Welcome to the North American Subaru Impreza Owners Club Sunday March 1, 2015
Old 06-23-2009, 11:07 PM   #1
MidLifeRally
Member#: 131322
Default Weight
I am almost finished with my yearlong RS 05 STi swap. My RSTi weighs
2935 with a/c and 10 inch 275 width rims and tires. Everything else is guttted
with a 4 point cage and Racetech seats, and intercooler spray tank and fluids.
This is heavier than I expected it to be. How does this compare? Dunk?
Boost Junkie? (I am building this car for time attack/ chasing my friends in
Vettes at track days.) Also, what would ideal corner weights be? (Weights or
percentages are O.K. Thanks to all who respond!!!!
MidLifeRally is offline   Reply With Quote
Old 06-24-2009, 12:01 AM   #2
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
2935 with you in it?
It's still pretty heavy. If it is really just for time attack and track days I'd recommend removing all the sound deadening from inside and outside the car. That stuff weighs a lot more than most people think.
Do you have a full interior?
Idea corner weights would be 50-50 side to side and 45 front 55 rear, but you will never get a subaru there. Shoot for 56 front 44 rear and make sure the cross weights are 50-50. Side to side you can't do much of anything unless you move stuff around.
speedyHAM is offline   Reply With Quote
Old 06-24-2009, 02:03 AM   #3
misterwaterfallin
Member#: 101091
why ac? why intercooler sprayer?
Strip that out, the deadening like speedy said, and whatever else you can find. If you want to lose more start cutting. The inner doors can take a shave, replace glass with lexan, ect.
also catless exhaust and new exhaust manifolds can save some weight to
misterwaterfallin is online now   Reply With Quote
Old 06-24-2009, 07:57 AM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
Probably should've started with a Brighton instead of the portly RS.
Jay Storm
sittin at 2450 with a full interior (for the most part).
Old 06-24-2009, 10:13 AM   #5
MidLifeRally
Member#: 131322
Weight was without me. A/C because I'm old, and sound deadening
is already out. Center console is in, dash and glove box. Maybe I
should have started with a Brighton, but this was my old Rally-X,
beginning track car until it blew. Seems heavy to me. Storm, I knew
you were light, but I have a full STi driveline. I just was curious what
others are????
Old 06-24-2009, 10:19 AM   #6
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
Hard to compare for me and dunk since the GC is quite a bit lighter than the GD to begin with. You can get a lot more weight out of there, just depends on whether you're willing to go all the way with it. Also, if you plan to compete with the car you should decide what series/class you will be in and make sure you build it to those rules.
boost junkie is offline   Reply With Quote
Old 06-24-2009, 11:07 AM   #7
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
Jay Storm
Now that I've built my car up I agree with this. I started with the RS since it "looks" better, and everything is there for easy daily driving. If I had it to do over again I would have started with a 95 L or something.
Now with a full interior minus the back seats per SM rules and a lot lightening allready done (still have STi seats) I'm sitting at 2910. Without me in it. Granted this is with the 6-speed transmission and the heavy Brembo's/R180. I think if you were extremely into light weight mods you'd go to a dog box 5-speed, R160 with clutch type guts, lighter brakes, and a few other things. With those changes I could see getting down to the 2600 lbs range.
For me I'm taking the sunroof out, carbon fiber driveshaft, sound deadening out of the trunk, and anything else I can find that's legal in SM. Trying to get it to 2820 (minimum weight for me).
subydude is offline   Reply With Quote
Old 06-24-2009, 11:24 AM   #8
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
This thread makes me wonder why the RS' are so much heavier than the brightons and L's or earlier years...wonder if they used a heavier sheetmetal in later models?
Old 06-24-2009, 11:44 AM   #9
MidLifeRally
Member#: 131322
I always thought that RS's were alot lighter than STi's and peeps
kept saying that with the same motor/drivetrain my car would be
noticeably faster than an STi. Thats why I was so disappointed
with my 2935 wet weight. Off to search factory stock weights...
