Old 06-23-2011, 11:43 PM   #351
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
Nice job. Man I wish i knew you were getting tuned. I was in WA all week for work. I was in Bellevue I don't know if that is near you. Very nice power. I hope to get my car tuned soon. What dyno does dom have is that a mustang? 409 on a mustang is awesome.
NITROS is offline   Reply With Quote
Old 06-24-2011, 12:28 AM   #352
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Rotated BW S256 6speed
Thanks guys!
Yeah Bellevue is about 30 minutes away from Marysville I do believe. I drove right through it on the way to his shop.
The Dyno is a Dynocom which doesn't read as low as a mustang. I think a stock 08' sti puts down 245whp on his dyno.
morrocco88 is offline   Reply With Quote
Old 06-24-2011, 01:22 AM   #353
simonasaur
Member#: 128997
99 rsti 207
white
best build thread ive read. nice job on power and on super clean looks!
simonasaur is offline   Reply With Quote
Old 06-24-2011, 11:31 AM   #354
httrdd
Member#: 224180
Wow that is truely amzing to make that kind of power! I hope to push that spoolin a Eg33.
httrdd is offline   Reply With Quote
Old 06-24-2011, 11:36 AM   #355
httrdd
Member#: 224180
Recent pics of the car? I am fabricating a grill out of an old "tall" grill that will bolt to the bumper. With my external fans in place I cannot use a clip type grill. It will be only frame and mesh with the Subaru symbol in the middle.
Old 06-25-2011, 01:49 PM   #356
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Thanks guys, it was a lot of work and determination to keep going after all the setbacks.
The car looks the same as the previous pics, but I too need to make a grill. I'm going to do the same....use the taller frame from the stock grill and have some sort of "tastefull" mesh painted black and then will use a custom made "L7" piece in the center. I have a friend that has a 1 Million dollar computerized lazer cutter at his work. I'm going to design the L7 and then probably cut it out of stainless and polish it. If it turns out, I might have him cut out a bunch for other people.
Old 06-26-2011, 12:07 AM   #357
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
Interested in one if you do
sense of nature is offline   Reply With Quote
Old 06-27-2011, 06:53 AM   #358
httrdd
Member#: 224180
Wow that would be different!
Old 06-27-2011, 11:28 AM   #359
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
Garris,
This car deserves the Nasioc's Top Scoob award!
...I'm just going to enjoy the car for a while....
We'll see about that!
Td
wtdash is offline   Reply With Quote
Old 06-27-2011, 02:15 PM   #360
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
^^^ Thanks! If they do a Legacy top scoob again, I might enter.
You know me too well . I'll try not to tear it apart and change the setup for a while. I don't know though.....I'm gathering parts for a 2.3 de-stroker high rpm motor with a rotated GT3076
I have a sickness!
Old 06-27-2011, 06:10 PM   #361
NITROS
Member#: 41561
04 GT3076 2.1
You're not the only one.
Old 06-27-2011, 06:21 PM   #362
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
I guess there is worse things to be addicted to.
The car is so bad ass right now though....I could stop now and totally be happy. The driveability of the speed density on this Link G4 is so smooth and refined, and the car just hauls ass without even getting into boost. I love how effortless and smooth the shifting is on the 6 speed with all the bushing upgrades and heavy weight knob. I was driving home taday with a huge grin on my face with the A/C blowing, cruise control set, and knowing I could blow the doors off just about any car I come accross
The only reason I'm gathering parts for a 2.3 de-stroker is because I like to have a back-up plan just in case anything breaks. I figure the high rpm smoothness of the de-stroker plus the short JDM gears will make for an amazing combo. Once you experience one, no other subaru motor compares. I think you need to have the short gears with it though, because it would suck with a 5 speed.
Old 06-27-2011, 10:43 PM   #363
cbryant514
Member#: 286855
Awesome swap - modern heart in classic shell!
cbryant514 is offline   Reply With Quote
Old 06-28-2011, 03:46 PM   #364
httrdd
Member#: 224180
Nah drugs are cheaper!
Old 06-28-2011, 07:01 PM   #365
Joelo_00
Member#: 175095
Chapter/Region: PRSIC
2000 RS
It's what makes a Subaru, a Subaru....
Joelo_00 is offline   Reply With Quote
Old 07-04-2011, 09:40 PM   #366
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Update: Well, a couple days after the tune, it was confirmed the head gaskets were leaking under high boost. We had some coolant spew out of my overflow bottle on the dyno, but the temp gauge never moved past normal and we thought maybe I just over-filled it, and I had never heat loaded the motor like we did doing a bunch of pulls on the dyno. I emptied the overflow and drove 100 miles toward home and stopped for gas, the level was the same (about an inch in the bottom) and the car was running normal on the temp gauge, so I thought I was good.
A couple days later, I took a buddie for a ride and after doing a few pulls, the temp gauge started rising and the overflow bottle was full again . The Cometic .040" gaskets combined with setting the torque on the ARP head studs to 85ft lbs proved to be the downfall. I guess ARP has since raised the torque value to 90 ft lbs., and Dom says they torque to 95 ft lbs on the Cometics and don't have any issues. My motor was put together back when ARP had just raised the torque value to 85 ft lbs from 72, so we thought we would be good to go....not so much.
