Old 06-24-2009, 12:10 PM   #1
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Default TPMS cross-compatibility? (Searched)
I did a quick search (here and on LGT) and posted over on LGT.
I just grabbed my summer (3-season)/track wheels and tires from another NASIOC member. I want to run them for 3-season use, at least until I wear out the tires or get some dedicated track wheels. I don't want to live with the TPMS light all of the time, but I don't want to pay to have the TPMS moved back and forth, nor to have 8 tires dismounted/remounted to move the 4 sensors.
Some junk yards will pull all 4 sensors and the computer. Are there any Subaru TPMS sensors that are NOT compatible with our brain? While I am at it, are there any other vehicles (other brands) whose sensors are compatible with the system that we have (assuming, of course, that they are properly reprogrammed)? I also see that TireRack sells TPMS sensors- do those work with our brains (again, assuming a reprogram)?
Just some info from LGT (that I did not see when I searched over here)- You can also put a set of TPMS in a second set of wheels and get a second TPMS controller and have those 5 components all programmed. This allows you to swap wheels AND the controller, to avoid the issue of having to either transfer the sensors or have the receiving unit re-programmed to accept different sets of TPMS sensors every time you switch wheels.
Thanks.
phenryiv1 is offline   Reply With Quote
Cross Compatible Flywheel? klepic Transmission (AT/MT) & Driveline 0 04-20-2006 10:04 PM
What basic suspensions are cross compatible variable Brakes, Steering & Suspension 2 07-29-2005 12:09 AM
2002 and 2003 Wrx ECU's cross compatible? miraclemonkeywrx Engine Management & Tuning 1 10-02-2004 02:02 PM
Question: Are all EJ series oil-pans cross-compatible? Kostamojen Subaru Conversions 2 03-09-2004 01:16 AM
Subaru Front Struts are cross compatible? cakagan Technical Forum Archive 2 09-08-2000 12:48 AM
