Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 06-24-2009, 11:37 PM   #1
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
Default Throttle off oversteer....08 STi STU
What is a good way to get rid of Throttle off oversteer...
08 STi for STU competition....STU Tune on Sport Sharp....Diff is 0 traction control on or off...doesn't matter..:/...Coilovers...STock Sways....Camber...still on stock Dunlaps...seems to happen more on the transition stuff....in particular ....Slaloms...or any sweeper turn where you have to let off the gas...
Any ingenious ways to get rid of it????
Thanks
Scooby South is online now   Reply With Quote
Old 06-25-2009, 12:16 AM   #2
Splash
Member#: 55936
04 WRX STi
32mm front bar....
Splash is offline   Reply With Quote
Old 06-25-2009, 12:32 AM   #3
mofugga
Member#: 19540
2000 old skool RS
BRP
keep your foot on the gas!
mofugga is offline   Reply With Quote
Old 06-25-2009, 12:43 AM   #4
DJSuperSoul
Member#: 120004
2xx8 STI
grey
who makes the bar?
DJSuperSoul is offline   Reply With Quote
Old 06-25-2009, 12:45 AM   #5
08WhiteRex
Member#: 187453
2012 Mulletmobile
Keep your foot in it...
08WhiteRex is offline   Reply With Quote
Old 06-25-2009, 12:58 AM   #6
Splash
Member#: 55936
04 WRX STi
Niles makes custom bars. I dunno if he's here, but I know he's on IWSTI. I had a 32mm front bar on my STi when it was in AS, and I know he makes them for GR/GH's as well.
(Not that I was serious about him getting one, just that it would fix that oversteer problem up right quick)
Old 06-25-2009, 06:24 AM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
Niles is local to me. Last I knew, he still had barstock in the garage and the jig still tacked up on a table..... He's been really busy with work and school, as well as getting his trackwhore sorted, so timely responses may not happen consistantly. I'll pass along the word to have him make another couple bars.
Jay Storm
Old 06-25-2009, 08:33 AM   #8
gotsol
Member#: 17346
08 Cayman S
In all serriousness my old WRX with a 6-speed swap was the most tail happy car ever. I was even going to enter it in drift events but someone told me AWD wasn't allowed.
I'd learn to drive with it. If you can't then set some toe in
gotsol is offline   Reply With Quote
Old 06-25-2009, 09:48 AM   #9
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
so....to summarize....
-A Bigger Front bar...
-keep your foot in it...
-dial in some rear rebound
-Dial out some some front Compresson
- rear toe in
-Alignment check...(front -3.5 about 1/4 toe out... -1.2 rear, 0 toe )
Ok...this only happens when you lift....to say to enter a slalom, or heavy transitions....where you lift to Set the car....
Bill
Old 06-25-2009, 10:20 AM   #10
Chiketkd
Member#: 71634
In hibernation...
Bill
My advice Bill. Just catch it an go! Drive a miata, then drive that STi again. You'll quickly learn how to catch oversteer early and get back on the skinny pedal.
I see lift throttle oversteer as an excellent thing for any awd/fwd car. Damn - wish I could have made my former DS WRX handle like that!
P.S. +1 on adding slightly more rear rebound and/or adding some rear toe in.
Chiketkd is offline   Reply With Quote
Old 06-25-2009, 11:17 AM   #11
BlkWRXWag
Member#: 31821
2015 DS WRX
We used to have that problem on my old 06 STI - a bigger front bar was the solution.
BlkWRXWag is offline   Reply With Quote
Old 06-25-2009, 01:04 PM   #12
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Thank you sir...Exactly what I was looking for......no way to get it before sun I guess.... oh well
Thanks again...
Bill
Old 06-25-2009, 01:06 PM   #13
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Originally Posted by Splash View Post
32mm front bar....
perfect..
Old 06-25-2009, 01:09 PM   #14
BlkWRXWag
Member#: 31821
2015 DS WRX
Having said that, it was fast if you could catch it! However, the odds of a clean run were slim. Every time you lifted off the car wanted to spin. When my codriver Aaron took his first run in the car, I think he spun in it within the first 200 yards
Braking and turning were just impossible though if a course required it. This was with the stock FSB. I replaced it with the Cobb 25mm hollow and the problem went away.
Old 06-25-2009, 01:14 PM   #15
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Snap oversteer has been commonly a trait of the open/viscous cars and largely went away with the STIs. However, odd setups can exacerbate the issue even with good diffs. The 03 WRX we are setting up has snap oversteer and we are trying to eliminate it (and have been unsuccessful so far). I'm told it is needed to make the car rotate. The 06 STI we are setting up had snap oversteer but we eliminated it. It can use the diffs to make the car rotate.
