Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 04-27-2002, 08:39 PM   #1
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Default Need serious help fast with brake pad/rotor issue.
I just put new cross drilled slotted rotors on my 2002 Wrx today. I purchased the new rotors from a guy on E-bay and I picked up a new set of pads from the dealer today. So the pads are OEM pads.
I did everyhing today. Feel the I did it right. However I took the car out tonight and I hear a slight squeel while I am driving and then when I brake say from 30 to 0 I hear this wierd noise that seems to be coming from the rear but could be oth front and rear. Sounds almost like those locost bugs. Sounds like the holes in the rotors are making a wierd noise.
Is this normal? Will it go away? Is it just due to the fact that the rotors and the pads are brand new? I am worried about what the problem could be. Can somebody please help me.....
Jasno999 is offline   Reply With Quote
Old 04-27-2002, 09:59 PM   #2
caino
Member#: 8700
2007 2.5i Wagon
Urban Gray Metallic
more than likely its just the pads vibrating slightly in the caliper....nothing major
go to your local auto parts store of your preference and pick up some brake goop...there's all different brands, all called different things.
bendix makes this blue ***** and some other companies make stuff too...it's normally blue and called brake quiet or something like that
take everything back apart and put it on the back of the pads where it comes in contact with the caliper..should solve your problem.
you get the squeal b/c the pads don't always fit 100% perfectly...especially on non-OEM brake pads.
caino is offline   Reply With Quote
Old 04-27-2002, 10:04 PM   #3
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
But I used OEM brake pads. The only non OEM thing is the rotor. And what about the odd sound that it makes whne I do apply the brakes? Is that normal for cross drilled rotors or is it somehitng that will go away or will always be there?
Old 04-27-2002, 10:08 PM   #4
romanom
Member#: 16215
2002 WR WRX wagon
Do the rotors have CD or Zn coating on the rotor surface? Are they those goldish colored type? That will squeal until it wears off.
OEM pads already have an anti-squeal pad on the back.
X-drilled rotors can squeal like that if the holes aren't drilled properly. As the rotor wears and the edges of the holes smooth it will go away. But expect more dust and worse wear.
http://www.i-club.com/forums/showthr...hreadid=168098
romanom is offline   Reply With Quote
Old 04-27-2002, 10:15 PM   #5
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Also Is there a reason why there are metal clips on all of the pads on the inner part of the caliper except for the left rear?
I noticed a small metal clip on one end of the pad that goes behind the rotor in the caliper. The front (both) and right rear had the metal clip but the left rear did not. Anybody know what that is all about?
Old 04-27-2002, 10:17 PM   #6
caino
Member#: 8700
2007 2.5i Wagon
Urban Gray Metallic
[/b]
oops....
my bad
didnt know subie's had that...
Old 04-27-2002, 10:34 PM   #7
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Thank you for the advice. I will let it go for now and see is the sound goes away. I noticed not loss in breaking or any real change. Jsut that I come to a bit of a quick stop from 2MPH to 0. But I think that is because the rotors and pads are so brand new.
The other thing I already noticed was that the silver rotor is alread black because of the brake pad wear. I mean it was nice and silver when I put it on but now it looks all black. Is this going to go away too?
Old 04-28-2002, 01:28 AM   #8
yellowrxo2
Member#: 13454
02 wrx
yellow
So they say about anti- squeal on OEM brake pads. Put more anti- squeal anyway preferrably the gel or tube type vs the spray ones.
Break them in as well
yellowrxo2 is offline   Reply With Quote
Old 04-29-2002, 08:46 AM   #9
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Ok I am going to try breakng them in for a week. But I noticed that it requires more force at the pedal to stop the car now. I hope this is just because the rotors need to be broken in. If not I have no idea what could be wrong.
Old 04-29-2002, 03:36 PM   #10
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
It does seem like it takes more force to stop the car now.
Is it possiable that I have air in my brake lines? Are you supposed to bleed the lines when you change the pads? If so how do you do it?
Old 04-30-2002, 06:32 PM   #11
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
AIR In the LINE???
Old 05-01-2002, 02:33 AM   #12
yellowrxo2
Member#: 13454
02 wrx
yellow
Always, bleed the lines for any pad replacements. Hope U know how , post if U don't. Best of luck
Old 05-01-2002, 06:42 AM   #13
romanom
Member#: 16215
2002 WR WRX wagon
Why? Please explain. Thanks
There is no reason to bleed from a pad change.
Old 05-01-2002, 07:04 AM   #14
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Yes most people are telling me that I should not have to bleed the lines but there are a few telling me that you need to bleed the lines after a pad change.
Can you guys please explain this to me. What should I do?
Suggestions needed on new suspension and brake pad/rotors. trail*of*dead Brakes, Steering & Suspension 10 11-14-2006 12:42 PM
Help!! My STI needs brake pads, rotors and labor big_furniture North West Impreza Club Forum -- NWIC 15 09-23-2006 01:34 PM
Can anyone help me with brake pad/SS lines install? Sputnik 5 Southern California Impreza Club Forum -- SCIC 1 07-11-2004 12:09 AM
Need help with Brake pad/rotor issue? Jasno999 Mid Atlantic Impreza Club -- MAIC 11 04-30-2002 09:57 PM
