Bay Area Impreza Club
Go Back   NASIOC > NASIOC Chapters > Bay Area Impreza Club Forum -- BAIC
Old 05-09-2009, 10:26 PM   #1
flukewrx
Member#: 75081
2003 WRX
Default Will a Cobb Stage 2 OTS Map pass a Smog Test?
Has anyone Passed a Smog Test using a Cobb AP Stage 2 OTS Map? I'm trying to decide if I should reflash to a Base Map or if I would be okay to Pass using the OTS Map for Stage 2?
I'm not trying to determine if my setup would Pass a Visual Inspection. Only if it would Pass a Sniffer Test.
flukewrx is offline   Reply With Quote
Old 05-10-2009, 06:36 AM   #2
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
You'll get better responses by asking this in your regional forum...
Spenk is offline   Reply With Quote
Old 05-10-2009, 07:50 PM   #3
JanssenTodd
Member#: 184605
2006 wrx wagon
SGM vf39'd
I've heard of people passing with stage 2 and a catted downpipe. but it might depend on who does the inspection. If you do end up reflashing, make sure your car runs for a couple hundred miles or else you wont pass.
JanssenTodd is offline   Reply With Quote
Old 06-11-2009, 11:41 AM   #4
Genner
Member#: 18372
Don't mean to hijack this thread...but I do have a similar question...
I'm from San Francisco, CA. I plan on getting just the Cobb Stage 2 package on my 02 WRX. Will that pass smog without having to remap to the base map?
Genner is offline   Reply With Quote
Old 06-11-2009, 02:45 PM   #5
flukewrx
Member#: 75081
2003 WRX
Well, I did pass while still running the Stage 2 OTS map on mine. I wasn't actually even close to failing with it (even though I was worried I would be). I think if I had done a few more things to help clean up my system I could have got the numbers down even farther. I sat with the RPM's up around 5-6K for a few minutes of driving (still maintaining normal freeway speeds) on my way to the Smog shop. I did that to help burn off any excess build-up in the system.
I'm running:
PDE Flex Up-pipe
Helix Catted Downpipe
I have other mods as well, but the catback exhaust portion won't make a difference on the Smog portion so I was only saying the mods I have that I think would affect my SMOG results. I had also just the week prior had a new panel filter installed.
I'll try to remember to pull up the numbers to show what I passed with. I really do think that if I had my car Pro-Tuned that the numbers would drop even lower as the OTS map supposedly runs pretty rich.
Old 06-30-2009, 02:24 AM   #6
flukewrx
Member#: 75081
2003 WRX
Here's the numbers for those that are interested, remember this is using an OTS stage 2 map for 91 octane gas (I run Chevron).
Idle
RPM - 728
CO^2% - 9.6
O^2% - 6.1
HC (PPM)
Max - 100
Ave - 17
Meas - 36
CO^2%
Max - 1.00
Ave - 0.00
Meas - 0.02
2500 RPM
RPM - 2484
CO^2% - 12.2
O^2% - 2.2
HC (PPM)
Max - 130
Ave - 12
Meas - 26
CO^2%
Max - 1.00
Ave - 0.10
Meas - 0.25
As you can see I really wasn't anywhere near failing the tests even with the OTS map. Now my car had over 116K miles on it when I tested it and I have not touched anything like the IACV or any sensors so I possibly could have cleaned those up or replaced stuff before going in and I would have been in even better shape. I also believe that once I get my car properly Pro-Tuned and it is not running as rich that these numbers should decrease.
Cobb stage 2 ots map and now overboosting. scurabus Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-29-2009 01:03 PM
Cobb Stage 2 OTS map vs. Perrin Stage 2 OTS map liljon350 AccessPort 4 08-09-2009 09:01 AM
Best runs on Cobb Stage 2, OTS maps MaxSTi05 Proven Power Bragging 41 10-04-2008 07:41 PM
safe running cobb stage 2 OTS map with catless tbe + megan headers? spooln407 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-19-2006 06:41 PM
Anyone with OTS Cobb stage 2.5 map driving with VF34 and header? txl146 AccessPort 2 03-19-2006 11:34 AM
