Old 04-02-2013, 01:23 AM   #576
1x2
Member#: 73564
2003 WRX
black-no wing no badges
Originally Posted by chenzonies View Post
you need a 5mm for the belt guide
Hey, thanks for posting- got one in my hex socket set. Good caution tip on your following post about the bolt thru the plastic rear cover, too. Glad your swaps worked out!
1x2 is offline   Reply With Quote
Old 04-24-2013, 12:33 AM   #577
Tiller35
Member#: 217006
I posted this in the video thread and I figured it wouldn't hurt to post here too...
I am having problems with the passenger side lower cam gear. Its not rotating by hand. Any suggestions of what can be done to make it rotate successfully or any knowledge of what could be wrong with it?
Its an 07 WRX and the engine was in working condition when removed last year.
Also, is the picture of the number of teeth in step 10 for 2.0L 2.5L or both?
Tiller35 is offline   Reply With Quote
Old 04-24-2013, 05:05 AM   #578
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
are the sparkplugs in the heads???
if so, take them out and see if there may be liquid in the cylinder
Old 04-24-2013, 10:11 AM   #579
Tiller35
Member#: 217006
thank you for the reply. I will be home tomorrow and I can check then. What does it mean if there is or is not liquid in the cylinder?
Old 05-08-2013, 05:25 PM   #580
Jarrod164
Member#: 253937
1995 WRX
I read through the first few pages and last few but I still have some questions!
I'm strictly looking at removing the oil pump to replace the oring and re-seal as I think this is the source of my oil leak. When everything is lined up and the belt is removed, I'm supposed to remove the crank bolt. Will this not move the pistons and is there cause for concern of hitting valves? Or are all the valves closed and I should not to worry about moving the crank at all. Or am I supposed to clamp the sprocket and then loosen the crank bolt?
Also in the video, all the idlers are removed, I assume this is because they are being replaced. As I said, just looking at getting to the oil pump, can I leave most idlers on (aside from maybe the one with the pin that should be compressed)?
Thanks for any help!
Jarrod164 is offline   Reply With Quote
Old 05-28-2013, 03:56 PM   #581
dLo R6
Member#: 108719
2004 VF39'd WRB WRX
2003 Honda CBR600RR
Someone correct me if I'm wrong, but since you should have already aligned everything to TDC before taking off the belt, it shouldn't be an issue since all the valves will be closed.
dLo R6 is offline   Reply With Quote
Old 05-28-2013, 03:58 PM   #582
dLo R6
Member#: 108719
2004 VF39'd WRB WRX
2003 Honda CBR600RR
THANKS MEATY for this DIY. it saved me $600 in labor and was a hell of a lot easier than I had expected. at 115k miles it turned out my timing belt was still perfectly fine (still replaced it) but i hadn't checked my accessory or AC belts in some time and man those ones were dying.
Overall if I could give you some e-form of props I would.
Old 05-29-2013, 05:14 PM   #583
ripman
Member#: 305707
1999 WRX
WRC Blue
Is it ok to hold those drivers side cam pulleys in place with some vise grips with just enough tension on them when you remove the old belt?
ripman is offline   Reply With Quote
Old 05-30-2013, 01:42 AM   #584
recce02
Member#: 13815
02 GCRally prepped
277TQ 281HP 19PSI
You can... but a better tool would be a padded sprung clamp. Think of an automotive chip clip.
recce02 is offline   Reply With Quote
Old 05-30-2013, 10:50 AM   #585
tominator19
Member#: 296801
2008 OBXT 5MT
BLACK
Dude, just don't do vise grips. Don't risk doing what I did. Look at post # 548. I thought they had "just enough tension on them" and, for about 3 minutes, they did. Then the gear just spontaneously broke without me touching anything.
tominator19 is offline   Reply With Quote
Old 05-30-2013, 04:13 PM   #586
ripman
Member#: 305707
1999 WRX
WRC Blue
Thanks. That is very good to know.
Old 06-03-2013, 04:15 PM   #587
Hans Moleman
Member#: 16775
Last year I changed the timing belt using this guide. Before removing the timing belt, when I aligned the cam gears, the bottom gears wouldn't line up perfectly to the notches on the back timing cover and the upper cam gears. When I installed the new timing belt, I aligned everything to the marks on the new timing belt and the engine ran perfectly.
Now I have to take everything apart again because the oil pump is leaking. I guess I didn't re-seal correctly so I have to do it again. I want to re-use the timing belt because it's still pretty new. But since I can't align the cam gears perfectly before removing the timing belt and the marks are gone from the timing belt, what is the best way to do this?
