Old 04-27-2010, 07:11 PM   #251
avk
Member#: 17252
'06 WX8
59E
The face of the seal should be at the bottom of the chamfer. With the crank seal, it means bottoming out in the bore, but not so with the camshaft seals.
avk is offline   Reply With Quote
Old 05-05-2010, 03:27 PM   #252
ibanez24_7
Member#: 192322
2002 Impreza TS
Excellent write up meat. Will save me a few bucks from havign to buy the manual. Liek I tell my friends if you can read you can work on your own car. Might ne a few special tools but it'll still be cheaper than taking it to a dealer. I plan on changing my timing blet, tensioner, water pump and seals. Pretty much every thing in there as my car has 113k and Im pretty sure none of that has ever been touched. Bought it with 55k. Got a quote from a dealership for $400 just to do the timing belt. All those parts alone will be around $500. Easy choice. There goes a saturday lol.
ibanez24_7 is offline   Reply With Quote
Old 05-05-2010, 05:31 PM   #253
geedar
Member#: 224617
03 WRX
6-sp. vf39
I just want to add that on my '05 WRX, the wire clips on the radiator are the push release type. I tried pulling the tabs for like 20 minutes before trying to push.
geedar is offline   Reply With Quote
Old 05-14-2010, 12:47 AM   #254
specialedd5
Member#: 209728
03 wrx wagon
black
after reading this, i think i may be ready to tackle this job. my 03 wagon is at 101,000 and it needs done, along with water pump. since i have to order everything from the parts store, should i order the timing belt guides, just in case? i have a weekend to do this project and im hoping it will only take a day. Im still a bit scared to do this job since im new to subarus, but it beats the $400 plus parts for someone else to do it.
specialedd5 is offline   Reply With Quote
Old 05-14-2010, 01:25 AM   #255
Rubr_Duky
Member#: 2159
2015 STi
I've done my fair share of wrench turning on little stuff. I'm not afraid to do my own struts/springs, change my own oil, etc. Don't ask me about auto electronics, but I've always been afraid of timing belts/chains. Even replaced an engine on my Nissan pickup ump-teen years ago, and timing belts scare me. Having a writeup like this saved me a butt-load of money, and gave me the confidence to change my own timing belt. While I was in, I replaced the tensioner, ALL of the pulleys (except cam) and water pump. My only regret, is that I didn't change the front oil seals on the cam shafts.
A strong bit of caution - splurge, and replace all of your pullers, idlers, and the tensioner. I paid damn good money for a mechanic to do this job at 60k, only to have to do it again at 80k because an idler bearing exploded on me.
Rubr_Duky is offline   Reply With Quote
Old 05-14-2010, 12:30 PM   #256
rick-l
Member#: 33868
2003 wrx
srp
Originally Posted by specialedd5 View Post
, should i order the timing belt guides, just in case? .
Do you mean the little metal tabs on MT cars? No
rick-l is offline   Reply With Quote
Old 05-14-2010, 03:23 PM   #257
o3WRXTC
Member#: 200856
1994 Legacy TSW
Red
just wondering if there's a cam gear lock tool like the DOHC honda's use?
like this (http://www.denlorstools.com/home/dt1...lock_tool.html.)
or has n e one made something that'll hold them in place?
o3WRXTC is offline   Reply With Quote
Old 05-14-2010, 09:23 PM   #258
geedar
Member#: 224617
03 WRX
6-sp. vf39
^^^ there is a Subaru special tool made for it though it's different. I tried to make one and it failed. Those bolts aren't playin'. I had all my weight hanging/bouncing on a 4 foot breaker bar and it didn't budge. Good luck with that one.
Old 05-22-2010, 01:07 PM   #259
specialedd5
Member#: 209728
03 wrx wagon
black
i put my 03 wrx in 3rd gear and went to loosen the crank pulley but it keeps turning. how do i stop this from happening, do i have to have the motor make a full rotation before it will stop so i can take the crank bolt out? Thanks
Old 05-22-2010, 01:49 PM   #260
specialedd5
Member#: 209728
03 wrx wagon
black
how do i get the crank pulley off, it keeps turning when i go to loosen it. is there a tool i need to do it?
