Welcome to the North American Subaru Impreza Owners Club Tuesday March 31, 2015
Old 06-29-2009, 09:20 PM   #1
ore0690
Member#: 153954
2007 Impreza 2.5i SE
Default Spark Plugs: Quenching is an issue to consider?
Hey guys,
I've researched these forums and the internet A LOT regarding spark plugs and finally decided to buy NGK V-Power copper plugs for my '07 2.5i. Yes, it is true that "Conventional wisdom says that copper spark plugs produce more power than the longer life platinum or the newer iridium" (from the spark plug FAQ). But it is also stated that, regarding platinum or iridium plugs, "These finer electrodes do not quench the flame core as much as a conventional style plug. This increases ignitability, therefore increasing HP. It's not a huge gain, but cylinder pressures are measurably higher."
So the comparison issue here is:
-Copper is a better conductor but must be built as a large electrode tip to be strong enough, thereby having a large quenching effect.
-Platinum is a worse conductor than copper but is stronger and thus can be built as a small electrode tip, thereby having a small quenching effect.
How important is it to avoid the quenching effect of copper electrodes when changing plugs in newer engines that were originally designed with a finer platinum electrode in mind?
Thank you,
Oren
ore0690 is offline   Reply With Quote
Old 07-01-2009, 10:50 AM   #2
rick-l
Member#: 33868
2003 wrx
srp
Platinum is a much better conductor than copper but very expensive.
rick-l is offline   Reply With Quote
Old 07-01-2009, 02:41 PM   #3
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
No, copper is a distinctly better conductor than platinum. Platinum's advantage is longer life, and simultaneously less flame quenching and higher spark energy. Both of those last two come by virtue of the much, much smaller electrode surface area.
bulwnkl is offline   Reply With Quote
Old 07-01-2009, 02:57 PM   #4
Lethal_Chemist
Member#: 203723
2005 Impreza STi
+1
Relatively speaking on a scale of 1-100, 100 being the most conductive. Copper is rated at about 89.3 whereas platinum is ~15. These are unitless values just a comparison to distinguish the conductivity. Silver however is the best conductor, both thermal and electrical known to man.
Lethal_Chemist is offline   Reply With Quote
Old 07-01-2009, 05:59 PM   #5
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
'copper' plugs are NOT copper
they ARE nickle
Old 07-01-2009, 08:40 PM   #6
ore0690
Member#: 153954
they ARE nickle
Yes this is true, though just the electrode tip. The nickel alloy is there to protect the copper core from corrosion and such. I've looked up material properties for Nickel and Platinum, and Nickel has an order of magnitude less electrical resistivity in comparison.
For anyone so interested, you can see the material differences at: www.matweb.com
Also, I've found a neat little technical paper on Iridium tip development, apparently by Denso Corporation, here:
http://www.sparkplugs.com/pdfs/iri.pdf
And, I don't think I like the NGK 'coppers' that I installed in my '07 2.5i. Sometimes, the car seems a little more sluggish than what I remember. Is it all in my head? Since I do like to push my car hard, I think I will just go with OE plugs and call it a day. No worries, just drive. Then I will get my STI sometime in the future.
Oren
Old 07-01-2009, 09:11 PM   #7
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
I put the new Denso double platnium TT plugs in my 06 wrx recently and they seem to be doing just fine
$2.99/ea(now off sale) at Advance...
I think too many people put too much thought into sparkplugs....other than using the proper plug----MOST do NOT need ANY 'colder' plug, but think they do
and proper gap and PROPER GAP PROCEDURE!!!!!!!!!!!!!!!
1!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
IS FAR MORE IMPORTANT THAN WHAT PLUG
Old 07-01-2009, 10:12 PM   #8
ore0690
Member#: 153954
Yeah, too much thought, definitely. haha. That's why I'm probably just going to go with OE plugs and forget about it, (which happen to be the NGK double platinums). I am fully confident in my gapping procedure; gapped to .043" which is within the range stated in the service manual.
