Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 08-09-2009, 12:48 PM   #1
freeride
Member#: 49783
2000 2.5rsti&98wagon
SRP/white
Default crank case hoses
The hoses were connected to the intake/airfilter, or im my case it was the COBB CAI that had 2 nipples to connect the hoses. So Right now I have 1 hose connected to one crankcase and the other hose is connected to the other crankcase and "t" to the other side of the PCV.
Now after being boosted I have these 2 hoses just sitting in the engine bay. After reading some threads on the emmisions system with crank case vapours on a N/A car:
"At the part throttle, the blow-by gas in the crankcase flows into the intake manifold through the
connecting hose of crankcase and PCV valve by the strong vacuum of the intake manifold. Under
this condition, the fresh air is introduced into the crankcase through connecting hose of rocker
cover.
At wide open throttle, a part of blow-by gas flows into the air intake duct through the connecting
hose and is drawn to the throttle chamber, because under this is condition, the intake manifold
vacuum is not so strong as to introduce all blow-by gases increasing with engine speed directly
through the PCV valve."
SO should I leave the hoses as is or I have heard to connect them to the intake before the turbo w/wo a catch can. But that seems to be pulling out the vapours rather than allowing fresh air to be drawn in.
freeride is offline   Reply With Quote
silicon lines for crank case vent hoses? kh15 Newbies & FAQs 1 04-28-2010 12:15 AM
2.5 crank case?? spoolinred Built Motor Discussion 1 06-08-2006 05:53 PM
02-03 WRX crank case vent bikerboy Private 'Wanted' Classifieds 1 12-27-2004 10:36 AM
Two crank case vents on JDM blocks? wRxbeater11 Subaru Conversions 2 06-29-2004 06:58 PM
Crank case venting thoughts... GLwagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 09-02-2003 04:53 PM