Old 05-22-2010, 02:24 PM   #261
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
Go back about 5-6 pages in this thread and you'll see how to make your own tool. You can probably buy a factory tool but it'll be $75+. Another way is to use a chain wrench with a scrap of the old accessory belt between the chain the pulley so you don't bugger it up.
Or, at your own risk, you can put a breaker bar on the ground and on the bolt head and have the end of the bar on the ground on the ***RIGHT*** side of the engine while looking straight at the engine. Remove your ignition/fuel injection fuse(s). Then go to start the engine quickly to use the starter to loosen the bolt. Usually one quick pulse will do it.
09rexwagon is offline   Reply With Quote
Old 05-22-2010, 03:15 PM   #262
specialedd5
Member#: 209728
03 wrx wagon
black
Default cam pulley question
I have tried 3rd and 5th gear trying to get the cam pulley off, still can not stop it from spinning. Anyone have any ideas on how to stop it. Also im assuming that the bolt is not opposite threaded, if i could get some verification on that, that would be great as well. thank you
Old 05-22-2010, 03:17 PM   #263
specialedd5
Member#: 209728
03 wrx wagon
black
a buddy of mine just told me to try that, pretty scared tho, sounds kind of sketchy. im guessing if i had an impact gun it would work as well, instead of doing that whole starter thing?
Old 05-22-2010, 05:53 PM   #264
Subaru Voyager
Member#: 246773
Default Cant get the Cam Sprockets to Re-Align ???
Great write up & Pic''s Meatball !!!
Tell me what I'm doing wrong;
I have everything Aligned,
all of the Belt marks
sitting where they should be,
matched up with the Crank, Cam Sprockets
and the backing cover marks.
Teeth seem to be numbered correctly;
54.5 51 & the 28's I believe.
Cam sprockets aligned with the double marks next to each other.
All good so far, But... when I rotate the engine clockwise
(facing the front) the Cam Sprocket Never re-align again???
I've rotated the engine about four times too.
The marks all re-align
but the Cam Sprocket double marks Don't???
The only thing I can think of
is that I need to rotate the cam sprockets
the correct direction
to re- locate them first.
Cant find any reference to this problem
And I'm hoping you my have some insight on this problem.
Thanks !!!
JW...
Subaru Voyager is offline   Reply With Quote
Old 05-23-2010, 12:38 AM   #265
geedar
Member#: 224617
03 WRX
6-sp. vf39
^^^ I remember someone else posting about the same problem. It may have been earlier in this thread. I remember someone saying something about that happening with aftermarket cams, or sprockets, or a hybrid head swap (something to that effect). Maybe that will help you search for it. I found out the best way to search NASIOC is google " site:nasioc.com + your search terms ". This will google NASIOC only. It gives you more flexibility and search results than searching through NASIOC's search function. Yo can look up Google search tips and tricks to learn Google's other advanced search options.
Old 05-23-2010, 10:36 AM   #266
WRXDK
Member#: 187983
2005 WRX
I just did this yesterday. I put the car in 5th and had my buddy stand on the brakes. That bolt is tight, it is a regular lefty loosey bolt, I had to use the cheata bar. As for the cam bolts I used an old timing belt and vice grips to hold the cams from spinning. I think I read about using an old belt as a strap wrench in something from Cosworth. It worked awesome on 3 of the bolts. The LH intake did not co-operate.
WRXDK is offline   Reply With Quote
Old 05-23-2010, 03:09 PM   #267
04ImprezaWRX
Member#: 120237
2004 WRX
Ok so i just pulled my timing belt cover because I think my timing belt skipped. The main cam was at about 9 o clock so I tightened it to the correct 12/1 o clock so that the, timing mark on the cam matched the one on the block. Now how many complete 360 degree rotations do i make with this cam to tell if the timing is off? Thanks in advance
04ImprezaWRX is offline   Reply With Quote
Old 05-23-2010, 03:55 PM   #268
michael_lowery
Member#: 70392
2004 WRX Wagon
San Remo Red
Okay,
I've got a request for all the shade tree mechanics out there who have successfully completed this.
The write up and pictures are great for a basic timing belt change, and over on Clubwrx.net there are photos added which detail the water pump etc.
