Old 06-27-2009, 10:19 AM   #1
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
Default Does my log look ok?
I've yet to figure out my avcs issue so that may be why my IAM is at 8. Its a ver8 ej207 with jdm ecu.
i'm sure tweaks are needed because this is someone else's tuned rom that i flashed onto my car, but as far as i know they had stock intake, bcs, tmic, etc (like my car).
http://spreadsheets.google.com/ccc?k...ialeokuQ&hl=en
i swear i made this pull to 7k also, gonna have to do another log.
mods:
Ver8 tmic
vf37
stock bellmouth welded to 2.5" piping that has a 3" flange. THis meets a maddad 3"-2.5" midpipe which attaches to oem axleback piping w/aftermarket bullet muffler(its ghetto i know).
scoobystas is offline   Reply With Quote
Old 06-27-2009, 12:53 PM   #2
JSarv
Member#: 163445
l33t *******
[email protected]
no....
JSarv is offline   Reply With Quote
Old 06-27-2009, 08:16 PM   #3
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
is it safe to drive or "no, don't go more than 50% throttle," type of no?
can you elaborate? I think its just the cel causing the jdm ecu to run a different timing and fuel map. does that sound legit?
Old 06-28-2009, 09:13 AM   #4
indytruckboy
Member#: 192599
2004 STI
2007 Outback Wagon
looks to lean to me.....
indytruckboy is offline   Reply With Quote
Old 06-28-2009, 10:47 AM   #5
JSarv
Member#: 163445
l33t *******
[email protected]
The only time you need to drive it is to the tuner.
Or You can Give me your 207 longblock and call it a day, because essentially you are going to explode it very very very quickly...
I'm not trying to be rude, but the V8 TS ECU has REDICULOUS OE timing values that should never be ran on anything less than C16 fuel..
It needs a tune before its drove past .1% throttle again..
Your avcs needs tweaked, your timing is probably rediculous, it looks like you have a leak at or after the maf and before the turbo, and that makes it look like (or you really are) running very lean...
-Jerod
Old 06-28-2009, 04:53 PM   #6
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
Jerod,
everything preturbo is stock, i'm gonna wiggle and tighten the clamps, double check the maf.
The rom that is flashed on my car is not the oem jdm. Its a tuned rom from a well respected tuner in canada.
is there anythiing i can do to tweak it and make it safer to drive till i can get the tune?
I can see that this map really trys to bring on the boost early. the target boost is in the 20s very early.
Old 06-30-2009, 04:20 PM   #7
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
ok so i've download the stock 04 sti rom. I compared my rom to that one and the ignition timing and fueling and almost all the fields are identical. The only fields that seem to have been adjusted were the wastegate and boost.
I'm thinking i was misinformed when i was told that the rom i have was a tuned rom for the vf37 TS setup.
Now that we know the ignition base map and ignition advance tables are from the 04 sti, should that reassure me that its fairly safe to drive my car?
btw, i checked for leaks and everything looks tight before the turbo. Its all stock and fits like a glove.
Old 06-30-2009, 08:57 PM   #8
JSarv
Member#: 163445
l33t *******
[email protected]
You cannot run the timing that is in that rom. Not on anything but race fuel...
You need to talk to someone (clark tuner) to get a good safe I-Tune..
I don't know much about the 207's and AVCS or I'd help you.
-Jerod
Old 07-01-2009, 04:26 AM   #9
eminehart
Member#: 11205
2015 WRX
at first I thought your base timing was the total timing. You are probably running about 4-6 degrees too much timing. You can't compare engine loads on a 2L and the 2.5. The bigger engine will make bigger engine loads for similar pressure levels. That will throw off timing quite a bit. I really don't have any experience with the 207 either but I don't think 20+ degrees of advance at peak torque is a good idea. I would start with stock jdm ecu mapping of ignition timing and pull back from there. If you don't know what your doing, go to a tuner.
eminehart is offline   Reply With Quote
Old 07-01-2009, 11:31 AM   #10
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
thanks for the advice guys.
Old 07-01-2009, 07:16 PM   #11
JSarv
Member#: 163445
l33t *******
[email protected]
Have you seen a V8 rom? That is OE timing... They run stupid stupid stupid timing, and I think its basically designed for C16 fuel, but IAM decreases timing (while detonating) to settle at a lower grade fuel.
You need to have it protuned - end of story.. I really wish I could help, but I've never messed with a 207 and AVCS, in combination it is a very powerfull motor, but a tune will save you a bottom end or worse a shortblock..
Email Clark Tuner he knows alot about 207's and could probably get you a good starter rom right away - and you could go from there.
-Jerod
Old 07-01-2009, 09:20 PM   #12
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
I have an EJ207 and stock timing is aggressive - but they are tuned for 98RON fuel minimum (Pretty sure that is like 93MON in the US) and run VERY rich.
The EL207 ROMs also have fairly odd base and advance timing tables, in that there are peaks and dips everywhere in each (although generally a peak in base is matched to a dip in advance and a dip in base is matched to a peak in advance). I suspect this is done as further failsafe while under the fine learning or feedback correction startegies.
Anyhoo, if you run lower quality fuel, or have anything changed from oem EJ207 setup (ie, different intake, turbo, tbe etc) then you definately need to get tuned to suit - especially when you take into account the base timing table and how agressive the timing is if you start going beyond the general rpm and load points (by running different setup to stock).
