Old 06-26-2009, 04:36 PM   #1
Ski4Ever
Member#: 51404
1999 OBS
Default Need help with installing replacement OEM rear springs on '99 OBS
Hi all,
The stock springs on my '99 OBS have sagged to the point where my fender wells rub a little going over bumps, etc. So, I've ordered/received replacement OEM springs and I'm wondering what all needs to be done to replace them. Is it as simple as the following?
  1. Jack up one side of vehicle
  2. Remove tire
  3. Remove strut assembly
  4. Compress spring
  5. Remove strut bolt and remove spring
  6. Install new spring
  7. Compress new spring
  8. Tighten strut bolt
  9. Put strut assembly back on the vehicle
  10. Put tire back on
  11. Lower vehicle
  12. Repeat above steps for other side
I was looking for info in another forum, and someone mentioned that I'd need to get an alignment. What would go out of alignment besides the camber? There is no camber adjustment, is there?
Thanks,
Matt
Ski4Ever is offline   Reply With Quote
need help with install on 09 wrx last lemming alive AccessPort 3 01-04-2010 08:55 PM
Need help with Glass Replacement...NOW BigJ04STi Tri-State Area Forum 8 02-02-2006 04:23 PM
Need help with installing gauges on A-pillar maxpower_454 Interior & Exterior Modification 1 07-06-2005 01:08 AM
Need help with install on used aps tmic hybrid gti 2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-14-2005 09:36 PM
DMS on the way - but need help with install knight North West Impreza Club Forum -- NWIC 7 12-20-2001 01:32 PM
