Old 11-05-2009, 01:11 PM   #101
jstalford
Member#: 175819
2006 Rav4
I'm thinking of doing this soon too. FYI, that seller is now using Gates Blue Belts.
jstalford is offline   Reply With Quote
Old 11-05-2009, 01:48 PM   #102
MConte05
Member#: 158579
2005 Lotus Elise SC
94 Legacy Rally Car
Just wanted to say thanks to Meaty. I did my Timing Belt and idlers and such a month or two ago and followed this guide in conjunction with the Service Manual. Was a tremendous help. Thanks!
MConte05 is online now   Reply With Quote
Old 11-05-2009, 06:03 PM   #103
Meatbawl
Member#: 175878
They sell the kits with the OEM Mitsuboshi belts too.. the Gates Blue belt is an option for a bit more $
You're welcome.. can't wait to revise it and shoot the DIY video for this sometime soon..
Meatbawl is offline   Reply With Quote
Old 11-09-2009, 05:43 PM   #104
REXlover02
Member#: 192338
2005 sti
wrb
Default Cam pulleys
There was a question about aligning the cam sprockets before removing the timing belt earlier in this thread. I can say there is but u gota do it carefully, where each sides cam sprockets meet at 6 and 12 o'clock u can get 2 pairs fo vice grips and lock them on each pulley(where the double lines meet up). What i did what get the vise grips and put electrical tape on the teeth so they diden't scratch the sprockets. It works really well im sure you could do it without tape but i dident want to srcatch them all up.
REXlover02 is offline   Reply With Quote
Old 11-10-2009, 05:27 PM   #105
JaredG
Member#: 56093
2005 WRX
wrb
More thanks to Meatbawl for a great guide! I just used it to put a timing kit on my 2005 WRX and it worked out great. The only thing I noticed is that the electric fan connectors on my 2005 require you to push the retaining clips inward to release instead of outward like the instructions said. Maybe they made a running change sometime.
I also used that mitsuboshi kit that Meaty mentioned. It seemed like good quality components. No complaints.
Thanks.
Jared
JaredG is offline   Reply With Quote
Old 11-18-2009, 09:24 AM   #106
elshankos
Member#: 230140
1998 Legacy GT-B
Dark Blue
Hi there, Im a newbie!
So sorry if my questions are answered somewhere else or if they're seemingly daft!
Ok, so Im living in Japan and I've recently bought a 1998 3rd Gen. Legacy GT-B with 125k km on the clock. Engine: EJ20, BH5 -. Can I even ask questions here?!
Ok so I have a squeaky bearing going on somewhere within the timing belt assembly - probably the tensioner - both the dealer and I agree on this. However I dont understand the rest of what he's on about (my japanese is rubbish) and I dont want to pay some $500 (labour only) for him to replace it.
Question 1: do you think I could use this help on a legacy - is the timing belt set up pretty similar? It looks the same and I could use some info for torque specs from the Hayes guide I have.
Question 2: do you recon its worth it to replace the pullies/ other bearing parts in the assembly while I'm in there.
Ive worked on all sorts of cars with assorted not-so-big problems and Im an electrical engineer so Im quite handy but Ive never done a timing belt change so I really appreciate any help you have!
Many thanks.
Stephan
elshankos is offline   Reply With Quote
Old 11-18-2009, 01:45 PM   #107
Meatbawl
Member#: 175878
I don't know much about your 98 Legacy, but this information was identical for my 98 forester when I did a rebuild on it a few months ago. I recommend replacing ALL bearings, tensioner, idler pullies, and belt with new when doing the timing belt. Especially if you already have a bearing squeaking, you're bound to have to do it all over again soon if you don't change them. Even if your Legacy differs slightly behind the timing covers, the concept and procedure should be very similar, if not, identical to this one. Post up any questions you have if you decide to do it. I'm sure myself, or someone else on here will be able to help
Meaty
Old 11-22-2009, 12:12 AM   #108
costelino
Member#: 230717
hi im new to this forum can somebody help me with my new bugeye i got ,,,the car was involved in a flood and it got bunch of gunk in the belt compartment and i think it skipped a few teeth so it wouldn't start now im trying to install a new timing belt but i cant seem to get it right ..oh by the way its a 2002 2.5 sohc ,,what mark do i use off of the crank sprocket? and does the motor have to be TDC? when you put the timing belt on.
