Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 06-25-2009, 11:32 PM   #1
sandman1011
Member#: 88476
Default Transmission fluid question
Yes, I know this would be an easy find if I had the owner's manual
What's the transmission fluid capacity on an AT 06 Sport?
Also, does anyone have any experience with Redline ATF? I like the Lightweight/75W90NS combo in the WRX, so I thought I'd try the ATF in the Baja...
sandman1011 is offline   Reply With Quote
Old 06-26-2009, 12:15 PM   #2
weiVA
Member#: 72942
2005 Baja T
Atl Blue Pearl
The below sounds right as my Turbo AT swallowed like 6-7 bottles of Redline. I'm satisfied with Redline. The fluid is still clear but I didn't really see any change in daily driving. I'll probably do my next change in Redline to use up my case then switch to something cheaper for the AT fluid change after that one.
According to http://www.amsoil.com/scripts/runisa...BAJA,SU,B,7539 , the Baja Sport:
CAPACITIES
Engine, without filter..........4.2 quarts
Cooling System, W/ AT Initial Fill..........7.1 quarts
Cooling System, W/ MT Initial Fill..........7.2 quarts
Automatic Transmission, Total Fill
4 speed TZ1A4..........7.6 quarts
Manual Transmission, ..........7.4 pints
Differential, Front..........2.5 pints
Differential, Rear..........1.7 pints
TORQUES
Oil Drain Plug.....33 ft-lbs
Manual Transmission Drain Plug.....51.6 ft-lbs
Last edited by weiVA; 06-26-2009 at 02:39 PM. Reason: clarified that these are specs for the Sport.
weiVA is offline   Reply With Quote
Old 06-26-2009, 12:53 PM   #3
sandman1011
Member#: 88476
Thanks!
PPG transmission fluid question -=Ice-T=- Transmission (AT/MT) & Driveline 3 07-28-2007 06:22 PM
Some transmission fluid questions TurboCharged97L Transmission (AT/MT) & Driveline 2 02-01-2005 09:25 AM
quick transmission fluid question wrigh003 Off-Topic 8 09-10-2004 08:37 PM
Transmission fluid question for you RS guys.... DrunkenMonkey Mid Atlantic Impreza Club -- MAIC 9 03-01-2004 12:10 PM
Dumb$%#@ me, transmission fluid question latinskllz Normally Aspirated Powertrain 1 06-03-2001 07:58 PM