Hey, also, I looked at the OE plugs that I pulled out of my engine after the first 30k miles, and all the ground electrodes appear to be missing the welded platinum disc that's supposed to be there. All that's left is a circular indentation in the nickel where the disc used to be.
Oren
Old 07-01-2009, 11:09 PM   #9
z&cobb
Member#: 12344
2002 2JC
blue
"Hey, also, I looked at the OE plugs that I pulled out of my engine after the first 30k miles, and all the ground electrodes appear to be missing the welded platinum disc that's supposed to be there. All that's left is a circular indentation in the nickel where the disc used to be."
Where did they go?
z&cobb is offline   Reply With Quote
Old 07-01-2009, 11:15 PM   #10
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Where did they go?
they were consumed or knocked off the plugs by detonation
Old 07-01-2009, 11:16 PM   #11
ore0690
Member#: 153954
Where did they go?
Dang. I don't know. That's a good question. Hopefully not lodged between piston and cylinder wall or something of that sort.
Oren
Old 07-02-2009, 12:39 AM   #12
ore0690
Member#: 153954
I see. You mean the knocking that happens when I would engage the clutch too much without enough gas (so that the RPMs go a little below idle)? Or the knocking that happens sometimes when I blip the throttle?
This reminds me that, also, one of the plugs' center electrodes looks a little..... disturbed. Like, slightly skewed, and without a level tip surface.
Could anyone say if the knocked-off discs are a danger to the engine? Or do they exit with exhaust gases easily? I guess that they might get stuck at one of the cats.
Oren
Old 07-03-2009, 05:19 PM   #13
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Oren
if you are not using 91 octane fuel....try it for a month and see if the car runs better
if so...keep using it
Old 07-03-2009, 08:02 PM   #14
ore0690
Member#: 153954
Thanks Scotty. Yeah, that's another question I had.... will the ECU automatically optimize ignition timing to take advantage of 91 octane fuel? My thought is that with the 10:1 compression ratio, if timing is optimized, there would be a sure performance advantage to using 91. I would reset the ECU after the first full 91 fill up. I have my first tank of what I believe to be 89 in there now (which I obtained by filling up with 91 when I had a little less than a half-tank of 87).
Oren
Old 07-03-2009, 08:23 PM   #15
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
the ecu will correct for less detonation
there are too many idiots around here that know nothing about fuel or how and why the ecu does what it does....and use the wrong fuel just because they are dumb enough to think that their engines/ecu's are obdII and the ecu will 'compensate' for low quality fuel and not have engine damage as a result of using whatever piss they can pour into it
I think your sparkplugs tell the story of why this train of thought is wrong and getting detonation, even with an na engine is a bad thing
Old 07-24-2009, 03:59 PM   #16
ore0690
Member#: 153954
Thank you for the info. I was away for a while.
So, being that my car is stock, I would naturally go for OEM plugs. They are for what the car was designed, and I suppose the engineers at Subaru already did all the hard work to determine how it will run with OEM plugs (NGK double platinums).
However, there seems to be a fault in the OEM plugs by which the platinum pads on the ground electrodes eventually fall off, as mentioned earlier in this thread. This appears to cause a sudden increase in spark plug gap, and possibly results in loose platinum pads in the system.
Thus I have decided to go with the NGK Iridium IX for the following reasons:
1) It is the closest to stock (same manufacturer and same smaller-than-nickel center electrode).
2) There is no welded pad on the ground electrode that is prone to falling off.
3) And, I assume that the center electrode is not as prone to falling off.
Would anyone like to share their opinion regarding my reasoning?
Thanks,
Oren
Did Cheney make who is going to be the VP candidates more important of an issue ? ZMANNH25rs Political Playground 4 08-21-2008 04:16 PM
Intresting: What is an otter to do ? racer98 Off-Topic 28 02-12-2007 07:57 PM
Is it time to consider Liberty over Democracy? PA-Brat Political Playground 19 11-08-2004 01:49 PM
Best choice of spark plugs: NGK copper? edkwon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-25-2004 09:29 PM
Splitfire spark plugs: yes? no? if no why? BryonMorton Service & Maintenance 7 06-18-2002 10:42 AM
