06-25-2009, 02:52 PM | #1 |
Member#: 128343
Vehicle:2002 WRX WRB |
Is it ok to drive the car with a bad ps pump?
The car is gushing out power steering fluid all over the engine from the reservoir but I need to drive the car to the mechanic. Is it ok for me to drive like that, will it cause any other problems? Should I just have it towed?
06-25-2009, 03:00 PM | #2 |
Member#: 174125
South East
Vehicle:2022 WRX WRB |
Just tow it. Fluid getting over the engine bay can cause problems, especially with any electronics.
06-25-2009, 03:04 PM | #3 |
Member#: 50301
NWIC
Vehicle:2004 BMW 330i |
Running a hyrdolic system with no hydrolic fluid generally = bad. I would have the car towed if you don't want to increase the damage that you already have.
06-25-2009, 03:06 PM | #4 |
Member#: 128492
HIIC
Vehicle:2002 WRX - Hybrid PSM |
you could always disconnect the pump and whatnot and drive without power steering. Someone correct me please if I'm wrong about disconnecting the pump. Maybe pull the power steering fuse? Look into it.
06-25-2009, 03:11 PM | #5 | |
Member#: 174553
Vehicle:2005 STi 360whp 345wtq on 93oct @ 20psi |
power steering is run off of a belt... to the OP, i would not recommend driving it like that as you could damage the rack depending on how much is "gushing" out and how far you have to drive |
06-25-2009, 04:52 PM | #6 |
Member#: 128492
HIIC
Good point, didn't think about that haha. But I know you can drive without power steering, so it'd just be a matter of how to 'disable' it I suppose.
Is it ok to track my car with a broken clock spring? | mikey88 | Autocross | 6 | 05-13-2009 04:58 PM |
Is it OK to drive a car without coolant? | Gerkins31 | Off-Topic | 17 | 02-25-2006 01:43 PM |
it safe to drive the car with this code P2096 Post Catalyst Fuel Trim System Too L | TampaSTI | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 2 | 07-21-2005 11:54 PM |
Last Followup: Is it ok to drive with the intake blockers off? | jodathmorr | Interior & Exterior Modification | 3 | 02-17-2004 09:14 AM |
Is it OK to drive in "3" with 4eat? | 02WRXman | Transmission (AT/MT) & Driveline | 5 | 11-17-2002 06:31 PM |
