#: 453865
2005 Baja turbo
Default Inconsistent hesitation under load
2005 subaru baja with turbo has a misfire or hesitation on highway 2000-2500 rpm on hill, then will downshift rpm's go up and engine will even out, or I give gas in 4th gear. On street runs good but seems lacking slight throttle response. Recently had rebuild heads & pcv valve installed at reputable local shop. Ouch! I need a direction to look to find the problem. Please advise or at least give me a direction.
Tinker2 is offline   Reply With Quote
OBS Springs, Top Hats, Mounts, 02 WRX Wagon intermittent wiper stalk, Shift Knob cybin MWSOC Private Classifieds 1 10-02-2008 12:38 AM
WTB: Stock 07 WRX wagon rear endlinks Eppster Private 'Wanted' Classifieds 2 07-11-2008 05:15 PM
FS: JDM wagon rainguards, 07 wrx wheels, re-92 tires, stock 07 wrx wagon struts jETwRX NWIC Private Classifieds 3 01-20-2008 03:49 AM
Stock 07 WRX Wagon faster than stock 06 WRX Wagon? RightyTighty General Community 21 05-07-2007 03:28 AM
stock 02 wrx wagon hesitates and cuts out under hard accelleration gregsmith Newbies & FAQs 0 03-01-2006 06:44 PM
