Old 06-24-2009, 12:55 PM   #1
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
Default ARP Extended Lug Install?
How difficult is it to install the ARP extended lugs on an 04 STi? I expect it would mean disassembling the rear only?
bcblues is offline   Reply With Quote
Old 06-24-2009, 01:06 PM   #2
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
No, I'm not following you. Don't flatter yourself.
Fronts are very easy. Remove rotors. Thread sacrificial lug nut on stud, hammer out. Pull in new stud with open ended lug nut and washer stacks. You will have to rotate the hub to the front for each one.
For the backs I did this: For the record the backs would only take longer than the fronts by the amount of time spent grinding/machining down the head of the studs.
Originally Posted by mccanixx View Post
If you end up doing the rears follow this.
Rear studs
ARP studs have a slightly bigger head than factory. Studs that come with like HR spacers will fit through, I don't like their studs however.
So....I simply rolled the ARP heads on my grinder for like a minute a piece. The heads are about the size of the sensor opening so it really only added ~ 10-15 minutes to the whole deal. Saved alot of heartache YOU DO NOT HAVE TO PULL THE REAR HUB FOR ARP STUDS.
This works for USDM I'm assuming the JDM hub is not that different and has ABS
mccanixx is offline   Reply With Quote
Old 06-24-2009, 01:10 PM   #3
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Front is pretty ez and streight forward. Hammer the old one out and put the new one in. Tighten the lugs a bit tighter to seat the stud. But don't strip it.
Rear is going to be tough
Old 06-26-2009, 01:29 PM   #4
bcblues
Member#: 17256
04 STi
Ended up taking it into the shop for the install. They estimate about $600, which includes pulling the rear hubs and replacing the bearings.
how to install extended lugs? vms150 Newbies & FAQs 26 01-06-2011 12:17 PM
HELP: ARP extended wheel studs and volk racing lug nuts Rod702 Brakes, Steering & Suspension 3 01-23-2010 03:06 PM
Super Easy rear wheel spacer / extended lug nut install Bad Noodle Brakes, Steering & Suspension 1 05-06-2009 02:07 AM
FS: Rays extended lug nuts & Work lug nuts supaflyTS VIC Private Classifieds 4 04-02-2009 10:14 PM
Volk Lugs Aluminum Extended Lug Nuts, Volk Locking Lug Nuts, Genuine Suby Wheel Locks timeless Wheels/Tires 10 08-21-2008 01:06 AM