i put the TB on and i got no compression in 1 and 3 cylinders???
costelino is offline   Reply With Quote
Old 11-23-2009, 07:31 PM   #109
Meatbawl
Member#: 175878
Match up the pulley marks with the diagram I drew up on the main post of this thread. It may take turning the motor quite a number of times until they all line up. Look at the picture of the crank sprocket that I posted in the main post that has the red circle showing the two marks that need to line up. Placing the crank sprocket at that mark is TDC. If you are dealing with a flood car, you may want to swap out all of the bearings and probably the tensioner as well as the water could have rusted them and even ruined them.
Old 11-23-2009, 09:20 PM   #110
costelino
Member#: 230717
hi i did just that and what im seeing is that the piston is down or in- not out TDC???? and i did get all the idler pulleys and water pump and tensioner new from the dealer got a really good deal from the subaru dealer here in renton .
is there a way that the cam shaft is out of timing on that side of the engine just thinking out loud here???
Old 11-24-2009, 11:34 AM   #111
rick-l
Member#: 33868
2003 wrx
srp
I'm not sure the piston is at TDC with the belt in the changing position. Look at page ME-3 of the service manual volume 8
**: The #1 piston is set at TDC on the compression stroke when the piston-position mark on the camshaft sprocket is facing directly upward
those arrows are not the alignment marks
rick-l is offline   Reply With Quote
Old 11-24-2009, 12:29 PM   #112
costelino
Member#: 230717
yea im not going by the arrows , i think i did everything right that meaty said ,,and im still not getting any comp. any chance theres valve damage i thought that these SOHC engine are not interference engines????
and is there a way to test for valve damage without taking everything apart?
ive been hearing about a leak down test will that work???
Old 11-29-2009, 09:59 PM   #113
Bugstiwagon
Member#: 189680
02 WRX Wagooon MBP
06 Lan Evo IX WW
Might be a stupid question but how do you tell the difference between bending the valves and the cams going into lift when you trying to align the drivers side gears? Is there any way of seeing if you indeed did bent the valves or if the friction is just normal lift without starting the car and it running the engine? Also maybe on the main write up page maybe listing the oem part numbers could really help, cause for the do it yourselfer finding the oem parts on say subarugenuineparts.com is kinda difficult. Great write up!! I hope my engine is ok, im probably just paranoid cause this was my first one lol..
Bugstiwagon is offline   Reply With Quote
Old 11-30-2009, 01:35 AM   #114
rick-l
Member#: 33868
2003 wrx
srp
I go here to look up parts.
http://opposedforces.com/parts/impreza/us_g11/type_3/
Old 11-30-2009, 08:49 PM   #115
Meatbawl
Member#: 175878
I'll add the part numbers to the thread when I have a little time to look them all up. I think it takes quite a bit of force in the wrong direction to actually have a valve get bent. I don't think the engine going into "lift" mode has the necessary force or ablity to bend them. This, of course, is my opinion. I have had them try to spin in the wrong direction on their own when lining them up and never had a bent valve.
Old 12-02-2009, 11:52 PM   #116
costelino
Member#: 230717
update on my little problem with the timing, i took the head off and i see i have 4 bent valves and thats why i got no comp. on 1&3 now im wondering why it bent the valves since this engine is not a interference engine??? any ideas
Old 12-03-2009, 01:15 AM   #117
04ScottWRX
Member#: 155412
2004 WRX Wagon
on a SOHC the valves don't interfere with eachother, but the pistons interfere with the valves. If there was a skip tooth on the pass side then there would be interference with the pistons on that side only. If its a flood car I would at least rebuild the engine. Hell, if you have the heads off you're half way there anyway. It would be worth your while to spend a few hundred smackaroons on rings, bearings, some new valves, some special tools, and a gasket kit--well probably 8-9 hundy including all the machine work....you might be able to do it for 7 if you know people. good luck dude!
