#1 |
Member#: 172917
NESIC
Vehicle:2004 WRX WRB |
I seem to be loosing about 1qt of oil every 1000 miles. It doesn't seem like I am burning it. No blue smoke or strange odor and the oil on the dip stick looks pretty clean. No leaks either so I am not sure where it is going. Does anyone know where I should start? I already seafoamed the motor through the BPV hose to try to free up the oil control rings and put some in my oil with the last oil change. Any help? Thanks in advance.
#2 |
Member#: 767
Vehicle:04 FXT |
1 qt. per 1k miles is considered normal according to Subaru and many other manufacturers. Any chance you're running an Energy Conserving oil?
-Dennis |
#3 |
Member#: 172917
NESIC
nope, just regular dino oil
#4 |
Member#: 198861
SCIC
Vehicle:2004 WRX PSM |
well no **** theres your answer.
try using synthetic oil. |
#5 |
Member#: 140244
Vehicle:02 bugeye "stare ale jare" |
#6 |
Member#: 767
Vehicle:04 FXT |
You can use conventional oil without consumption, but you'll need something robust, IMO.
Try a High Mileage conventional or blend like Castrol GTX HM, Pennzoil HM or Valvoline MaxLife in 10W-30 or 10W-40. You could also try Rotella 10W-30 conventional if you can find it. -Dennis |
#7 |
Member#: 36540
BAIC
Vehicle:04 Silver GGA Cobb Stage 1 EQ Tuned |
Used 5w-30?
#8 |
Member#: 111219
Vehicle:2005 SWP LGT |
5W-30 is too thin, especially on hot summer days.
Try 5W-40, 5W-50, 10W-30. Works for me anyways and i usually run 5W-40 or 10W-30 all year round, depending which oil is on sale ![]() |
| Thread Tools | |
| Display Modes | |
| Loosing Oil UPDATED!!! PLEASE HELP | emsfd125 | Newbies & FAQs | 5 | 04-22-2010 09:22 AM |
| how much oil will i loose,?? have to remove oil filter again to tighten sndwch adapt | Dr. octagon | Factory 2.0L Turbo Powertrain | 5 | 12-28-2009 10:01 AM |
| Loosing oil... Low compression..? | mayhemsm | Factory 2.5L Turbo Powertrain | 1 | 03-29-2008 05:50 PM |
| Steadily loosing oil pressure, I may be in trouble here | Cation | Factory 2.0L Turbo Powertrain | 29 | 06-05-2007 02:50 PM |
| Car still burns oil. Need help badly. Oil catch can solution? | Andrew | Factory 2.0L Turbo Powertrain | 30 | 06-21-2001 05:00 PM |