Old 06-24-2009, 01:58 PM   #10
grippgoat
Member#: 62182
2005 STI
Carpoint.com is decent for stock weights. And 2935 is a hell of a lot lighter than even an 04 STI. 04 was 3250ish, 05 3298, and they kept getting heavier after that.
That said, go look up AnorexicSTI's thread on IWSTI.com. It's kind of epic.
EDIT: Had it bookmarked: http://www.iwsti.com/forums/gd-membe...bs-2598-a.html
-Mike
grippgoat is offline   Reply With Quote
Old 06-24-2009, 03:04 PM   #11
RB5 Clone
Member#: 30909
RA East Open Class
Champs 07-08-09
an RS shell is indeed, quite a bit heavier than an early L...electric windows, AC, sunroof, lots of body goop/insulation, those big ole long coupe doors, it all adds up quick. body shell itself is not the difference, it's all the extras.
I recently re-installed interior into a stripped 00 RS coupe, you would not believe how much all that stuff weighs--the glovebox molding and frame alone weighs 10 lbs, center console/center stack ditto, kick panels 3-5 each, carpeting 20, stock seats 40-50 each, etc etc.
I had a 94 L sedan built into 2.5NA spec Open Class rally car, it weighed just over 2600 fueled & ready to rock and only passed the 2700# minimum with a spare tire, jack, and tool kit aboard. only stock interior remaining was main dash molding, everything else was gone. This weight included 2 race seats w/6-pt belts, full cage, 15 gal fuel cell, extensive 3/8" ally skidplates, ham radio, intercom, rally computer yadda yadda.
In other words, your RS can still lose lots o weight.
RB5 Clone is offline   Reply With Quote
Old 06-24-2009, 05:36 PM   #12
Fred
Member#: 3560
06 STi, 02 WRX
94 Open Light 2.5RS
Bring it over to my house and I'll help you/ show you where to remove lots of weight. Done a few things with my rallyx RS, but I know where there's lots more - but it's not coming out of mine yet.
Fred is offline   Reply With Quote
Old 06-24-2009, 10:55 PM   #13
kwh29
Member#: 22100
Your full STi drivetrain is heavy - remember the '04 WRX was still listed at 3080 or some such yet the '04 STi was almost 3400. All that weight is in drivetrain as the trim on an '04 isn't meaningfully heavier than the same year WRX.
Have you done the standard auto-x weight drop mods? JDM (or removed and replaced with zip ties) fender beams, Braille battery, changing all the doors to roll-up and yanking the extra wires from the harness, removing the bottom layer of the sunroof (saw that you already reskinned the roof. Nice!) etc? All of those things add up quick. Also there's a fair amount of just plain extra stuff under the car that you are legal to pull that auto-x people have to leave, like the tow tie downs and the block of iron under the crossmember. All the above added up can easily save more than 100lb.
You also have a rollbar, if only a 4-pt. That's +75lb or so that most street people don't have. Not that I'd remove it. With a car as capable as yours I'd personally go the other direction and upgrade to a road race legal cage.
--Kevin H.
kwh29 is offline   Reply With Quote
Old 06-24-2009, 11:22 PM   #14
MidLifeRally
Member#: 131322
Thanks Fred!You know I'll take you up on that! I would like your opinion on some set-up stuff as well. Kevin H., planning on running HPDE and TT the rest
of this year and get Chris Shimmel to finish the cage this winter. Again, was
just disappointed on how heavy she was. Anyone have any roll up windows
the want to trade? I already have light weight bumper beams, lighter hood
and trunk, re-skinned roof with no liner. Must be more pork somewhere!!
