Old 06-27-2009, 12:55 PM   #1
howweirdo
Member#: 186257
2008 obp GH
VF52 319/325
Default camber bad?
i just replaced my wheels and tires to a set that is the exact same size as my oem wheels. when i put the new ones on, i noticed that my rear wheels are cambered a little. (did i use that word the right way?) i have bc racing coilovers and my car is lowered, but not slammed. are my rear wheels cambered because my car is lowered? and is it really bad to have it cambered? how can i fix this?
howweirdo is offline   Reply With Quote
Old 06-27-2009, 02:01 PM   #2
grippy monkey
Member#: 131067
your "stance"
sucks
You should just take it in to get the allignment checked if you haven't. I wouldn't have them set it to stock camber setting though. I don't know what kind of camber adjustment if any that the rear of the newer WRX's have. I heard from a sedan owner there isn't any in rear.
Camber is not really bad. Camber is actual good if you have it dialed in correctly, but if you have loads of camber in rear and not in front your car will handle wierd. There is only extra wear on the tires with camber if it is extreme levels, which I doubt you have. I would have your camber set up with a little more in front. If you are running OEM fitment you can run almost zero camber in rear and little up front without fitment problems.
grippy monkey is offline   Reply With Quote
Old 06-27-2009, 02:11 PM   #3
howweirdo
Member#: 186257
2008 obp GH
VF52 319/325
yeah i had it aligned and balanced yesterday and the camber is still there. thanks for the tip though.
Old 06-27-2009, 07:48 PM   #4
cpunlamd
Member#: 151360
2007 STI RIP
2013 EvoX/2010 GTR
A set of $20 camber bolts can get your camber where you want it my friend.
cpunlamd is offline   Reply With Quote
Old 06-27-2009, 08:04 PM   #5
howweirdo
Member#: 186257
2008 obp GH
VF52 319/325
i read the sticky for camber bolts, but i just wanted to be sure of some things. will my camber be set back to or close to stock setting if i raise my car a little bit? and if i decide to go with camber bolts, is installation easy? it looks doable on the sticky but some things turn out to be way harder than they look. at least for me... i also found that whiteline camber bolts are $40 more than eibachs. is the main difference between eibach bolts and whiteline bolts simply the name brand? or are whiteline bolts that much better?
Old 06-28-2009, 12:45 AM   #6
northernwrx
Member#: 165099
2006 wrx
i understand you should get an alignment after you get new rims/tires. i am getting ready to buy a set of 18x7.5 with +48mm offset. i am wondering will my camber need to be adjusted so much that i will need to purchase bolts or will it be in the range of the car in stock form. i have an 04 wrx STOCK
northernwrx is offline   Reply With Quote
Old 06-28-2009, 12:58 AM   #7
Nicklz
Member#: 94096
2003 WRX
inside tire wear is usually related to toe out, NOT camber.
camber alone isn't bad, but throw in a little bit of toe and it eats the tires.
I run -2.9 in the front and you can barely tell the difference in inside and outside wear once the tire gets down to the tread bars.
When it is aligned make sure the toe is ZERO, not close to zero but ZERO.
No offense meant, but you need to read up more on coilovers and suspension and figure out the geometery of your suspension and how it works. Ecspecially since you have coilovers, they are pointless unless they are setup properly. (or slammed for looks)
~imo you should get the ride height where you want it, get it aligned by someone who knows what they are doing and leave it alone.
you may or may not need camber bolts on an 08 I have no idea...
Nicklz is offline   Reply With Quote
Old 06-28-2009, 01:00 AM   #8
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
but people that know nothing about suspensions and alignments should not be ****ing with such things
Old 06-28-2009, 01:01 AM   #9
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
there is SO MUCH stupidity out there about alignments that it is just stupid
Old 06-28-2009, 01:23 AM   #10
kursplat
Member#: 89528
2005 sti
crystal grey
did the alighnment place give you a print out with your settings?
if so post them then people will have an idea where to screw you up the most
good luck
kursplat is offline   Reply With Quote
Old 06-28-2009, 09:42 AM   #11
Daishi00
Member#: 78952
2005 WRX
CGM
who told you that?
Daishi00 is offline   Reply With Quote
FS: TXS FMIC, BOV, WL sways, camber plates, stock parts, brake hoses, more benton0311 MAIC Private Classifieds 21 06-12-2010 07:54 PM
Mega Bad News Izero Tri-State Area Forum 12 06-08-2010 08:29 AM
FS IL: ** SOLD ** 08+ STI Whiteline Camber Plates NIB JM530 Suspension/Brakes/Handling 11 06-04-2010 02:58 PM
bad toe kills tires not bad camber? wm07 Brakes, Steering & Suspension 5 04-18-2006 01:31 PM
bad camber problem enyce4u Brakes, Steering & Suspension 2 06-07-2002 06:54 PM
Message Board Statistics All times are GMT -4. The time now is 02:45 PM.
