Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 06-24-2009, 12:59 PM   #1
slicksboy
Member#: 174808
Default Seat belt Chime
Did the search and tried the 20 clicks in 30 seconds to disable the chime. Didn't work for me ('06 A/T). Any suggestions?
slicksboy is offline   Reply With Quote
Old 06-24-2009, 01:08 PM   #2
scf
Member#: 189579
Step 1. Sit in the driver's seat and close the door.
Step 2. Insert the key in the ignition and turn to the "on" position (but do not start the engine).
Step 3. Fasten and unfasten the seat belt 20 times within 30 seconds. Then, within 10 seconds, open and close the driver's door.
Step 4. The chime will sound when you start the car, but it will not repeatedly sound if the seat belt is not fastened.
Is this the procedure you used?
scf is offline   Reply With Quote
Old 06-25-2009, 07:28 AM   #3
jeromes
Member#: 192299
2011 Forester XT
Default Yes it works
What I found on my tries is that you have to release to button for the insert / removal to be read by the computer.
I too tried this and cussed after many tries. Then I would plug in / push button removed / release button...... do again for 20 total, and it word. Hve done it on three Cars.
jeromes is offline   Reply With Quote
Old 06-25-2009, 03:16 PM   #4
JLBaja
Member#: 137951
2006 Baja Turbo Blue
Phat Botti Tuned
Definitely works. One of the first things that I did.
I know I'll get some heat for this, but if you want to disable your DRLs (Daytime Running Lights) also, see this thread...http://forums.nasioc.com/forums/show...1012964&page=2
JLBaja is offline   Reply With Quote
Old 06-28-2009, 06:08 PM   #5
slicksboy
Member#: 174808
Thanks scf, it worked. I think it was the open/closing door step I left out previously.
how to disable seat belt chime on 06 sti? wrb2006sti Interior & Exterior Modification 14 04-25-2013 09:35 PM
seat belt chime delete? snowman87 Newbies & FAQs 32 03-16-2010 11:52 PM
seat belt chime dupah68 Newbies & FAQs 99 05-09-2008 03:36 AM
seat belt chime dupah68 Legacy Forum 14 07-27-2007 01:55 AM
Where is the seat belt chime on an 07 sti? StiLimited Electrical & Lighting 4 12-21-2006 12:37 AM
