Old 06-28-2009, 04:56 PM   #1
JLude7
Member#: 185513
02 impreza wrx
aspen white
Default High Pitched Squeaking noise
When I first turn my car on and sit in idle, a noise starts to come from my engine and then once i throw it into a gear and start driving, it gets noticeably louder. the more i drive and warm up the car, the less it squeaks. but it will still do it every once in a while if i drop it into a lower gear and make a somewhat sharp turn. Because of that, i thought it could be my power steering belt, but i just had it changed not too long ago. maybe a couple thousand miles ago. the belt seems too narrow so the next thing i thought of was the noise was coming from the belt slipping back and forth? does anyone know what this noise is coming from?
JLude7 is offline   Reply With Quote
Old 06-28-2009, 11:36 PM   #2
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Try tightening the belt. If you had it changed a few thousand miles ago the belt probably has stretched out a little and lost some tension.
To tighten the belt- loosen the bolt on the adjustment screw, then tighten the adjustment screw until the belt has ~ 1/4" give when you press on it between the alternator and the crank pulley. Tighten the bolt on the adjustment screw and you are done.
speedyHAM is offline   Reply With Quote
High pitched squeak from aftermarket intake? BrysImpreza Normally Aspirated Powertrain 11 06-30-2004 02:58 PM
Heat "ON" = high pitched squeaks JayGold Normally Aspirated Powertrain 2 12-08-2003 02:27 PM
High-pitched squeak during upshifting everbruin Warranty Issues & SOA Problems 4 02-13-2002 09:13 PM
High-pitched squeak during upshifting everbruin Transmission (AT/MT) & Driveline 1 02-13-2002 11:55 AM
annoying, high pitch squeaking driving me nutz! olie General Forum Archive 2 01-11-2001 07:04 AM