Hans Moleman is offline   Reply With Quote
Old 06-03-2013, 04:20 PM   #588
RP31
Member#: 123574
2005 stuck-in-garage
CGM STi
When I was in a similar situation I just marked the spot on the belt where it met the crank gear at TDC, and did smaller marks for reference at all of the points on the cam gears. Pulled it off, and then counted teeth for all of the positions using the image on the first page, and drew them back on with a marker.
I have never counted something so many times repeatedly. In the end it worked just fine.
RP31 is offline   Reply With Quote
Old 06-03-2013, 06:29 PM   #589
rick-l
Member#: 33868
2003 wrx
srp
I could still see remnants of the marks on my OE belt when I changed it. Find one mark and then find the others / verify it by counting teeth according to the service manual.
http://forums.nasioc.com/forums/show....php?t=1587945
rick-l is offline   Reply With Quote
Old 06-05-2013, 03:20 AM   #590
my0six
Member#: 341826
2005 WRX MY06
Light Bluish Silver
Hello all. Just spent the last three days reading this whole thread, looking forward to getting started.
Has anybody had any joy sourcing these parts cheap for Australia?
I spoke to the stealership and WOW, they're ambitious folk!
my0six is offline   Reply With Quote
Old 06-28-2013, 01:59 AM   #591
dustingwhale
Member#: 275346
05 FXT
Is it, put it in 3rd gear w ebrake and brakes depressed?
Should the spark plugs be removed? Is it difficult to turn the crank w them in and a long enough cheater bar?
I did the tbelt on my aba VW, easy but a pita access wise - looks like tons of space w the radiator removed on these. Thanks in advance for the write up!
dustingwhale is offline   Reply With Quote
Old 06-29-2013, 04:55 PM   #592
dustingwhale
Member#: 275346
05 FXT
stuck on crank bolt removal.
05 xt manual
3rd gear
wife standing on breaks
breaker bar w cheater
lefty losey
the crank walks back slightly
can't get it off
pissed. What am I missing? Isn't this only to 90fy lbs?
Old 06-29-2013, 05:08 PM   #593
Mr. Me
Member#: 193598
2002 Bugeye Wagon
Put it in 5th. Ebrake on and stand on the brakes. Worked on my 02
Mr. Me is offline   Reply With Quote
Old 06-29-2013, 06:05 PM   #594
LCredit
Member#: 343500
06 WRX STi
Are you wheels on the ground?
LCredit is offline   Reply With Quote
Old 06-29-2013, 06:20 PM   #595
dustingwhale
Member#: 275346
05 FXT
The back wheels, front is on stands..
Taking a BBQ break, thanks for the help
Old 07-03-2013, 06:06 PM   #596
kbobomber89
Member#: 231418
2006 WRX
I work at a used car dealer and just wanted to say thank you for this walk through. Did my first timing belt on a 2002 wrx today and this helped a lot.
kbobomber89 is offline   Reply With Quote
Old 07-03-2013, 09:14 PM   #597
AndersH04
Member#: 333883
2004 WRX STI
JBP
Hey I'm in need of some help guys doing water pump and timing belt.
I've taken the belt off and on several times trying to make all the marks line up and ended up getting everything to match as close as possible.
Once I got it to as close as I thought I could I pulled the pin and now its off by a few teeth
Should I redo everything to make it line up more?
Or just put it back together and see if its okay?
AndersH04 is offline   Reply With Quote
Old 07-04-2013, 07:24 PM   #598
my0six
Member#: 341826
2005 WRX MY06
Light Bluish Silver
Hey lads, can anybody point me in the direction of a guide to changing the cam / crank seals???
I've been searching for weeks now, have all the parts on the way, looking forward to this
Old 07-09-2013, 07:34 PM   #599
johnblahuta88
Member#: 221614
So I just pasted 60k and I checked the timing belt. The teeth look good and the belt has no signs of wear at all. What is a safe mileage to replace it. I have a 04 sti and only put 6k miles on it a year. Any advice will be very helpful.
johnblahuta88 is offline   Reply With Quote
Old 07-09-2013, 07:36 PM   #600
johnblahuta88
Member#: 221614
Get the crank off by having one person prying a breaker bar against your ac compressor and have someone slightly tap the ignition. It worked for me. It's a little dangerous but it worked fine. Just toke a little bump and the bolt loosened right up.
timing belt change steve_d Normally Aspirated Powertrain 5 12-04-2013 05:28 PM
changing the timing belt, change bearings or whole idler wheels/pulleys? NicEJ25 Service & Maintenance 15 12-28-2010 07:46 PM
inner timing belt cover guides madkayaker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-17-2010 11:34 PM
ok time for a timing belt change. speed_ga Legacy Forum 9 09-17-2008 12:19 PM
Timing belt change with seal change? file_id Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-09-2007 02:59 PM
