Old 04-27-2002, 10:09 PM   #1
Ru fan
Member#: 1605
1997 1.8L Brighton
NESIC TrackH0z member#1
Talking Dyno results for a 2.2L
I have a 98 impreza wagon. The clamed hp is 137 at the crank. It is an almost stock drivetrain with the single ehaust port heads. The only mods I have are as follows.
-removed intake scilencer
-JUN FW 12lbs
-ACT clutch
-Stromung S/S axle back Dual tip
I guess the only one that really counts on the dyno is the exhaust.
*Drum roll*
Hp=93.3 @5200 (quickly drops off after 5200)
Tq=111 @3700
What can I say...she is a Dyno Queen!
How do I read the AFR charts? I have no idea what they mean. I heard that NA cars are supposed to have around 12:1 or something like that. I don't really know what that means though. How can I use this data to tune my car?
Later,
Seth E.
Ru fan is offline   Reply With Quote
Old 04-28-2002, 09:01 AM   #2
roninscar
Member#: 2306
2000 RS Sedan
Blue Ridge Pearl
Default AFR
The AFR can tell you how much power is being lost to conservative fuel mapping. The ideal stoichometric(sp?) balance would be 14.7 to 1, but this is pretty dangerous and extra fuel is added in order to keep the engine from running too lean and looking for other fuel sources to burn, stuff like pistons, valves etc. So lowering the ratio will help keep exhaust temps down and keep from burning pistons, but it will suck some performance from the beast as you are not combusting near peak efficiency.
Do a search on fuel controllers, there should be a discussion there on a method used by some RS owners to raise the ratio in the higher revs to increase power. The stock maps typically have the afr diving in the higher revs.
Regards,
scotto
roninscar is offline   Reply With Quote
Old 04-28-2002, 05:34 PM   #3
Tkacik
Member#: 847
'06 Titan Crew Cab
'08 Forester LL Bean
Wow those are pretty impressive numbers.
Tkacik is offline   Reply With Quote
Old 04-28-2002, 05:47 PM   #4
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Charts
Seth,
Will you be posting a scanned pic of the dyno chart itself? Then we can see details as to how the powerband is.
Kevin Thomas is offline   Reply With Quote
Old 04-28-2002, 09:28 PM   #5
Ru fan
Member#: 1605
1997 1.8L Brighton
Arrow
I can't post the charts because of the size. I can't compress the charts because I don't have the software. I will see what I can do though. Give me a few days, maybe I can figure something out.
<---Doesn't know shiznit about computers
Later,
Seth E.
Old 04-28-2002, 09:58 PM   #6
MGXsport
Member#: 4048
2013 Outback
I'd like to see the chart also.
You can get a good image resizer for free at downloads.com
Search for Ifran View.
Chris
MGXsport is offline   Reply With Quote
Dyno Results XPT Stage 2 16-bit? apgarabu Commercial ECU Reflashes 3 12-29-2008 01:27 PM
Dyno results - WRX stage 2 w/ 3rd cat and OEM catback Rick Schu Proven Power Bragging 2 04-09-2005 09:58 AM
My dyno results Accessport Stage 2 file_id Proven Power Bragging 48 12-30-2004 06:53 PM
any dyno result for intake rex_area Bay Area Impreza Club Forum -- BAIC 4 04-26-2002 07:14 PM
Fuel Rail dyno results for a turbo Miata shiv Normally Aspirated Powertrain 1 02-11-2001 11:45 AM
