#1 |
Member#: 211609
TXIC
Vehicle:04 GT30R w/ Meth.. Aspen White |
Ok I have a half tank of gas. The motor is idling fine but when I go to step on the gas pedal nothing happens? What gives?
#2 |
Member#: 80465
RMIC
Vehicle:2001 2.5RS Black Diamond Pearl |
connect your gas pedal to the throttle. If we knew what kind of car you have, the diagnosis can be better. we can't read your mind, you have to inform us.
#3 |
Member#: 88589
Vehicle:2012 STI the best one |
^^ Exactly. Throttle cable sounds like it's not connected
#4 |
Member#: 211609
TXIC
#5 |
Member#: 88589
2004 is still cable throttle, right? I thought the Drive by Wire wasn't until 2005.
#6 |
Member#: 16200
Vehicle:OK Houston we have an Uncle |
you need a mechanic
#7 |
Member#: 85900
NESIC
Vehicle:2001 Forester S White |
#8 |
Member#: 80465
RMIC
if it's cable driven, check by the pedals and in the engine bay to see that the cable is intact.
If drive-by-wire and this happened overnight, there's a wire loose/missing somewhere. |
#9 |
Member#: 180710
South East
Vehicle:2002 PSM WRX WFC# 229 |
Jeez, can i have your car?
#10 |
Member#: 206828
Pop the hood and manually rev the car at the throttle body! This will tell u if its the throttle pedal etc
#11 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
All USDM STi's, '04-up, are drive-by-wire/electronic throttle.
#12 |
Member#: 143802
Vehicle:2007 Imp 2.5i 5M Wgn Crystal Gray |
look to see if something is cloging the intake. Putting the stock intake back to go in for some warranty work, a small plastic bag got sucked in and Luckily hung up on the throttle plate in the TB. I had driven 3 blocks and all of a sudden it wouldn't rev. They Every light on the dash flashed like a pinball machine. I was going to put back the CAI, and unplug the ABS again, and reached inside the TB, and found the bag.)) I wondered what could have happened if it had gotten sucked into the motor.(((
| Thread Tools | |
| Display Modes | |
| help!!! flashing cel and no one can help | tommy 02wrx | Factory 2.0L Turbo Powertrain | 21 | 06-05-2010 07:26 PM |
| Anyone getting check engine LIGHT but no actual code? | byroll01 | Factory 2.5L Turbo Powertrain | 45 | 08-03-2006 10:50 AM |
| Wouldn't start, now runs but has gas smell from exhaust | paradawks | Normally Aspirated Powertrain | 3 | 09-02-2003 06:48 PM |
| !! Car clicks, but no gas!!! HELP!! | Bahumut | Normally Aspirated Powertrain | 9 | 06-05-2001 02:26 PM |
| HeLp, Fog Lights but no HeadLights??!!?? everyone must read | emprezadent | Interior & Exterior Modification | 1 | 01-28-2001 12:32 AM |
