Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 06-26-2009, 04:45 PM   #1
Gonz#75
Member#: 101841
1998 2.5RS
mostly black
Default Tire options for ST?
What is the popular tire & size for a GC running in ST? I wanted to get the Dunlop star specs or the Hankook RS-2's but neither are available in the size I was looking for (225/45/16). I would rather run 16" wheels if possible but I can't find any information on other good ST options. Thanks
I'll be using 16x7.5 wheels BTW.
Gonz#75 is offline   Reply With Quote
Old 06-26-2009, 05:08 PM   #2
mofugga
Member#: 19540
2000 old skool RS
BRP
the rs2's should not be an option if you want to be competitive. take a look at the kumho xs instead.
noone makes a good st option in 225/45/16 so the next best size would be 225/50/16 if you're set on running 16" wheels.
mofugga is online now   Reply With Quote
Old 06-26-2009, 05:33 PM   #3
Gonz#75
Member#: 101841
1998 2.5RS
mostly black
So what is the competitive tire size in ST? I'm not a national kinda guy so I'm not worried about that and I won't buy a $200+ Advan tire. I really liked the Star specs on my STi.
Old 06-27-2009, 12:00 AM   #4
jeisen
Member#: 27258
who dat be dat was?
It doesn't matter. You will probably lose to a 1989 civic si.
I was running the RT-615's and just bought a set of the star specs to replace em. 225/45/17 on 04 sti wheels.
jeisen is offline   Reply With Quote
Old 06-27-2009, 11:25 AM   #5
testify
Member#: 196517
2007 n00b rocket
urban grey metallic
QFT!
Did you see a big difference going to the star specs from the rt-615's? I only ask because i am considering a switch.
testify is offline   Reply With Quote
Old 06-27-2009, 11:29 AM   #6
jeisen
Member#: 27258
who dat be dat was?
Won't get to try them out for 1-2 weeks. I'll post up my findings after the next event.
Old 06-27-2009, 01:00 PM   #7
Boxologist
Member#: 21118
a good driver will see a HUGE difference. a bad driver will under/overdrive both.
Boxologist is offline   Reply With Quote
Old 06-27-2009, 10:07 PM   #8
Gonz#75
Member#: 101841
1998 2.5RS
mostly black
I looked locally for that exact car before I picked up my RS. I've never auto-x'd a FWD car but I thought I would give it a shot. Oh well, my RS only cost me 2K. And now I'm spending twice that in upgraded parts.
I decided against the 16x7.5's I was going to get and now looking to see if it's possible to fit a 17x7.5 wheel under there. Anybody know if that works without rolling fenders or does it have to be 17x7? Can I just run more neg camber?
Old 06-27-2009, 10:39 PM   #9
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
With the negative camber and spring rates you should be running , you'll probably only rub "slightly" in the rear if at all. I have 225/50/16 on the stock RS wheels and with basically 0 camber it rubbed in the back, but not in the front. A quick fender roll later and it's fine now.
If you're going 17, definitely go for the 7.5 inch wide wheel, and light weight if you can. 225/45/17 in your flavor of choice (star specs, xs, re01-r).
subydude is offline   Reply With Quote
Old 06-27-2009, 10:52 PM   #10
Gonz#75
Member#: 101841
1998 2.5RS
mostly black
I've been trying to confirm if the 17x7.5 wheels will rub with the 225/45's. So you don't think it will?
Old 06-27-2009, 11:45 PM   #11
Splash
Member#: 55936
04 WRX STi
I know Rota has a 17x7.5 that is made for WRX wagons. Its slightly more than their normal et48 offset should clear GC fenders. Either way offset will be critical, as will the camber selection.
Splash is offline   Reply With Quote
Old 06-29-2009, 11:40 AM   #12
mofugga
Member#: 19540
2000 old skool RS
BRP
it all depends on your ride height and rear neg camber. i rub right now with 17x7.5 rota's and 215/45/17 kumho xs, springs are p1's and it has about -.8 for camber.
your best bet to make sure the 225's will fit is to roll the rear fenders
Old 06-29-2009, 11:16 PM   #13
DougM
Member#: 799
2000 2.5 RS Coupe
Mitsubishi EVO IX
i've run the starspecs in 225/45/17 on 7.5" sti bbs's (+53et). fits fine up front... and ok in the rear with -1' camber, coilovers and a fender roll.
615's, ad07's and ad08's also fit fine with the rear rolled (225/45/17)
this photo has the dunlops mounted up, and they're the widest 225's I've seen to date
DougM is offline   Reply With Quote
Old 07-19-2009, 06:52 PM   #14
Richard A.
Member#: 79
1999 2.5 RS
RBP
Best 16" tires for you might be the 225/45/16 Toyo R1R. Hankook may come out with that size later in the RS-3 which is supposed to be much better than the RS-2. I used to run 215/45/16 Azenis rt-215s on my GC8 and liked that size for tight courses and the new Kumho XS is available in that size and is a top performer.
Richard A. is offline   Reply With Quote
Old 07-24-2009, 12:46 PM   #15
mslstixx
Member#: 101387
2006 2.5i Wagon
RBP
As mentioned above the hankook RS-2's are not good, they get greasy FAST.
I was running RE-01's when I got some on sale.
I would look at
1. Dunlop Star Specs
2. Yokohama AD08 - which have amazing grip in the wet also, in case that's a factor
3. RE-11
4. Kumho XS
I know the first two are great tires, don't know much about the last two.
mslstixx is offline   Reply With Quote
Wheel/tire options for a 2009 Forester XT GodWhomIsMike Tire & Wheel 4 08-20-2008 11:24 PM
Any 17" rally tire options for the STi? MoDrift Tire & Wheel 10 10-08-2005 07:47 PM
tire options for '03 WRX wheels DP1112 Tire & Wheel 2 10-18-2004 09:37 PM
Best ST tire size for STi del105 Motorsports 13 04-27-2004 03:43 PM
tire options for 18 inch rims William LaPalme Tire & Wheel 2 11-24-2003 08:51 PM
