Old 06-27-2009, 02:22 AM   #1
05stiadam
Member#: 205929
2005 Wrx Sti
Default Timing belt help
i am changing my timing belt in a few days. anything i need to worry about? what precautions do i need to take? is there any special techniques i need to use to get it on or off? give me your 411 and tips on changing a timing belt. Thanks.
05stiadam is offline   Reply With Quote
Old 06-27-2009, 04:14 AM   #2
rolzrex
Member#: 85790
07 FXT 6-speed
Rally Blue
Have a friend help you.
Count and write down the number of teeth between the top dead center of crank gear and tdc of each cam gear (very important)
Be ready to empty coolant so that you can remove top radiator hose, you'll have much more room to work without that in the way.
Have a large allen wrench ready (dont know the exact size) so you can rotate each cam gear back to its proper location if it moves at all.
Find illustrated directions online and refer to them during the process.
Good Luck, its a fun one!
rolzrex is offline   Reply With Quote
Old 06-27-2009, 08:43 AM   #3
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
My tip is to read the sticky threads and post in the right forum, now that you are here, let's do that.
Old 06-27-2009, 09:04 AM   #4
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
^^^There are stickies to help.
You don't need to count teeth. All belts are marked for cam position. Other than that, you should replace all pullies and the water pump while you are in there. Don't forget to replace the tensioner as well.
Only somewhat special tool you'll need is a 10mm allen head socket.
Tony
Timing belt help - Off by 7 teeth after one cycle of belt rick-l Service & Maintenance 3 09-08-2008 04:21 PM
('93-'01) drive belts, idler pulley, timing belt help wanted!! down-n-dirty Impreza Forum 1 06-10-2006 09:27 PM
timing belt HELP photoman Normally Aspirated Powertrain 4 09-27-2005 11:43 PM
EJ20G Timing belt Help snowjob Subaru Conversions 7 04-28-2005 11:08 PM
Trouble changing timing belt...help. WRXTeamDFL Tri-State Area Forum 6 01-16-2005 01:54 PM