If you are dealing with a lift snap, it is typically caused by instantaneous loading/unloading of the tires. This translates into rear rebound, front compression, front spring, and front or rear bar. More rear rebound limits the weight transfer from the rear. More front compression limits weight transfer to the front. More front spring limits weight transfer to the front. More front bar limits weight transfer to the front. Less rear bar limits weight transfer from the rear. Keep in mind that rebound, compression, and bars are for lateral transitions (slaloms/offsets), and springs are for constant loading (sweepers) or longitudinal transitions (braking/accelerating).
I didn't notice the snap on my 08 STI, but it is a very premature build with lowering springs and bars so far. The 08 STI, specifically, will add camber and toe-in when weight is transferred to it. If you have excessive body roll, you may be significantly decreasing camber and going toe-out.
Old 06-25-2009, 01:17 PM   #16
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Having said that, it was fast if you could catch it! However, the odds of a clean run were slim. Every time you lifted off the car wanted to spin...
I agree with this. It is a little unsettling when you have to worry about when you hit the brakes or if you can catch it fast enough as it rotates through the slaloms. Fast, though, if you stay ahead of it. The lifting/braking is what deters me from this setup. It is ok if you can hit the gas to smooth out the transition- braking doesn't exactly settle it.
Old 06-25-2009, 01:22 PM   #17
BlkWRXWag
Member#: 31821
2015 DS WRX
Nightmare scenario - fast curving entry into a tight slalom!
I lost the Atwater Tour a few years ago, as the car simply could not get into that slalom without going sideways!
Old 06-25-2009, 01:25 PM   #18
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
That puts things in a better perspective for me....thanks..so either way your trying to limit to Transitional forces to be more predictable....or better yet so the car doesn't get upset when these transitions occur...so essentially, Any of the above will have a greater effect on Results, be it better or worse...
I See..Thanks...I was trying to figure out what was going on...now when the car is on power and in transition...it handles with a slight understeer, but ease off the go pedal..and the backend wants to swap ends...not violently but a gradual motion...IE: Slo-mo Spin...
thanks again
Bill
Old 06-25-2009, 01:25 PM   #19
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
I lost the Atwater Tour a few years ago, as the car simply could not get into that slalom with going sideways!
EXACTLY.....same type of scenerio
Old 06-25-2009, 01:26 PM   #20
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Yep....Same...
Old 06-25-2009, 04:01 PM   #21
AtomicRacer
Member#: 84586
1995 Frankenpreza
2012 Tundra DC 5.7L
Max,
Left foot braking is your friend. =0
-Paul
AtomicRacer is offline   Reply With Quote
Old 06-25-2009, 04:04 PM   #22
BlkWRXWag
Member#: 31821
2015 DS WRX
Originally Posted by AtomicRacer View Post
Max,
-Paul
I'm not that talented!
Old 06-25-2009, 09:08 PM   #23
KC
Member#: 442
13 Crosstrek XV
00 S2000
slow down more earlier and then power out of it? you can't just keep on it everywhere.
KC is online now   Reply With Quote
Old 06-25-2009, 09:31 PM   #24
dstan
Member#: 120386
2000 BRP 2.5RS Coupe
Wow the 89 Civic is fast
so Bill you have a new STi ?
dstan is offline   Reply With Quote
Old 06-25-2009, 09:38 PM   #25
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
All you gotta do is push the middle pedal. It's easy.
Keep in mind, a vacuum assisted braking system won't work well at WOT, so you can really stomp on the brakes.
sniper1rfa is offline   Reply With Quote
is there a way to take off the side moldings off the 08 sti? swizz977 Interior & Exterior Modification 1 08-13-2009 09:32 PM
FS: CT Dunlop Sp Sport 600 Tires off of 08 STi $450 OBO dml145 Wheels/Tires 5 07-15-2009 10:29 PM
FS 07 BBS w/Dunlop winter tires off my 08 sti stealthgr Wheels/Tires 8 02-07-2009 03:55 PM
FS (NJ): Dunlop SP 600 tires off my 08 STi 245/40-18, <4k break-in miles ddcha Wheels/Tires 0 02-05-2009 09:08 AM
IHI vf48 turbo off my 08 sti - this vf48 has no shaft play and never blew smoke vhalin Engine/Power/Exhaust 10 11-14-2008 03:34 PM
