Old 06-25-2009, 02:11 PM   #1
CatchMyDrift
Member#: 54523
Exclamation Can I drive on bad head gaskets?
I need to drive a 98 impreza from redding,ca to Paradise,ca which is about 1.5 hours. The owner says it has a bad head gasket because it overheats and and has to stop and put water in every 10-20 minutes or so. He reports there is NO water / coolant in the oil.
To drive this thing confidently for a 1.5hr distance @ highway speeds, is there anything I can do? Here are my ideas:
Pull thermostat out
keep adding water
blast the heater on high the whole way.
Am I risking too much?
CatchMyDrift is offline   Reply With Quote
Old 06-25-2009, 03:08 PM   #2
OneBadPig
Member#: 181858
2016 WRXcwp,04WRXsrr
15Outbacktungstenmtallica
I m not a mechanic..just manic...but i wouldnt risk it. If the heads arent already warped they might end up that way.
Even though there is no water in the oil. that could soon be the case also.
I think (someone qualified check this) there is a danget of getting water in a cylinder...then boom.
I had a leaky gasket years ago, what i thought was white smoke turned out to be steam. I was damn lucky
OneBadPig is offline   Reply With Quote
Old 06-25-2009, 08:28 PM   #3
flstffxe
Member#: 155358
2008 Forester
Steel Silver
sign up for AAAplus($59.95) and have them tow it(24-Hour Emergency Towing (Up to 100 Miles). You are covered for any vehicle you are in.
We did this for a neighbors car when it wouldn't start in sub-zero weather. Total cost of 146 mile tow was $36 + $59.95(AAA membership) = $95.95. Compared to the $250-350 we were getting quotes for.
I would error on the side of caution and not drive it.
flstffxe is offline   Reply With Quote
Old 06-26-2009, 03:23 AM   #4
CatchMyDrift
Member#: 54523
I decided to trailer it. Thanks for the reply's guys.
Old 06-26-2009, 11:53 AM   #5
OneBadPig
Member#: 181858
Good deal Bro
Is this gonna be a project car for you? Is it my imagination or do i smell a Cosworth 2.5 swap
Old 06-26-2009, 03:34 PM   #6
CatchMyDrift
Member#: 54523
Actually this car will be my daily driver / frankenmotor build. lol. I have various motors lying around to play with and I'll come up with something. Low boost for a while as this will be my first turbo subaru.
Thanks for the interest man.
Bad wheel bearing - how long can I drive on it Outback Jack Brakes, Steering & Suspension 14 05-24-2009 12:23 AM
Bad Head Gasket on '03 Subaru Legacy? paulkrueger Newbies & FAQs 3 10-01-2007 10:18 PM
Bad head gasket? JDMSUBAROO Service & Maintenance 1 11-12-2006 01:12 PM
Craked Block or Bad Head Gaskets Tattoo Collector Normally Aspirated Powertrain 16 12-05-2002 10:26 AM
Bad Head Gaskets again...... seowitz Warranty Issues & SOA Problems 2 11-12-2001 01:22 PM
