Welcome to the North American Subaru Impreza Owners Club Friday August 28, 2015
Old 06-26-2009, 09:05 AM   #1
brandonl
Member#: 3341
04 STi
track rat black
Default Pad knockback solved!
Im sure many of us have felt knockback before and have decided to just deal with it. Well I was tired of dealing with it, and doing wheel to wheel racing and having to brake hard from high speeds needing to trim 75-100mph with a car inches off both bumpers and having the pedal travel 3/4 to the floor is less than confidence inspring. Since AP, Alcon and other racing caliper companies use antiknock back springs from the factory in their calipers, I figured it was worth a shot. I found sets of 4 springs for 36.5mm+ pistons on HRP's site and they are only $6.90 per set. Calipers off and open, springs in and knockback is gone 100%. I ran my car on NJMP's lightning circuit yesterday and I didnt get even a hint of knockback once, when I typically felt it twice per lap. Go get em guys, thank me later
http://www.hrpworld.com/index.cfm?fo...action=product
Brandon
brandonl is offline   Reply With Quote
Old 06-26-2009, 02:23 PM   #2
Fred
Member#: 3560
06 STi, 02 WRXes
94 Open Light 2.5RS
I thought about getting a set of those for my STi when I had it. Ended up selling it first. How do they install? Does it cause the brakes to drag a little? If not, how does this work?
Good to hear from someone like you that they actually work.
Thanks.
Fred is offline   Reply With Quote
Old 06-26-2009, 02:26 PM   #3
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
yes, they do cause brakes to drag...it gave the spring rate in the link. 6 lbs IIRC.
Old 06-26-2009, 03:11 PM   #4
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Or you can left foot, tap, tap before you enter your braking zone. I just got used to it and I still have to tap with my 08 WRX. I sure don't miss having to do that on my 06 STi though
Element Tuning is offline   Reply With Quote
Old 06-26-2009, 03:13 PM   #5
grippgoat
Member#: 62182
2005 STI
6lbs is a drop in the bucket compared to what's exerted under even light braking, though, isn't it?
-Mike
grippgoat is offline   Reply With Quote
Old 06-26-2009, 03:24 PM   #6
brandonl
Member#: 3341
04 STi
track rat black
I do not feel a brake drag at all. A 6lb spring is so light it is hard to really explain without having felt one yourself. The force is not enough to really apply the brakes just enough to "reset" the pads into position should they shift away from the rotor surface. I can not say for a fact that they do not drag at all, I did not take any steps to measure the drag, but it honestly can not be felt at all. The car rolls across the floor just as it did before, there is no different feeling of resistance when you turn the rotors by hand either.
The left foot tap does work for sure, but I do not like to have to phantom brake check the guys behind me at speed. You are right Phil, NOT having to do it sure feels good.
Old 06-26-2009, 03:36 PM   #7
Astartes
Member#: 183813
2006 WRX TR OBP
WRX STi SGM
If they're dragging the only thing it'll really influence is the brake wear and it'll be minimal at that. If this is a track only set up brake wear won't really matter as you're changing them out often.
Astartes is offline   Reply With Quote
Old 06-26-2009, 03:48 PM   #8
brandonl
Member#: 3341
04 STi
track rat black
Dragging makes it sound worse than it is, whatever amount of drag there may be is nothing you will feel, and on a track car you will never see the difference in the pads service life. 6lbs of force at the pad is equal to an eye lash falling on the brake pedal... not literally, but its as minimal as minimal gets in comparison the force exerted when you actually apply the brakes.
Old 06-26-2009, 04:08 PM   #9
Homemade WRX
Member#: 33782
96 bastard child
-Mike
yes, the pressure isn't much but my concern would be more of wear and heat. Though I'm sure those would probably be minimal when you look at the grand scheme things...still makes for a higher pad, rotor and caliper operating temp.
true but wear items do add up...
We used springs in the formula car one year for the front and noticed some decent heat increase and pad wear.
Old 06-26-2009, 08:01 PM   #10
555ideways
Member#: 36652
For those who've actually experienced constant pad knock back weekend after weekend - it is a PITA and the tiny increase in pad wear/heat will be worth it.