Maybe start a thread over on the RomRaider forums, and attach your logs there for ppl to scrutinize. You want be able to post your ROM though, as it is someone elses tune. You will arguably be better of starting from scratch anyhoo and tuning for your mods.
Start from scratch, start with safe settings in your tune, and save your engine
Regards,
Leslie.
wrxsti.l is offline   Reply With Quote
Old 07-01-2009, 11:38 PM   #13
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
sounds good leslie.
At this point, just for the time being, i want to wait on a tuned map from clark because i've yet to figure out why my avcs isn't working. I've tried rewiring it several times and have an entire thread dedicated to it.
I currently want to richen up my a/f ratio because it is definitely not hitting the targets. At points where i'm at 11.32, i should be into the 10s (rich).
jared you mentioned intake leak. I can't locate it. If there's a leak post turbo, then I would not be hitting my boost targets right?
Since intake is stock, my maf scaling was also kept stock. Will pulling some timing out of base and advance maps give me the richer A/F ratios i need?
Old 07-02-2009, 02:17 AM   #14
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
How is your AVCS not working? Is it not working at all, just not following your AVCS table properly? If it is the later, that is a commong problem with EJ207 and there are a couple of things that can cause it and that need to be corrected. If it just simply doesn't function, then you will need to check over the complete AVCS system and make sure everything is installed correctly.
As for richening up your AFR to suit your targets, there really is no quick solution that I'd advise. You could do many quick solutions to richen things up, but whether they are safe or not is a different thing all together
The first thing I'd do to address your knock is remove some timing. Then when it isn't knocking, address your AFR, and then once AFR is hitting your targets add some timing back. This is very over simplified, and there are things you will need to know and understand to do this, but it is the direction I would take.
If you send me your ROM, I will make a few changes for you to limit that knock you are experiencing so you have a decent enough base tune so you can drive around safely.
Leslie.
Old 07-07-2009, 12:12 AM   #15
treystoys
Member#: 97436
05 Legacy GT
white
Listen to what Leslie just told you, or if your wanting to try something yourself to be safe, go into the total timing map, highlight the entire board, and remove 10 degrees from every cell. That'd give you a safe cushion for the 93 octane we use here. As far as the avcs goes, the stock avcs mapping will suit your set up fine. Getting the avcs to work, you have to have a jdm engine harness, and the corresponding wires correctly run to the ecu pins.
Trey
treystoys is offline   Reply With Quote
Old 07-07-2009, 01:27 AM   #16
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
10deg across the board may be a little too much. From around 2800rpm and load of 1.25 onwards I'd start by removing a couple deg. Then log a little more and if there is still knock rinse and repeat.
I'd definately be doing something until you have Clark tune it porperly - unless you are not going to drive it?
Leslie.
Old 07-07-2009, 02:09 AM   #17
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
I'm definitely driving it. I've removed some timing in the zones it has knocked before. At peak torque i'm running about 20 degrees. Not knocking anymore.
I can't figure out why i'm running lean though. The maf scaling is stock. Injector latency and scale are also stock. The AF ratio targets are only slightly leaner than stock.
i.e., at 5200 rpm and load of 2.75 i have a target of 10.81
Old 07-07-2009, 03:05 AM   #18
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
I didn't see WB02 data in the last log, so I'm not sure how you can tell how rich or lean it is running?
If you are looking at the stoock a/f sensor data, you should know it is limited in accuracy while in open loop and WOT. Also, it has a lower limit set in the ROM (your lower limit seems to be 11.32) and will not record any lower.
If you want to tune AFR, then you really need to use a WB02. You don't have to actually buy one, you could book an hour on a dyno and use their WB02 - and hour should give you more then enough time to sort out your fuel and your timing
Leslie.
Edit: Post a log of your current changes and wb02 data if you have it.
Old 07-07-2009, 05:07 PM   #19
paul_p1
Member#: 77372
2005 Spec C
WR Blue
Check your NPS is functioning correctly, AVCS won't engage if it's not working. Remember Subaru changed the polarity on the MY05 cars.
paul_p1 is offline   Reply With Quote
Old 07-08-2009, 01:34 PM   #20
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
the chassis is a usdm 03 and the motor is from a MY03 car so i don't think the neutral position switch thing applys here, right? thanks anyways.
i think the avcs not funcitoning has something to do with the wiring coming off the solenoids. their is alot of shady non-oem looking black electrical tap down there. When the tech installed my engine, prior to knowing anything about the avcs not working, he noticed it and said whatever was done wasn't by subaru.
Old 07-08-2009, 01:36 PM   #21
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
don't have the wb02 leslie, i'm really considering picking one up though. 150 on ebay shipped looks appealing.
BTW, i'm going to post a learning View screenshot later tonight but my closed loop fueling looks good. In field A, its rich by 1%, B and C are both lean by 1-2%, and D = 0.
Does this rule out a vacuum leak?
How do I read my Log? Does this log look OK to you? Knock? scottjua AccessPort 3 05-21-2009 04:03 AM
Does this log look ok? (2007 WRX, Stage 1) Overlord2kx Commercial ECU Reflashes 9 05-30-2007 05:24 AM
Do my logs look ok? LegacyGt05 South West Impreza Club Forum -- SWIC 14 04-27-2007 06:31 PM
How does this log look and say? Thugthizzle Engine Management & Tuning 3 04-01-2007 09:57 PM
do my logs look ok? jordanscotty Engine Management & Tuning 9 11-22-2005 11:06 AM