Old 06-24-2009, 11:50 PM   #15
grippgoat
Member#: 62182
2005 STI
Originally Posted by kwh29 View Post
Your full STi drivetrain is heavy - remember the '04 WRX was still listed at 3080 or some such yet the '04 STi was about 3250. All that weight is in drivetrain as the trim on an '04 isn't meaningfully heavier than the same year WRX.
Fixed.
-Mike
Old 06-25-2009, 12:23 PM   #16
subydude
Member#: 80649
Like everyone says, the swap adds a lot of weight to the car to begin with. The engine and tranny combo add about 225 lbs, brakes and rear end add at least another 50. Tack 275 onto 2825ish and you're at 3100 lbs with full stock interior.
But lighter hood, lighter trunk, all the metal NVH bits removed, a lot of "hidden" parts removed and it'll get down there. My 2910 is with the heavy stock bumper beams in place (if you're going for SM the JDM bumper beams are illegal). I think with removing the sunroof on mine and taking out a few more things from behind the dash I can get it down to 2820 with a full dash, and Ver 7 STi seats. That would be like getting a regular RS down to the 2550 lbs range. It's definitely possible, and unlike the anorexicSTi guy you won't be spending as much $$$.
Old 06-26-2009, 12:15 AM   #17
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
AcquaCow's car (RS w/ 04/07 STi swap) was 2887, no rollbar.
http://forums.nasioc.com/forums/show...ghlight=scales
Old 06-30-2009, 06:35 PM   #18
vids
Member#: 120113
2002 WRX, full-race,
GT35, built engine, etc.
In the floor, there is several bars that exists for crash safety. Take them out if you have a good cage. Also, every door has some solid metal in it that can be removed if you have a good cage, or are willing to take a chance without it... Certainly no more dangerous than driving an old car anyway...
I think there is about 10kg in every door.
vids is offline   Reply With Quote
Old 06-30-2009, 07:33 PM   #19
vinceGC8
Member#: 72263
2008 Impreza STi
Dark Grey Metallic
u remove the front and rear crash beams and go with lightweight battery?
vinceGC8 is offline   Reply With Quote
Old 06-30-2009, 07:35 PM   #20
MidLifeRally
Member#: 131322
Default Subydude
PM me about the carbon fiber driveshaft. Sounds interesting. Any exp.
with one or know anyone with one? Fitment?
Old 12-04-2009, 05:54 PM   #21
John2.5RS
Member#: 1140
2013 Ecoboost'd F150
Grey
I have my RSTI sitting at right around 2700 wet, without me in it.
That's with a 6-speed, R-180, BBK, etc.
It would be lighter without a cage or maybe a lighter, chrome-moly cage.
If $$$ is no object, look into a Lithium-Ion Battery (It's on my future 'wish-list )
Same ones found in top-end racing.
There's a lot of weight to be found in stuff you don't use much on the track.
Power windows, pwr. mirrors, foglights, stereo, extra wiring, etc.
You can find weight to lose, you just need to be creative!
I've had a CF driveshaft for a few weeks now. It's a nice mod, as long as you can deal with the quirks that come with swapping a 2-pc driveshaft for a one piece unit.
I think it was well worth it. MUCH lighter that the stock piece (less than half the weight, IIRC) and it fits good, but you either need to trim or removed the lower plate at the rear u-joint.
John2.5RS is offline   Reply With Quote
WRX rim weight? P7 rim weight? jblaine Brakes, Steering & Suspension 3 12-18-2001 02:01 PM
X-Brand Tire Weight Vs. RE92 Weight ITR&RSGUY Brakes, Steering & Suspension 5 08-03-2001 11:26 AM
X-Brand Tire Weight Vs. RE92 Weight ITR&RSGUY Brakes, Steering & Suspension 0 08-02-2001 01:37 PM
99' wheel weight vs. 00' wheel weight? Dolphin Overton Brakes, Steering & Suspension 4 06-26-2001 05:21 PM
curb weight vs. gross weight mtn-boy Technical Forum Archive 2 08-05-2000 03:53 PM