-Paddy
555ideways is offline   Reply With Quote
Old 06-26-2009, 08:56 PM   #11
Fred
Member#: 3560
06 STi, 02 WRXes
94 Open Light 2.5RS
My temporary solution with my 04 STi was to adjust the brake pedal underneath the dash so that there was just a little bit of pressure/ dragging. Worked for all but the hardest cornering side to side at autoxes.
Old 06-26-2009, 09:01 PM   #12
iLuveKetchup
Member#: 66258
SCCA STU 05 STi #65
I get consistent pad knockback at the auto-x & its driving me crazy. However, I was at NJMP Lightning this past Sunday & I didnt get any knockback. Lightning is a very smooth rhythm based course. So I wonder if the knockback is gone because the course you tested them on doesnt produce much knockback? But I'll give these a try, for sure. Thanks!
iLuveKetchup is offline   Reply With Quote
Old 06-26-2009, 09:15 PM   #13
iLuveKetchup
Member#: 66258
SCCA STU 05 STi #65
Also, how are these installed?
Old 06-27-2009, 04:59 PM   #14
brandonl
Member#: 3341
04 STi
track rat black
I agree it is very much rythm based, but I know through turns 3, 4, 5 I generate enough cornering force to feel knockback at the brake zone for the left hander under the bridge. They are installed directly behind/under the piston in the caliper.
Old 06-27-2009, 05:18 PM   #15
Mykl
Member#: 14311
2010 GTI
I solved my pad knockback by installing '05+ parts on my '04. I almost sold my car over it.
Mykl is offline   Reply With Quote
Old 06-28-2009, 10:22 AM   #16
brandonl
Member#: 3341
04 STi
track rat black
In hindsight I would have done the same but I already have too much invested in suspension, brakes, and wheels to change the bolt pattern now.
Old 06-28-2009, 11:14 AM   #17
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
We have used them before and always had good results.
For those asking, you have to remove the pistons from the calipers and install the springs behind them.
Tony
Old 06-28-2009, 11:41 AM   #18
REX8
Member#: 24038
Which is a damn good idea to do anyway.
Old 06-28-2009, 02:30 PM   #19
Mykl
Member#: 14311
2010 GTI
Yeah, that's why I did it before I purchased anything. My '04 spec bearings were starting to feel dead after four hours of track time. I knew that I didn't want to have to go in and change them that frequently, so I just bit the bullet and went through with it.
Old 06-28-2009, 09:53 PM   #20
iLuveKetchup
Member#: 66258
SCCA STU 05 STi #65
I agree. Or if I would have researched more & found about the knockback, I would have just bought an 05.
Old 06-28-2009, 11:53 PM   #21
grippgoat
Member#: 62182
2005 STI
http://www.6gunracing.com/products.asp
2nd one down?
-Mike
Old 06-29-2009, 08:07 AM   #22
brandonl
Member#: 3341
04 STi
track rat black
I tried to go that direction Mike, I dont know whats up with 6gun... I tried calling, emailing and going through a distributor (TIC) with no luck. No returned calls or emails, and TIC said they didnt have any in stock and hadnt had luck getting any kits or a lead time on them.
Old 06-29-2009, 03:04 PM   #23
grippgoat
Member#: 62182
2005 STI
Oh well.
-Mike
Old 10-06-2012, 11:41 AM   #24
bossdog
Member#: 297370
2005 STi
Crystal Grey Metallic
I have an 05 I track. What makes the 05 better regarding Knock back?
bossdog is offline   Reply With Quote
Old 10-06-2012, 12:54 PM   #25
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Bigger better hubs.
Counterfit is offline   Reply With Quote
Pad knockback on '04 RS Grant Motorsports 10 01-14-2007 01:21 AM
2005 STi pad knockback? fourdegrees Brakes, Steering & Suspension 21 06-28-2005 12:35 PM
'05 STi owners/vendors/racers: pad knockback w/ the new 5x114.3 hubs/wheel bearings? gills Brakes, Steering & Suspension 15 09-17-2004 10:48 PM
Auto-X with pad knockback? Capt Crunch Motorsports 27 04-09-2004 10:47 PM
sti pad knockback milessport Brakes, Steering & Suspension 1 09-24-2003 10:53 PM
