Old 06-24-2009, 12:50 AM   #1
nxttruck2002
Member#: 90879
Default 245/45R17 on 17x8"
I got 4 new 245/45R17 Kumho Ecsta XS from my brother because he sold the car he bought them for. So I have them sitting in my garage waiting to be put on the car. I'm on stock 17x8s and would like to know if these will fit with no rubbing, too much side wall flex, or are they just too wide. Would you recommend an alignment if mounted? Other advice?
100% stock 2006 sti
nxttruck2002 is offline   Reply With Quote
Old 06-24-2009, 03:19 PM   #2
EdHilario
Member#: 137398
2004 Impreza 2.5RS
Way oversized...
EdHilario is offline   Reply With Quote
Old 06-24-2009, 03:54 PM   #3
Chris_Lee
Member#: 110667
2006 WRX
Those should fit fine. I have 245/40 on my wrx and the Sti wheel wells are larger than mine. You may need a new alignment though because of the side wall height. 45 looks a bit tall.
Chris_Lee is offline   Reply With Quote
Old 06-24-2009, 06:45 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Originally Posted by EdHilario View Post
Way oversized...
no as in not
again...no as in not
the reason to get an alignment is getting a PERFORMANCE alignment
and a 'totally stock' sti has a REAL **** alignment as the factory alignment is always ****
Old 06-24-2009, 06:50 PM   #5
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
They are going to look great on there.
crpwrx is offline   Reply With Quote
Old 06-24-2009, 07:42 PM   #6
mrcoder
Member#: 93785
2005 STI
Default good to go
245/45/17 on 17x8 stock BBS on 2005 STi
No problems. Fenders are stock, not rolled. Suspension is stock, not lowered.
mrcoder is offline   Reply With Quote
Old 07-24-2009, 10:18 PM   #7
nxttruck2002
Member#: 90879
How should I know the appropriate PSI to put in the fronts and rears? 245/45R17 Kumho Ecsta XS. Any ideas or recommendations?
On the stock re070's 225/45R17 it is front:35psi rear:29psi
Old 07-25-2009, 01:59 AM   #8
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
The tires will fit the wheels just fine, but the overall diameter will be bigger than stock. The '94-03 Mustangs came with 245/45s on 17x8s for years, and there are other OEM applications of the same fitment.
As for pressure recommendations I would start with both ends the same at like 35 or 38psi, something like that. A lot of it is personal taste - higher pressure will stiffen the sidewall to an extent and improve steering response, but it also firms up the ride a bit.
Pat Olsen
235/45R17 or 245/45R17 focused_80 Tire & Wheel 14 05-03-2008 07:31 PM
245/40r17 or 235/45r17 on 17x8? toebotypera Tire & Wheel 7 06-08-2007 12:14 PM
Poll 245/45R17 or 255/40R17 Victoracers on Stock BBS for STi? crystalhelix Motorsports 9 05-13-2005 09:23 PM
245-45R17 Kumho Victoracers for STi in AS? cgroppi Tire & Wheel 2 04-23-2004 11:54 AM
Snows 245/45r17 any uses? jeff22 New England Impreza Club Forum -- NESIC 10 01-16-2004 07:15 PM
