Vancouver Impreza Club
Go Back   NASIOC > NASIOC Chapters > Vancouver Impreza Club Forum -- VIC > VIC Vendor Classifieds
Closed Thread
Old 06-25-2009, 07:32 PM   #1
dalesalignment&brake
Vendor Sales Rating: (47)
Member#: 173316
'13 BRZ
Default What we have in stock for June-
'04-09 STI-DTC 30, HP+ and HPS
HB453W.585 Hawk Brake Pads-$210
HB180W.560 Hawk Brake Pad-$185
HB453N.585 Hawk Brake Pad-$165
HB180N.560 Hawk Brake Pad-$130
HB453F.585 Hawk Brake Pad-$125
HB180F.560 Hawk Brake Pad-$85
'02-07 WRX-HPS and HP+
HB352F.665 Hawk Brake Pad-$95
HB434F.543 Hawk Brake Pad-$88
HB432F.661 Hawk Brake Pad-$95
HB452F.545 Hawk Brake Pad-$88
HB178F.564 Hawk Brake Pad-$98
HB179F.630 Hawk Brake Pad-$90
HB432N.661 Hawk Brake Pad-$142
HB452N.545 Hawk Brake Pad-$135
HB178N.564 Hawk Brake Pad-$142
HB179N.630 Hawk Brake Pad-$130
DBA Standard Slotted Rotors
STI-'04
654SL DBA Brake Rotor-$180ea
654SR DBA Brake Rotor-$180ea
655SL DBA Brake Rotor-$160ea
655SR DBA Brake Rotor-$160ea
WRX-'02-07
650SL DBA Brake Rotor -$155ea
650SR DBA Brake Rotor-$155ea
644SL DBA Brake Rotor-$140ea
644SR DBA Brake Rotor-$140ea
653SL DBA Brake Rotor-$150ea
653SR DBA Brake Rotor-$150ea
DBA 4000 Slotted Rotors
'02-07 WRX('06-07 rears only)
4650SL DBA Brake Rotor-$170ea
4650SR DBA Brake Rotor-$170ea
4653SL DBA Brake Rotor-$160ea
4653SR DBA Brake Rotor-$160ea
'05+ STI DBA 4000 slotted
42654SL DBA Brake Rotor-$205ea
42654SR DBA Brake Rotor-$205ea
42655SL DBA Brake Rotor-$185ea
42655SR DBA Brake Rotor-$185ea
05+ Legacy GT Front DBA slotted
42650SL DBA Brake Rotor-$160ea
42650SR DBA Brake Rotor-$160ea
DBA 5000 Slotted Rotors
'05+ STI(frt)-5654SLR DBA Brake Rotor-$975pr
Steel braided brake hoses-$120set
ATE brake fluid(Blue and Clear)-$16 ltr
I will match price with any Canadian vendor (pm me quote)
GD '04+ WRX, STI and '02-03 GD with '04+ rear strut tops.
"Blacks"-Regular Guy springs-$385
Introducing the RCE Regular Guy Springs (RCE Blacks), an OEM replacement spring for 2004-2007 Subaru WRX STi and the next in the Racecomp Engineering growing line of performance springs for Subaru Impreza, Subaru Legacy, and Mitsubishi Evolution. Designed for use with standard STi inverted struts or Ohlins Fixed Perch Replacement Struts, these springs are intended for both the daily driven street driver as well as the autocross and track day weekend warrior. Using similar spring rates as the extremely popular and successful RCE Yellow Springs, but having a much more subtle/mild drop in comparison, these are perfect for STi owners not looking for a ride height much lower then stock, and yet are still looking for increased spring rates. Spring rates are still 10% stiffer then JDM Pinks with an emphasis on the rear rate, so you will still be outpacing just about everything on the track and auto-x course.
"Yellow" springs-$385
The highly anticipated Super Sport Street/Track Springs, an OEM replacement spring for 2004-2007 Subaru WRX STi from Racecomp Engineering. Designed for use with standard STi inverted struts or Ohlins Fixed Perch Replacement Struts, these springs are intended for both the daily driven street driver as well as the autocross and track day weekend warrior.
Racecomp focused on improving on track and autocross performance, while maintaining acceptable ride quality. Extensive research, design, and testing was performed to develop a completely new spring unlike anything currently available. With springs rates increased approximately 25% stiffer then the popular JDM Pink Springs, the springs are perfect for those with wider tires worried about rubbing, as well those looking for a little more rear spring rate to promote a more neutral handling characteristic. Much care was taken not to exceed the limits of the stock struts. The mildly progressive design and spring rates properly matched with the dampers ensure that ride quality is not diminished over stock. The car is lowered 20mm in the rear and 23mm in the front for an even look
"Wagon"-$365
Finally, an option exists for Subaru WRX Wagon owners with upgraded struts! Rather then having to choose between spring rates that are too soft, like most wagon specific springs, and a saggy rear end, like most sedan specific springs, Racecomp Engineering is proud to announce an OEM replacement spring for the Subaru WRX Wagon. Designed for use with standard STi inverted struts, Koni Inserts, Tokico D-Spec struts or Ohlins Fixed Perch Replacement struts, these springs are intended for both the daily driven street driver as well as the autocross and track day weekend warrior. Using similar spring rates as the extremely popular and successful RCE Yellow Springs, but having a wagon specific ride height, these are perfect for wagon owners not looking to compromise either ride height or spring rates.