04ScottWRX is offline   Reply With Quote
Old 12-05-2009, 12:36 AM   #118
squeethebee
Member#: 115849
1994 Impreza L wagon
1997 Impreza OBS
Did almost all of this tonite, finishing up by installing the belt tomorrow, I just wanted to say thanks for the write up, the direction to spin the cam gears was especially helpful.
I found using a large t-handle allen to turn the driver's side gear (only my exhaust spun, hopefully the intake doesn't when I go to install belt) makes it so much easier, and greatly lessens the chance of catching fingers, or the gear slipping out of your hands and having to have to redo it. Would never do it without one of those again.
ed
squeethebee is offline   Reply With Quote
Old 12-05-2009, 02:33 AM   #119
elviking
Member#: 182656
2007 2.5i
1 Black, 1 Blue
Thanks for the write up. Seems fairly 'simple' but a pain in the rear.
elviking is offline   Reply With Quote
Old 12-05-2009, 02:57 AM   #120
squeethebee
Member#: 115849
1997 Impreza OBS
It's pretty straightforward, just time consuming.
ed
Old 12-09-2009, 10:05 PM   #121
sti_95imp
Member#: 53774
1995 Impreza
Dirty.
Originally Posted by Meatbawl View Post
I've never heard this, and would think it's a myth or incorrect information. I would guess they meant advancing the timing via the tune or something, not by skipping teeth on the pulleys I think you're better off doing a TGV delete or exhaust/intake mod for a safe 5-10+HP instead. Anyone else able to shed light on this?
Thats Old school honda stuff. I wouldnt do it to a WRX...
sti_95imp is offline   Reply With Quote
Old 12-10-2009, 11:13 PM   #122
cbean
Member#: 57387
02 wrxwagon
awesome post! Thank you Meaty...getting ready to do this on mine, this post is exactly what I was hoping to find
cbean is offline   Reply With Quote
Old 12-11-2009, 03:01 PM   #123
CharT
Member#: 36117
2003 WRX Wagon
Another big THANK YOU to Meaty for this guide. I finished my timing belt change last weekend and everything went smoothly. The car started up and idled fine.
One issue I ran into was the replacement idler 13073AA200 needed a shorter bolt (808208320 BOLT-8X45X22) than what was on the car. It's the same problem as mentioned in this post.
Besides that, the hose fitting, on the engine side, for the upper and lower radiator hoses had a lot of mineral deposits that were difficult to clean off. I have a slight leak at my lower radiator hose fitting that I need to remedy. I reused the stock clamps and tighened them "good and tight" with a 1/4" rachet. It's leaking at a rate of 1/2" per day in the coolant overflow reservoir. Any ideas that don't involve draining the coolant? I'm going to try cranking down on the hose clamps again.
CharT is offline   Reply With Quote
Old 12-15-2009, 07:49 PM   #124
Meatbawl
Member#: 175878
Thanks for the info, and your welcome on the writeup
Try double-clamping the hose. Fit two clamps as close as possible on the thermostat (or radiator, wherever it's leaking). I've done this myself with success. You might have a small tear in the rubber hose, so I recommend replacing your hoses anyway if you're still using the OEM originals. I have really taken a liking to silicone hoses
Old 12-16-2009, 10:28 AM   #125
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Nice write up...
rexworx is offline   Reply With Quote
timing belt change steve_d Normally Aspirated Powertrain 5 12-04-2013 04:28 PM
changing the timing belt, change bearings or whole idler wheels/pulleys? NicEJ25 Service & Maintenance 15 12-28-2010 06:46 PM
inner timing belt cover guides madkayaker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-17-2010 10:34 PM
ok time for a timing belt change. speed_ga Legacy Forum 9 09-17-2008 11:19 AM
Timing belt change with seal change? file_id Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-09-2007 01:59 PM
