Old 06-29-2009, 02:43 PM   #1
1WYDSTI
Member#: 207991
2004 STi
Chargespeed Widebody
Default Aftermarket FAL Radiator Fan Question
I own a 04 STi with the Flex-a-lite aftermarket cooling fans with shroud and they recently went kaput. The person who installed these did some crazy wiring apperatus that I feel is over the top for a set of cooling fans.
Is there an "only-on-when-car-is-on" wire I can tap into that anyone knows of in order to hook up the new fans to without reusing the crazy wiring that was done prior.
I wanted to tap into a line located at the under the hood fuse box but everything is live/hot when the car is off...
Thanks for any help ahead of time...
1WYDSTI is offline   Reply With Quote
Old 06-29-2009, 02:48 PM   #2
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
You don't want your fans always running when the car is running, it wastes power and supposedly actually hurts airflow through the radiator while driving on the freeway. It will also wear your fan motors out MUCH quicker. What happened to the factory wires that run to the fans? Those are switched on/off with coolant temp.
How crazy is the wiring in there? Maybe he just added some relays...
Old 06-29-2009, 02:55 PM   #3
1WYDSTI
Member#: 207991
2004 STi
There was a wire for power tapped into the main fuse box but then an additional hot wire that only came on when the car was on to use I guess to act as a switch for on and off..
I cannot locate the factory harnesses or even the wires from the fans which is strange
Old 06-29-2009, 08:04 PM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Get stock fans NOW. Why? Well, I suggest you read the Cooling System FAQ and it will tell you why your car will run WORSE with aftermarket fans. Nice job on downgrading your car, now is the time to fix that.
Old 06-30-2009, 11:33 AM   #5
1WYDSTI
Member#: 207991
2004 STi
Haha your such a typical forum know-it-all... well thanks for the information SMARTASS...
'n FYI, I acquired the car with the fans installed
Old 06-30-2009, 02:43 PM   #6
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You might not agree with the delivery, but the answer helps...you can't have everything with the internet.
Old 06-30-2009, 04:15 PM   #7
csmithwrx'05
Member#: 171293
'05 WRX Hybrid
EJ257 w/Blouch 18G 8cm^2
Unabomber is right, you need to read the Cooling FAQ. It has been repeatedly documented that aftermarket fans actually cool less (car operates at a higher temperature) than the stock fans. Not to mention that most aftermarket fans only have one speed (on/off). While the stock fans have 2 speeds (low/high).
Don't get mad just b/c you don't like the answer. He is only trying to help. Also, Unabomber's reply was actually pretty tame as he is usually even more blunt. Regardless the man knows his ****.
csmithwrx'05 is offline   Reply With Quote
Old 06-30-2009, 06:13 PM   #8
1WYDSTI
Member#: 207991
2004 STi
I understand what your saying, but its like give me break, that **** is just uneccesary, period. But I understand and honestly dont care, theres people like him on all of the other forums I belong to and he doesnt know me or my car, bottom line.
Anyways back to the topic at hand... I did my research regarding the OEM fans vs. aftermarket and I will be picking up a pair of OEM fans from someone off the local craiglist on Thursday.
Thanks for the insight..
Old 06-30-2009, 10:02 PM   #9
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Just wait until Uncle Scotty comes rolling in
jigga is offline   Reply With Quote
Old 06-30-2009, 10:04 PM   #10
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Look at it as a form of tough love. You are not the first person to run into this issue, and you probably will not be the last that starts a thread on this very topic. Unabomber I'm sure has only the best intentions for you, and as he mentioned, if you checked out the cooling FAQ, you would have found the solution to the issue you are having. Those FAQ's really are helpful imo..
A Few Final Radiator/Fan questions Twiztidunreal Electrical & Lighting 2 02-02-2009 07:02 PM
radiator fan question!!!!!!!!!PLEASE HELP ict-wrx Electrical & Lighting 6 08-30-2008 04:32 PM
AC + radiator fan question jblaine Service & Maintenance 6 03-21-2008 02:07 PM
radiator fan question exhondaguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-20-2004 10:01 AM
quick radiator fan question chahny Legacy Forum 10 06-16-2004 10:27 PM
