Old 06-29-2009, 06:11 PM   #1
Wagon Jon
Member#: 97630
2004 WRX Wagon
Red
Default Transmission Oil Change Question
I recently hit 60,000 miles on my 2004 WRX 5mt and decided it was a good time to change my transmission/diff oils. I ordered the Transmission Fluid Change Kit for my from fastwrx.com (http://fastwrx.com/trsekit.html). On the website it states
"You get enough Motul transmission fluid for your gearbox, and your choice of either Motul or Subaru's own LSD fluid for the rear differential."
The kit comes with 3 quarts of Motul 300. I did not look closely into volumes until the package arrived but then realized the 5mt takes 3.7 liters of oil. After a little searching I have seen a few people have not used the entire 3.7 liters, but only having 3 liters available to me doesnt sound like enough.
Anyone have any experience changing transmission fluid and using 3 liters or less?
Thanks for any input
Jon
Wagon Jon is offline   Reply With Quote
Old 06-29-2009, 07:33 PM   #2
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
You're not going to use the 3.7 qts for the transmission. Expect to use around 3.2-3.4 qts, depending on how much old oil you drain. I say 3 qts is not going to be enough. For the 5 speed you want to fill to the F line (full), you don't want to be on the low side. I'd get another quart to be safe.
rexman2002 is offline   Reply With Quote
Old 06-29-2009, 07:36 PM   #3
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
Old 06-29-2009, 08:51 PM   #4
Wagon Jon
Member#: 97630
2004 WRX Wagon
Red
That was pretty much my thoughts. Thanks
I wonder why they would sell the kit with 3 quarts and say that it is enough.
Old 06-29-2009, 09:10 PM   #5
AndyH
Member#: 2133
2005 STi WRB/Gold
2005 S4 Avant
The kit is for 3 liter's of the fluid, which equals 3.17 quarts...so it might just be enough.
AndyH is offline   Reply With Quote
Old 06-29-2009, 09:25 PM   #6
Wagon Jon
Member#: 97630
2004 WRX Wagon
Red
Correct my first post should 3.5 liters or 3.7 quarts
still a close call though.
Old 07-03-2009, 01:15 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
add a bit of Penzoil synchromesh fluid to make up the difference...it will be great
transmission oil change question jasman17 Service & Maintenance 6 03-15-2007 08:51 PM
Oil change and Transmission oil change help in Ann Arbor Scuter83 Mid West Subaru Owners Club Forum -- MWSOC 12 09-11-2006 10:53 PM
I need a good place to get an alignment and transmission oil change w.r.x Southern California Impreza Club Forum -- SCIC 17 06-23-2006 08:33 PM
Transmission Oil change intervals J3]2 Service & Maintenance 7 07-14-2005 10:06 AM
transmission oil change? ngates0516 Transmission (AT/MT) & Driveline 2 02-07-2005 11:35 PM
