Old 06-28-2009, 02:54 PM   #1
Member#: 24773
2005 WRX STI
Default AC not blowing cold air
I tried searching but couldn't find exact symtoms. So the other day, AC was just working fine. It's been over 100 degrees for the past 2 weeks. Yesterday, I didn't drive the car at all. Then today, the ac kicks on but no cold air. One thing I noticed is the hissing sound under the dash continues to hiss. Normally, I only hear the hissing sound in the beginning then fades away. What should I do to start troubleshooting? I just had a 60K maint. done by subaru and this happens?
b0red@werk is offline   Reply With Quote
Old 06-28-2009, 06:09 PM   #2
2.5GTLegacy
Member#: 111219
AC is a complicated system.
There isn't much you can do by yourself, without the tools and knowledge. I suggest taking back to Subaru and let them look at it. It's either low on refrigerant or you have a leak somewhere.
2.5GTLegacy is offline   Reply With Quote
Old 06-30-2009, 01:18 AM   #3
martymcfly
Member#: 152414
08 WRX-S 230 (EDM)
It sounds as if your evaporator is on the fritz....My '08 WRX is in the shop as we speak getting a new evaporator installed under warranty. I had the same issue as you...AC was working fine until one day it stopped blowing cold air and a hissing sound came out from under the dashboard on the passenger side....a quick pressure test at the dealer revealed that there is a leak in the evaporator....The whole dashboard needs to be removed in order to access this part....
Good luck
martymcfly is offline   Reply With Quote
Old 06-30-2009, 09:13 AM   #4
Member#: 24773
2005 WRX STI
how much did they say it would cost?
Old 06-30-2009, 01:55 PM   #5
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
since it was UNDER WARRANTY, I'm assuming it cost 0.
Old 07-01-2009, 11:25 AM   #6
wagonovsky
Member#: 98414
1996 OBS
Green
+1 for the evap comment.
wagonovsky is offline   Reply With Quote
Old 07-02-2009, 05:23 PM   #7
bboyjunglist
Member#: 178855
2004 WRXagon
Dat Java Black P SOn!!!
yup this happened to me yesterday. was working fine, next day turn the car on and i get a hissing noise. so evap should be 1st thing to chk? my car is out of warranty so does anyone know the price range to fix this? i live in AZ and temp is 106-110 avg right now AND thats not the highest it will get this summer!!! ****!!!!
bboyjunglist is offline   Reply With Quote
A/C not blowing cold doodie Service & Maintenance 35 06-08-2015 10:40 PM
Heater blowing cold air Tweeder Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-23-2010 08:11 AM
AC stopped blowing cold KaliKarver Warranty Issues & SOA Problems 17 07-30-2009 09:57 PM
It's 14 degrees out and my car is blowing cold air!!! jester696 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 33 01-26-2009 10:05 PM
A/C hissing not blowing cold air ryanpietro Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 08-28-2006 02:33 PM
