Welcome to the North American Subaru Impreza Owners Club Friday February 5, 2016
Old 06-28-2009, 12:38 AM   #1
kato4276
Member#: 162641
2004 PSM WRX
New engine in the works
Default FP HTA GT35 Turbo
Is anyone running either the HTA GT3586R or HTA GT3582R on the 2.5L? I want to save up for a rotated setup and i have not seen much info on these turbos ...
kato4276 is offline   Reply With Quote
Old 06-28-2009, 02:36 AM   #2
ASU
Member#: 164551
2006 Brotastic STi
Land of beer and laws
Some people like them others think they are bogus. I for one don't know to much about them and have no opinion on them.
ASU is offline   Reply With Quote
Old 06-28-2009, 02:38 AM   #3
fourZero
Member#: 117926
2006 STi
Why even reply then?
For that matter, why am I replying to you?
fourZero is offline   Reply With Quote
Old 06-28-2009, 10:46 AM   #4
06mattsti
Member#: 174796
2006 STI
^ lol. PM Im_Slow. He just recently put his fp hta 35r rotated kit on. Made around 420whp on pump with stock motor. 515whp on Q16, again stock motor. With a bigger fuel pump and a built motor, its easily a 600whp car. He loves the turbo. Pm him.
06mattsti is offline   Reply With Quote
Old 06-28-2009, 12:34 PM   #5
Racer_X_X
Member#: 141804
'98 RSTi HTA86 AEM
'02 35R-Nürburgring Cert.
I have the 86 on my car. I like it. I dd my car about 160miles a day too.
I don't think it has that much lag, but just my opinion.
I sure do like it.
Racer_X_X is offline   Reply With Quote
Old 06-28-2009, 02:05 PM   #6
ASU
Member#: 164551
2006 Brotastic STi
Because all the fan boys will reply, I though the op should know there is a part of the Tuner community that thinks this is a marketing scheme.
Old 06-28-2009, 07:36 PM   #7
ScorpionT
Member#: 195677
The HTA stuff is nice for sure, but pricey. The 82 is a better choice if you arent planning for 600whp, the reason being its slightly less expensive and spool is better.
ScorpionT is offline   Reply With Quote
Old 06-29-2009, 12:26 AM   #8
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
i think "The Shop" did a test with a reg gt35 vs HTA...iirc they made 10-20 more hp uptop
Old 06-29-2009, 01:23 AM   #9
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
the evo guys like them a lot
All4bSpinnin is offline   Reply With Quote
Old 06-29-2009, 08:09 AM   #10
06mattsti
Member#: 174796
2006 STI
F the EVO guys.
Old 06-29-2009, 11:01 AM   #11
ec2k1gt
Member#: 129631
06 Obp Sti
back to slow lolz
Originally Posted by 06mattsti View Post
F the EVO guys.
Your dumb as rocks, your one single post just answered the op's question
ec2k1gt is offline   Reply With Quote
Old 06-29-2009, 12:36 PM   #12
b00st3d
Member#: 9891
2015 RC-F
Ultra White
YOU'RE
b00st3d is offline   Reply With Quote
Old 06-29-2009, 12:58 PM   #13
06mattsti
Member#: 174796
2006 STI
Originally Posted by b00st3d View Post
YOU'RE
Thank you.
Old 06-29-2009, 08:48 PM   #14
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
For a stock block, i'd say if the 35r is what you want, get a the HTA3582R with a smaller housing like a .63 or .82. The HTA86 (3586) has a bigger exducer which makes it spool slower but also make significant more power, power you will never see on your stock block with the hopes of longevity. For reference, the HTA3582r is supposed to make 50+whp over a standard garrett housing and spool somewhere in the range of 400rpms sooner due to the cartrige design and 7-blade billet compressor wheel. The HTA86, spools like a standard garrett 35r however the power increases dramatically.
<----HTA owner.
D Money is offline   Reply With Quote
Old 06-29-2009, 11:58 PM   #15
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
Doesn't the hta the same as Borg Warner's extended tip technology. Geoff of Full-race says it is the extended tip tech. The blades extend wider into the inlet of the the compressor housing. I'm thinking of getting the hta upgrade on my twin entry 1.06 a/r gt35r with full twinscroll header, uppipe, dual mv-s Tial wastegates.
methaddict is offline   Reply With Quote
Old 06-30-2009, 12:13 AM   #16
kato4276
Member#: 162641
2004 PSM WRX
<----HTA owner.
my block is not the stock 2.0L ... I actually have the current setup
Engine:
- RAW Performance Street Series Stage 2 EJ257 Short Block
- Forged CP Pistons
- STi Forged Rods
- Forged EJ257 Crank
- RAW Performance 2.0L Cylinder Head R&R with Shim-less Buckets and 3-Angle Valve Job
- New Subaru 10mm STi Oil Pump
- New Subaru STi Water Pump
- New Subaru STi Timing Belt
- ARP Head Studs
- Cometic Head Gaskets
- FP TD06SL2-18G Turbo
- STi TMIC
- Turbo XS Blow Off Valve Type H-RFL
- Turbo XS MBC
- STi 1.3 Bar Radiator Cap
- 4" Top Speed Extreme Down pipe
- 3" Top Speed Pro 1 Exhaust (All Cats Removed)
- HKS Up Pipe
- Perrin Turbo Inlet
- P&L Motorsports Signature HighFlo 3" Intake
- EcuTek ECU Reflash
Fuel System
- Stock Fuel Rails
- Walbro 255LPH Fuel Pump
- WitchHunter Modded 828cc Blue WRX Injectors
Drivetrain:
- PPG Straight Cut 1-4
- ACT Street Series Clutch
I also have an AEM 3.5 bar MaP sensor i neet to install and have my car retuned. Current setup made 308 awhp and 342 lbs tq @ 22 psi. I want to eventually get rid of the STi TMIC, 18G and Up pipe and downpipe. I want to go rotated with a FMIC, head porting and a set of BC cams. I had saw the HTA's on their site but not to much info other then what their site has. I would like to stay around the 500 =/- awhp area.
Old 06-30-2009, 12:49 AM   #17
kato4276
Member#: 162641
2004 PSM WRX
to the top bump!!!
Old 06-30-2009, 01:40 AM   #18
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
Engine:
- Forged CP Pistons
- STi Forged Rods
- ARP Head Studs
I'd check with Ron on the turbo you plan on running. You only have his base line motor with drop in pistons and a head cleaning service. Essentially, you're running the same size turbo as I am, however I also have Ron's signature series block + signature series heads. Big difference with a fully built block + sleeves.
Also, you'll need alot of upgrading.
Old 06-30-2009, 01:41 PM   #19
ScorpionT
Member#: 195677
The design is similar, yes. The extended tip helps, but its also the aerodynamics of the compressor. The smaller hub and longer blades at the inducer are another factor.
FP HTA GT30R Turbo Kit Perrin Crawford AOS Rotora BBK FIC925cc Exedy Twin Disc cynet2k Engine/Power/Exhaust 13 09-17-2009 08:14 PM
FS: Feeler: PA , FP HTA Green 3" Anti-Surge 8cm^2 EWG Turbo < 500 miles Merp Engine/Power/Exhaust 26 05-13-2009 08:51 PM