The good news is that I'm really good at pulling the motor on my car. I also just pretended it was a full blown race car, because their motors get pulled just about after every race, and tear them all the way down before the next race. This way I wouldn't be wrenching pissed off . Dom advised me to go with factory gaskets and torque to 90 ft lbs on the outers and 95 ft lbs on the inners.
Pics:
Got the motor all torn down and cleaned the mating surface with acetone
Same with the heads, everything is looking good
I decided to copper coat the gaskets to help things seal up good since I wasn't going to re-surface the heads
Motor all back together and going in the car
All I'm waiting on now is new exhaust gaskets I ordered, and my new turbine housing.
I finally got Blouch Turbo to sell me one of their new, one piece cast, TD06 8cm housings for the Dom3. The old one was leaking a bit at the welds and was re-welded, but it's leaking again. I tried to get it installed before my tune, but couldn't get Blouch to sell me one in time. They finally decided to sell me one, and I should have it tomorrow. I will have to blast it, ceramic coat it, and then bolt it on with the rest of my exhaust and she will be back on the road.
I'm planning to go to the Big NW Meet, so hopefully I can get it back together in time.
Old 07-04-2011, 11:00 PM   #367
Maxwell Power
Member#: 190729
AWESOME BUD!
Thank you for the kind words and not giving up. Many other customers would have walked away blaming their tuner for their issues. I'm glad we finally got her to run like she should. I'm also happy to hear that you are going back to the OEM gaskets (that's what I built the block for anyway).
I look forward to seeing you at the meet. I believe we have a free spot in our booth and I'd be honored to have your car in it.
Have a good one man,
Dominic
Maxwell Power is offline   Reply With Quote
Old 07-05-2011, 01:51 AM   #368
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
You would be honored? I would be honored, but I don't know if she is booth worthy with my license plate grill
Yeah, blaming other people for stuff that happens doesn't get you anywhere. It's always the tune's fault, right .
I just appreciate all your time you spent trying to troubleshoot, and doing the R&D to find a solution to the knock issue. It really is amazing at how much of difference spark plugs and a header can make! I mean, the car ran pretty good before, but you knew it wasn't it's full potential and it wasn't "right". So you didn't give up until it was dialed in. I have heard that from other people too where you went out of your way to troubleshoot a problem on a car that had come into the shop that way. I've seen a lot of other tuners just kick the car off the dyno and say "bring it back when it's fixed".
Thanks again, and see you at the show!
Old 07-05-2011, 09:50 AM   #369
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
yeah get some leggy love next the fozzy
NW2TONE is offline   Reply With Quote
Old 07-05-2011, 02:00 PM   #370
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Dave, you got the fozzy back together? Did you re-tune?
I think I will park next to the Fozzy. What time should I be there to park in your booth?
Old 07-05-2011, 11:15 PM   #371
NW2TONE
Member#: 212509
your **** go faster
yeah its all put back together. It will have enough miles on it to get it tuned on friday hopefully. Breanna wants to be able to get it on the way to the show so I hope we have time to tune it friday morning or thursday night.
We are gonna be there hella early but Im sure we will save you a spot
Old 07-06-2011, 10:30 PM   #372
GuamSTI
Member#: 210071
04 STI
Subscribed
GuamSTI is offline   Reply With Quote
Old 07-11-2011, 01:37 AM   #373
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Update:
Car is running really good, and almost feels like it's a bit more snappy with the tighter quench from ditching the thicker gaskets.
Drove 100 miles each way to the Big NW Meet and I'm really happy with the decision to make sure the A/C and Cruise Control were left intact. The car is just so nice to drive like a normal car, but when you want to have some fun just floor it
I felt really honored to be invited to park in the Maxwell Power booth at the show. They saw me in the line and waved me over to dodge some cones and come in the back way to their booth. It felt like VIP treatment .
I got a lot of positive feedback from people looking under the hood and that felt really good after all those hours slaving in the shop. It was cool to have people appreciate my design and look I wanted for the car. All in all it was an amazing time!
couple pics:
I got to pull in behind most of the MPS cars right next to one of their tables and park next to a cool Turbo S2000 they built for a customer.
My very pregnant wife passed out in the passengers seat . She was such a trooper!
Now I can finally enjoy the car and plan to take her out to the WCSS13 this year since I missed the last two. I will be working on some other small detail work and plan to do a full repaint this winter hopefully.
more updates to come.
Old 07-13-2011, 12:11 PM   #374
triplet911
Member#: 106971
1998 lgt
red
damn that is a cool pic bro thanks for the post its giving me some hope with my swap
triplet911 is offline   Reply With Quote
Old 07-17-2011, 09:50 PM   #375
sense of nature
Member#: 112759
SexyRP
Nice to be finally "done" huh?
Aquamist HFS-6 install into 97' LGT with 04' wrx swap: Pics Inside morrocco88 Water/Methanol Injection, Nitrous & Intercooler Cooling 4 04-22-2012 06:51 AM
My 2.1 Stroker build with part numbers so you can do it too! DSM Nexus Built Motor Discussion 79 10-06-2011 12:19 AM
Dom 3 or Dom 2.5 or Dom 1 or FP Green? Want ~400 whp with quickest spool? 2.1 stroker NITROS Built Motor Discussion 10 10-26-2009 12:40 PM
V8 6 speed into 97' LGT - Which drive shaft? morrocco88 Transmission (AT/MT) & Driveline 12 09-23-2009 11:21 AM
05 lgt with new stuff...brembos and more clawdnb Member's Car Gallery 23 01-20-2008 07:15 AM
