Old 06-25-2009, 05:45 PM   #1
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
Default has anyone drilled into the oil sandwich adapter for a gauge?
I'm currently running one half of an oil sandwich adapter for my oil temp gauge sensor since I don't feel like pulling my intake manifold to access the oil galley.
I need an oil cooler now though, so I was thinking about drilling an additional hole in the sandwich adapter to run the gauge sensor. Has anyone done this?
Thanks!
Ambert
verc is offline   Reply With Quote
Old 06-25-2009, 06:59 PM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
We use the galley plug for the low oil dash light for the sender. All you should have to pull is the alternator that way.
Turn in Concepts is online now   Reply With Quote
Old 06-25-2009, 09:18 PM   #3
mla163
Member#: 104922
2013 BRZ
Same. A friend of mine helped with the install and said this was the way to go. I got a remote oil pressure sending kit to shift around the sender.
http://fastwrx.com/reoilprsekit.html
mla163 is online now   Reply With Quote
Old 06-25-2009, 10:41 PM   #4
jamal
Member#: 71875
98 Legacy GT
my wheels fit
you can put senders in either of the top galley plugs without pulling the manifold. For the front one all you need to do is take off the alternator, and since you're installing a pressure gauge that little 2psi warning light becomes even more useless.
jamal is offline   Reply With Quote
Old 06-26-2009, 02:15 PM   #5
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
For the front galley you pull the altenator.
For the rear galley you pull the TMIC and move the recirc valve hose out of the way.
Done many pressure in the front galley and temperature in the rear galley and never once considered pulling the manifold.
turboICE is offline   Reply With Quote
Old 06-26-2009, 02:20 PM   #6
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I like the plug at the back of the #1 and #3 main galley. It'll show you the true pressure flowing to your heads and that is sustained across the oil galley. I really wish I could pick up 2/4 galley instead but the coolant crossover pipe blocks the rear of that one.
anyone drill into the EBAY fmic piping for meth kit? anthonyrb98 Water/Methanol Injection, Nitrous & Intercooler Cooling 5 05-19-2007 12:52 PM
Has anyone dipped into the 12's with stock WRX motor and turbo? silver arrow Proven Power Bragging 54 01-05-2005 04:01 PM
Has anyone packaged together a oil cooler kit for the WRX? BIGSKYWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 04-12-2004 06:39 PM
oil sandwich adapter for oil supply? Tigris Normally Aspirated with bolt-on Forced Induction Powertrain 7 02-02-2004 01:22 PM
Has anyone been to the NE District court for a speeding ticket? fubuki North West Impreza Club Forum -- NWIC 1 08-16-2000 07:41 PM
