Old 07-02-2009, 10:57 AM   #26
FromageTheDog
Member#: 81095
2005 WRX sedan kid-
bus. OS self-tuned!
Originally Posted by Dutch Scooby lover View Post
Check the rear caliper, and see if is actually still in working order.
My guess is the overheating melted something, so dirt could get in seizing the caliper.
I commute 120 miles 3 times a week, so I'm going to guess that if the caliper was dragging I'd be killing pads even sooner. That said -- you are correct; I did damage at least the piston boot with my abysmal pad choice during this last event! I've got a caliper rebuild kit on order and plan to rebuild them this weekend.
FromageTheDog is offline   Reply With Quote
Old 07-02-2009, 10:58 AM   #27
FromageTheDog
Member#: 81095
2005 WRX sedan kid-
bus. OS self-tuned!
Originally Posted by REX8 View Post
Not to mention 05 WRX's are much harder on rear brakes with their auto-bias feature.
Wait, what?
I've got a bit of research to do!
Old 07-02-2009, 03:14 PM   #28
ESmooth
Member#: 118082
Its EBD or electronic brake force distribution, a lot cars with ABS from the early 2000s and up have it.
ESmooth is offline   Reply With Quote
Old 07-02-2009, 04:09 PM   #29
MasterKwan
Member#: 98961
2003 WRX
Yeah, 05's have BFD. According to the manual, the rears are set to get more pressure than they did in the days of the prop-valve and the ABS pump pulls pressure off the rear wheels to control lockup. It suggests that an 05 with the ABS disabled would tend to lock the rears before the fronts.
I feel confident I could install HPS pads in the rear and they're last a summer of track days. It's hard to compare because I've switched brakes around but, I ran HPS's in the back and XP10's in the front when I had LGT brakes all the way around. For awhile there, I was tracking without ABS and I wanted to ensure that the rears wouldn't lock before the fronts. Now, if the front pads aren't aggressive enough, that by itself might make the rears work too hard.
Old 07-02-2009, 04:48 PM   #30
REX8
Member#: 24038
Well, on 255 street tires, I sure as hell couldn't on a full weight 200 whp WRX. Didn't last a day running briskly (high 1:20's on Summit Main, pre-paving)
Old 07-02-2009, 05:19 PM   #31
grippgoat
Member#: 62182
2005 STI
In general, I'm not sure what point you are trying to make, we all agree why his rear pads went so quickly. But your assumption that you can't heat a pad past ideal and not melt it off is flat out wrong.
My point is stop messing around and get some REAL race pads. I've never heard anyone refer to EBC Yellows as real race pads.
It's also not really useful to talk about how it's possible to operate a pad beyond its heat range without melting it off. You're not going to save money or have more fun by continuing to run your car that way. Either press the pedal harder and burn 'em off, or just throw 'em away and get pads that work the way you need 'em to.
With the OP's problem confined to the rear, it'll be very hard for him to know whether he's running the pads too hot through brake feedback, making the suggestion that he do so even less useful.
-Mike
grippgoat is offline   Reply With Quote
Old 10-10-2009, 05:38 PM   #32
FromageTheDog
Member#: 81095
2005 WRX sedan kid-
bus. OS self-tuned!
So finally got back to the track Friday. This time, I was running EBC Yellows in the rear, with the stock sized rear rotor. Still DS2500 pads in front (StopTech BBK). It seems to me the pads still wear faster than I expect (or wish?), but not nearly at the crazy rate they were before. At this rate, I expect to replace them maybe 3 times for every 2 sets of 2500s I go through, which I think I can live with. It definitely seems to me that the H6 rotors coupled with the StopTech BBK were at least partly to blame, but since I changed both the rear rotors and pads at once, I'll never know. At least stock-sized rotors are cheaper to replace...
Really appreciate all the feedback and pointers here, folks.
Old 10-10-2009, 07:02 PM   #33
SoapBox
Member#: 204578
S54 E46, N54 E82,
N55 E84, AKA REX8
Yeah, not sure why we really didn't get into that right away. You have a BBK up front. That's huge heat capacity that will prolong pad wear by a very very very large amount. You could easily double or triple your front pad life with a BBK. It's also the reason you can get away with running DS2500's up front. They're staying nice and cool.
SoapBox is offline   Reply With Quote
Question about brake pads? signshopII Tri-State Area Forum 12 07-08-2006 02:29 AM
Question about brake pads on 03 WRX swalker Brakes, Steering & Suspension 7 08-18-2004 06:41 PM
General question about brake pad wear K Rock Impreza Brakes, Steering & Suspension 4 01-06-2004 10:40 AM
Question about brake pads for big brakes urapnis Brakes, Steering & Suspension 1 12-31-2002 08:55 AM
question about brake pad/rotor install mkotecha Service & Maintenance 2 08-15-2002 04:46 PM
