Old 06-29-2009, 11:21 AM   #1
a_k
Member#: 198767
2002 Outback Sport
Default Dissapearing oil
*EDIT
I just drained the coolant into the bucket and it looks black, but isn't milky and doesn't appear to have oil in it. The walls on the coolant reservoir are all nasty though. If my cars head gaskets are ok where is all this oil going? Every 700 miles the oil level goes from F on the dipstick to no oil at all. The car has never smoked or leaked a drop onto the ground. Can anyone help?
So I have an 02 Impreza 2.5 OBS with leaky head gaskets. I'm going to start the project later but had a question. I've searched and cannot find out if I need to remove the cam from each head to do the job. I have the subaru service manual which says to, but when I bought the parts from the dealer he said on SOHC engines that is not necessary.
a_k is offline   Reply With Quote
Old 06-29-2009, 04:31 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
The dealer is correct, you do not need to remove the cams to remove the heads on a sohc. Are you sure you have the correct manual?
Head building and head gasket questions hybrid gti 2 Built Motor Discussion 21 04-11-2010 11:04 AM
Head gasket questions... otisfireboy Normally Aspirated Powertrain 23 07-09-2003 10:47 AM
Yet another head gasket question... MHC Normally Aspirated with bolt-on Forced Induction Powertrain 7 06-29-2003 02:40 PM
Head Gasket Question bgd scooby Normally Aspirated with bolt-on Forced Induction Powertrain 0 02-13-2002 06:08 PM
Pat Olsen - head gasket question once again. 2.5GT Normally Aspirated Powertrain 1 11-16-2001 01:32 PM