GRB Chassis('08+STI)-$405
"Regular Guy" springs
Finally, a performance spring designed with function over form is available for the latest Subaru Impreza STI. Incorporating the knowledge gained from designing a growing list of suspension and brake performance parts for the true track day and autocross enthusiast, Racecomp Engineering is proud to announce the latest addition to their line up. The Regular Guy Functional Lowering Springs for the 2008+ Subaru Impreza STI are designed as the ultimate performance spring upgrade for the newly redesigned GR chassis.
Paying special attention to the completely new rear suspension design of the GR chassis, the Functional Lowering Springs provide a mild 5mm drop front and rear to maximize the limited suspension travel available. Shorter bumpstops are included front and rear to take things one step further, resulting in more bump travel than stock. Rarely does an aftermarket spring set-up add suspension travel, but in this case it is a crucial design aspect that improves performance while helping to maintain a civil ride on the street.
Spring rates of 320 lbs/in front and rear are intended to work with the completely new rear suspension of the GR chassis, which has a lower motion ratio in the rear than previous Imprezas. In addition, the OEM dampers have been carefully examined on a shock dyno to match the new spring rates to the dampers.
Everything in stock.
'08+ STI and WRX
Front/rear swaybars
BSF30Z-22mm adj. frt
BSF30XZ-24mm adj. frt
BSF39Z-22mm adj. frt
BSF39XZ-24mm adj. frt
BSR49Z-20mm adj. rr
BSR49XZ-22mm adj. rr
Front and rear endlinks
KLC39-front adj.
KLC066-rear adj.
Front upper strutbars and lower stressbars
Front roll center kits, anti-lift kits and rack bushings
Rear camber kit, diff lock and subframe bushings\
04+ STi, 02+WRX, 2.5I sedan and wagon
Front/rear swaybars
02-03 2.5I
BSF10-22mm frt.
BSF11-22mm-wagon frt
BSR33XZ-24mm rr
02-03 WRX and wagon
BSF12Z-22mm adj. frt
BSF33XZ-24mm adj. frt
BSR33XZ-24mm adj. rr
04+STI
BSF36XZ-24mm adj. frt
BSR37XZ-24mm adj. rr
Front anti-lift kits, rack bushings, subframe lock bolts, outrigger bushings and roll center kits
Function:
• Infinitely adjustable within german TUEV-tested adjustment parameters
• Shortened struts for increased spring travel
• Trapezoidal threads for simple height adjustment
• Three different damping technologies for individual adjustment
• Elastomer bump stops with integrated dust boot protection
• Easy to read documentation
• Ready to use comprehensive solutions
• Visually perfect – safe and unique motion dynamics
Quality:
• Strut housings in inox-line stainless steel technology
• Anodized aluminum spring collars and add-on pieces
• High-quality, high-tensile racing springs
• Special ventilation and sealing system
• High-quality damping components
• Hardened, chromium-plated piston rods
• Special guide and sealing systems
• Pistons with V-shaped Teflon seals – optimal sealing with minimal friction – temperature-resistant, durable damping technology
KW V3 for GD STI and WRX-pm for pricing-in stock
KW V3 for '08+ STI and WRX-pm for pricing-in stock
H&R Coilsprings for '08+ STI
1''drop frt/rr.
I installed a set in an '09 STI and the rideheight looked awesome and it was very comfortable, works well with the stock dampers.
$399/set.
__________________
[CENTER][CENTER][SIGPIC][/SIGPIC][/CENTER][B][I][COLOR="Red"]"We do pricing a little differently. Every price you see includes the shipping cost to our office(Surrey, BC), duties and exchange rate . This creates a built in cost savings, no hidden fees, and less hassles. The best part is we still have a price match guarantee!"[/COLOR][/I] [/B]
[COLOR=black]Service Center: 604 530 9160 [/COLOR] [COLOR=black]Email- [/COLOR]
[/CENTER]
dalesalignment&brake is offline
Old 07-02-2009, 12:56 PM   #2
Member#: 173316
'13 BRZ
Pic of '09 STI with H&R coilsprings added.
__________________
[/CENTER]
Closed Thread
what choices do we have in dry panel filters? BIGSKYWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 09-16-2008 05:00 PM
What KW Vendors do we have in Central NJ? All Star Diaries Tri-State Area Forum 0 05-03-2008 10:20 PM
what we have here in OT Skell Off-Topic 44 12-24-2007 02:55 PM
What Kind of Exhausts Or Turbobacks Do We Have In Chicago? Red Rexx Mid West Subaru Owners Club Forum -- MWSOC 8 12-11-2004 07:38 PM
ok what next.....here`s the list of what we have and wondering what we need to do now wrextuner Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-07-2002 12:47 AM