Seems however that lots of other people are replacing the crankshaft / cam shaft seals and there is plenty of written information on how to go about this, but has anyone happened to take any photos and document that part of the job?
I'd be interested to see the process before I dive in, and I've a sneaking suspicion I've got to replace them and oil is leaking from somewhere.
Any extra photos would be appreciated, maybe exactly how you make that awesome sounding jerry rigged strap wrench?
Thanks in advance.
~m
michael_lowery is offline   Reply With Quote
Old 05-24-2010, 01:20 AM   #269
Subaru Voyager
Member#: 246773
[quote=geedar;30808188]^^^ I remember someone else posting about the same problem. It may have been earlier in this thread. I found out the best way to search NASIOC is google " site:nasioc.com + your search terms ". This will google NASIOC only. It gives you more flexibility and search results than searching through NASIOC's search function.
Great Search Info !!!
Thanks !!!
Old 05-25-2010, 10:41 AM   #270
michael_lowery
Member#: 70392
2004 WRX Wagon
San Remo Red
Originally Posted by michael_lowery View Post
Okay,
Thanks in advance.
~m
Anybody have any pictures of this?!
Old 06-02-2010, 11:57 PM   #271
o3WRXTC
Member#: 200856
1994 Legacy TSW
Red
hi everyone,
i just did my timing belt.(i've done alot of honda timing belt's but it's my first subaru)
so here it goes, i just did the timing belt, line up all the timing marks on the belt to the mark's on the crank,cam's.
after lining everything up,pulled the pin out of the tensioner to set it.
spun the crank around to make sure thing's were fine. but as im spinning it to line it back up. i notice my timing mark's on the belt dont line up n e more. but all the marks on the crank and cam's still line up.( marks lined up as in page 1 post 2)
did i do something wrong?
(note: when i took my timing belt off my driver's side cam rotated)
followed the instruction's on which way to spin it and lined it up.
i dont know why my timing belt mark's are off now but the timing marks on the crank and cam's still line up.
like i said it's my first subaru timing belt.
but i imagine it's almost the same.
n e thoughts?
Old 06-03-2010, 01:33 AM   #272
04ScottWRX
Member#: 155412
2004 WRX Wagon
Lightbulb belt marks not lining up with cam/crank marks
Mine never lined back up either. I rotated the engine many times until sweat began to bead off my brow.....stress sweat!! and then i realized---As long as the marks all lined up to begin with...all the timing marks in their proper places lined up with the belt...the everything should line up mechanically later on after I rotate the engine (only in a clockwise direction). To make a long story short, the marks on the belt will only line up again after a few million turns (maybe-maybe not), but the alignment marks on the cams and crank will line up properly as long as the belt is installed properly--every time the engine is rotated notice the cam and crank marks lining up. There may be a slight discrepancy in the "dual" marks on the cams, but I also noticed that they didn't line up exactly even before the old belt came off!! It seemed like they were 1/2-1/4 a tooth off. Rest assured that as long as the marks on the cams line up in correlation with the crank, and there is no binding when you rotate the engine multiple times; Then you have completed the task.
04ScottWRX is offline   Reply With Quote
Old 06-03-2010, 06:44 AM   #273
Meatbawl
Member#: 175878
^this is correct.. I'll reword the write-up to avoid any confusion
Meatbawl is offline   Reply With Quote
Old 06-03-2010, 09:17 AM   #274
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
turn the crank 2 cycles and everything should line up.
BlackJavaPearl04 is offline   Reply With Quote
Old 06-03-2010, 12:17 PM   #275
rick-l
Member#: 33868
2003 wrx
srp
Correction: Turn the crank pulley 281 times and everything will line up again.
timing belt change steve_d Normally Aspirated Powertrain 5 12-04-2013 04:28 PM
changing the timing belt, change bearings or whole idler wheels/pulleys? NicEJ25 Service & Maintenance 15 12-28-2010 06:46 PM
inner timing belt cover guides madkayaker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-17-2010 10:34 PM
ok time for a timing belt change. speed_ga Legacy Forum 9 09-17-2008 11:19 AM
Timing belt change with seal change? file_id Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-09-2007 01:59 PM
