Old 06-30-2009, 07:37 PM   #26
japslapr
Member#: 100150
02 V9 STi 6spd
HTA Green, Built EJ205
Does this say you trapped 141 on pump gas with alky....?
Originally Posted by Bilyk WRX View Post
Qualification - [email protected] - boost is 28PSI on 93+ALKY
total weight of the car with me inside is 3388 lb
too much pressure in the tires - 42psi - too much spin 60ft is 1.77
car can make it much quicker but clutch was slipping all the next runs on the 3rd gear on the peak torque
YouTube - Bilyk WRX BW374 Qualification 10.63
japslapr is offline   Reply With Quote
Old 06-30-2009, 09:51 PM   #27
crashtke
Member#: 120912
Nice, do you even need a wastegate, lol. Very nice build. The setup I am putting on the car is a S362 single scroll with a .70 AR. We are hoping for boost a bit sooner. It is the T-3 housing with 3" vband.
boost is BW S374 1.0 AR:
3832 - 0,51
4030 - 0,66
4152 - 0,73
4427 - 0,90
4581 - 1,03
4738 - 1,16
4891 - 1,29
5098 - 1,43
5269 - 1,54
5468 - 1,67
5670 - 1,79
5898 - 1,88
6058 - 1.98
6221 - 2.05
6409 - 2.09
6590 - 2.15
6912 - 2.21
8500 - 2.40
crashtke is offline   Reply With Quote
Old 07-01-2009, 01:42 AM   #28
Bilyk WRX
Member#: 89058
2003 WRX 9.63/150mph
EJ257+BW S374 735whp
yes pump+alky
Bilyk WRX is offline   Reply With Quote
Old 07-01-2009, 11:54 AM   #29
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
13.4 @ 103, '09 spec.B
Very nice...
def
dug-e-fresh is offline   Reply With Quote
Old 07-01-2009, 12:58 PM   #30
RJSP
Member#: 170905
1998 WRX STi Type RA
Feather white
Very nice build! What oil pan and oil pump are you using? oil pressure at 8600 rpm?
Thanks
RJSP is offline   Reply With Quote
Old 07-01-2009, 01:25 PM   #31
Bilyk WRX
Member#: 89058
Thanks
oil pan EJ257, oil pump - modified stock.
oil pressure at 8600 - should see - never did before
Old 07-01-2009, 03:47 PM   #32
GeneralTJI
Member#: 152680
Wow... great build. 141mph is blistering fast! That BW is massive ... get some traction, I'm excited to see what you can run
-Todd
GeneralTJI is offline   Reply With Quote
Old 07-02-2009, 09:11 AM   #33
rxw
Member#: 43669
2006 STi
Impressive! Would love to see a dyno sheet!
rxw is offline   Reply With Quote
Old 07-02-2009, 10:59 AM   #34
modaddict
Member#: 95840
sold to a good bud
awaiting next car
what crankshaft?
modaddict is offline   Reply With Quote
Old 07-02-2009, 11:06 AM   #35
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Self tuned ftw. Very nice, must be a wild ride.
stretchedk7 is offline   Reply With Quote
Old 07-02-2009, 12:48 PM   #36
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Very impressive - good looking !
alfriedesq is offline   Reply With Quote
Old 07-02-2009, 01:47 PM   #37
Bilyk WRX
Member#: 89058
Originally Posted by modaddict View Post
what crankshaft?
stock EJ257
Old 07-02-2009, 01:48 PM   #38
Bilyk WRX
Member#: 89058
Thanks Al !
Next round will try low-low 10.xx. Have to work on traction
Old 07-02-2009, 02:09 PM   #39
Bilyk WRX
Member#: 89058
Old 07-02-2009, 02:13 PM   #40
Bilyk WRX
Member#: 89058
Old 07-02-2009, 05:57 PM   #41
SQC120
Member#: 39677
2008 Land Rover
02 WRX
wow man.. great job! the thing is a beast
SQC120 is offline   Reply With Quote
Old 07-02-2009, 06:04 PM   #42
HyperSl4ck3r
Member#: 179982
2008 Impreza WRX STI
Obsidian Black Pearl
So did you win against that Evo? Evo hunting STI?
HyperSl4ck3r is offline   Reply With Quote
Old 07-02-2009, 08:17 PM   #43
Speed
Member#: 67371
05 BUILT 2.4L STI
Thumbs up
thanks
BTW on the 245/45/17 and 8600 redline I have 4th gear till 145mph on the 2007 6mt
Man that's a huge turbo. If you want traction and you want to keep the Brembos... the only thing that would do is using the M/T Motorcycle slicks. 26-7-17 (they fit great on 17X7.5 04 STi BBS... otherwise you will need 17 X 7 wheels and a small spacer)
Since they're a little taller (1/4 inch or so) you can go 151 mph in 4th @ 8,600 rpm. We get 1.3-1.4 60ft with those... but be careful... don't run them with very low air pressures.
If you don't want to keep the brembos then run 15" slicks.
With those you either hook, make the clutch slip or break an axle.
Speed is offline   Reply With Quote
Old 07-03-2009, 02:25 AM   #44
Bilyk WRX
Member#: 89058
I have no Brembos - I have WRX - 15' - no problem.
BUT! We have regulations and I'm running in STREET AWD class. Car has to have full interior and DOT street use tires - thats the rule - no slicks.
I think next time I will have to lower launch to 6500 rpm and make 26PSI in the wheels.
Old 07-04-2009, 10:00 AM   #45
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
Do you have a cage? In the pics you just through up it doesn't appear you do.
def
Old 07-04-2009, 10:31 AM   #46
MattPersman
Member#: 139385
cage? lol, in the one picture he has the window part way down with no helmet on making a pass. pretty lax rules there
141 is WOW, congrats
MattPersman is offline   Reply With Quote
Old 07-04-2009, 10:43 AM   #47
Boxer4u
Member#: 115149
07 STI
Murdered & Loud
congrats man! that is a gi-normous turbo! You should definetly check out the cosworth intake manifold.
Boxer4u is offline   Reply With Quote
Old 07-04-2009, 07:41 PM   #48
Bilyk WRX
Member#: 89058
def
I don't have a cage. On our regulations - if you have car body, doors untouched (STREET CLASS) - you don't have to. Why do I need cage with completely stock body? I don't want to drive my car in the city with a cage. Or I will have to always put helmet on and all my passengers.
Window is open on the way back.
Helmet is needed but marshals are out sometime.
Old 07-04-2009, 07:43 PM   #49
Bilyk WRX
Member#: 89058
I have SPEC C intake manifold - I completely happy with it. I don't believe in cosworth manifold, but if someone will present it for me - I'm ready to test it
Old 07-04-2009, 10:29 PM   #50
spiralsmurf
Member#: 16085
2005 STi
in the US, most tracks require some time of body reinforcing cage if you run lower than 12s. (to the best of my knowledge)
spiralsmurf is offline   Reply With Quote
