#1 |
Member#: 82989
NESIC
Vehicle:2002 WRX Hybrid VF22 |
02 WRX. 113k miles.
I'm getting a very noticable hollow wobbling sound when I make turns either left or right. I can still hear the noise a little bit when driving straight, but as soon as I start turning the wheel, it becomes more audible. I first thought it was my tires, but wouldn't it make a consistent sound all the time if it was? It's also not a grinding sound, or metal to metal contact sound... it really sounds like something is loose and is wobbling around creating an echo-ey sound. Wheel bearings maybe? It's driving me nuts... ![]() Edit: Also, I'm also getting a bit of steering wheel vibration. I haven't got an alignment in awhile either. When I'm turning, I can almost feel whatever is wobbling right through my steering wheel...
#2 |
Member#: 82989
NESIC
Anyone
#3 |
Member#: 183534
TXIC
Vehicle:06 wrx wrb |
search wheel bearings. Thats what it sounds like...
#4 |
Member#: 158586
Vehicle:2009 WRX Pearl White |
Jack your front end up and give your wheels a couple tugs up/down left/right. If there is excessive play its wheel bearings. I'd give the rear a check as well.
#5 |
Member#: 203723
Vehicle:2005 Impreza STi OBP |
might be a torn cv boot, no more lubrication in there. Or wheel bearing.
#6 |
Member#: 215225
South East
Vehicle:1995 Impreza 1.8L L Blue |
Does it make that noise while you are stationary? If so it could be power stearing issue.
#7 |
Member#: 76817
NESIC
Vehicle:2005 WRX Black |
I am having the exact same problem. I just jacked up my car and the is no free play in the wheels. Other ideas?
#8 |
Member#: 82989
NESIC
Woah dead thread!
It was a wheeling bearing. Got it fixed a few months ago. |
#9 | |
Member#: 76817
NESIC
Just wondering because I would rather replace mine myself, but no idea which side is bad, lol. EDIT: My steering wheel wobbles too, but I got an alignment and tires balanced 3 times! Wobble is still there. |
#10 |
Member#: 82989
NESIC
Fixed/replaced at a dealership.
#11 |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper Wagon |
Does it wobble at all speeds or just some? If just some speeds, I will guess it's ~65MPH. Since everything else seems OK, check for a dragging front brake caliper.
#12 |
Member#: 76817
NESIC
[quote=Charlie-III;28605385]Does it wobble at all speeds or just some? If just some speeds, I will guess it's ~65MPH. Since everything else seems OK, check for a dragging front brake caliper.[/QUOTE
The noise/wobble gets louder/worse as speed increases. I have posted a thread on my issue. http://forums.nasioc.com/forums/show....php?t=1871172 I will check for a dragging caliper, thank you. |
| Thread Tools | |
| Display Modes | |
| Weird noises when turning, popping noise HELP! | idrum2loud | Brakes, Steering & Suspension | 13 | 07-07-2008 12:42 AM |
| Car Making Lound Noises when turning | Scooby_Treat | Transmission (AT/MT) & Driveline | 2 | 10-30-2002 11:46 PM |
| Loud click noise when turning on/off headlights | MooBob42 | Warranty Issues & SOA Problems | 3 | 02-26-2002 07:31 PM |
| flexing/popping noise when turning | Moshpit552 | Newbies & FAQs | 1 | 11-06-2001 09:12 PM |
