Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 06-30-2009, 05:25 AM   #1
yeahbuddy661
Member#: 179192
2008 WRX
Spark silver
Question Help priming turbo
Hi, I have been searching the forums for a day and still a little confused on the proper way to do this. I will be injecting oil into the oil inlet before the turbo goes in but I would also like to take the precautionary steps as well.
What I dont understand is when you turn the ignition over a few times unless you step on the clutch the car wont fire anyway right? If thats wrong and you have to pull the fuel pump fuse, do you pull it then turn the key as far as it will go and hold it there for a few seconds or just turn the key over and take your hand off of it letting it sit for a few seconds.
Sorry but I have never done this before and just wanted to hear the correct way from those of you who have done this properly.
btw my cars an 08 wrx.
yeahbuddy661 is offline   Reply With Quote
Old 06-30-2009, 08:55 AM   #2
b00st3d
Member#: 9891
2005 AW STi
Dom3 MZM Tuned
it doesnt build oil pressure unless you turn the key all the way.
b00st3d is offline   Reply With Quote
Old 06-30-2009, 09:21 AM   #3
06mattsti
Member#: 174796
2006 STI
I just fired the car up, immediately shut it off. Did this a few times, increasing the time its on by a couple more seconds each time.
06mattsti is offline   Reply With Quote
Old 06-30-2009, 09:35 AM   #4
HOLLYW00D
Member#: 44954
pull the ignition fuse. crank it st least FIVE times for 5 seconds. don't worry, you won't break anything. finally, put the ignition fuse back in and start the car. let idle for at least 5 minutes WITHOUT touching the gas pedal.
DO NOT start the car without priming the turbo. even for a split second, the exhaust gases can spin the turbo up fast enough to be harmful without proper lubrication.
HOLLYW00D is offline   Reply With Quote
Old 06-30-2009, 09:44 AM   #5
06mattsti
Member#: 174796
2006 STI
^ Definitely the best idea, but my turbo is in perfect condition doing it the way I did. If you damage your turbo doing it my way, then you picked a ****ty turbo anyway.
Old 06-30-2009, 09:47 AM   #6
STIBungy
Member#: 51684
2004 Impreza WRX STI
There's a fuse you can pull out that takes power away from the ecu and fuel pump. I usually pull that as my starter kill and to prime both the motor and turbo.
STIBungy is offline   Reply With Quote
Old 06-30-2009, 10:37 AM   #7
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
The oil pump is driven by the engine, which means it's not pumping oil unless the engine is turning. Just turning the key to "on" and leaving it will do nothing, the engine isn't spinning so the oil pump isn't pumping. You need to crank the car, but you need to pull some kind of fuse (be it ignition, fuel, doesn't really matter) to keep it from actually starting. Do NOT start the car before the turbo has been primed, that's probably the worst thing you can possibly do to a turbo.
I don't know what you mean about the car not starting if the clutch isn't in...sure the car won't start if you're not stepping on the clutch, but that's because the starter doesn't engage and the engine doesn't even turn. Engine not turning = oil pump not doing anything. The clutch must be in as if you're trying to start the car, but you need to keep the engine from actually starting.
the suicidal eggroll is online now   Reply With Quote
Old 06-30-2009, 01:33 PM   #8
GreenLantern
Member#: 159372
2007 WRX (stage ++)
UGM
even better dude, if all you did was a straight turbo swap, (not a new motor or anything just swapped the turbo) you could just enter clear flood mode (by pressing gas peddle to the floor and cranking your motor over) to prime your turbo.
this way you get no combustion and you'll get oil in your turbo.
do this a few times for a handful of good cranks and you should be good to go
-GL
GreenLantern is offline   Reply With Quote
Old 06-30-2009, 04:22 PM   #9
jays05
Member#: 78165
05 STI 35r + e85
Fail. The turbo spins at like 50k rpms when you start the engine.
jays05 is offline   Reply With Quote
Old 06-30-2009, 04:24 PM   #10
All4bSpinnin
Member#: 99102
08 Corvette Z06
problem Traction?
good catch jays... i was going to mention that as well...
*warranty denied*
All4bSpinnin is offline   Reply With Quote
Old 06-30-2009, 07:33 PM   #11
rubinm
Member#: 63483
2005 STi HTA68'd+e85
I always use my Accessport's Anti theft map..
it allows the car to crank and crank without firing over.
great way to prime turbos.. just like pulling a fuse for the fuel or spark..
rubinm is offline   Reply With Quote
Old 06-30-2009, 08:15 PM   #12
yeahbuddy661
Member#: 179192
2008 WRX
Spark silver
Thanks a lot all you guys had some good input I think I wll try Hollywoods method. Is it still a good idea to prime it by hand/oil inlet?
Old 06-30-2009, 08:17 PM   #13
yeahbuddy661
Member#: 179192
2008 WRX
Spark silver
Also if the ignition fuse is pulled doesnt that mean it would not fully prime when you press the clutch and turn over would it be better to pull the fuel pump fuse?
Old 06-30-2009, 09:13 PM   #14
wheatpaste
Member#: 170747
2004 WRX Wagon
The ignition fuse is the widely accepted method that a lot of people use.
Trust us, it works and it's easy.
Other people pull the coil packs, disconnect the fuel pump, hold down the gas pedal, etc...
As others said, as long as you've got a method where you can crank the engine without it starting, you'll be fine.
wheatpaste is offline   Reply With Quote
Old 06-30-2009, 10:02 PM   #15
yeahbuddy661
Member#: 179192
2008 WRX
Spark silver
Thanks, now to find the ign fuse.
Old 07-01-2009, 12:33 AM   #16
wheatpaste
Member#: 170747
2004 WRX Wagon
It's behind the coin tray, fuse #11. Tried to find a picture, but no luck.
Old 07-01-2009, 01:19 AM   #17
sch3838
Member#: 154636
just pull the fuel control module before you install turbo and use all the pressured gas and prime the turbo
sch3838 is offline   Reply With Quote
Old 07-01-2009, 09:10 AM   #18
WolfPlayer
Member#: 65054
2005 Grannymobile
Hitch + Block Heater
Everybody is making this stupid hard when it is so amazingly easy. Simply pull the IGN fuse (#11 on my '05 STI). Crank the car as explained above. Pulling my IGN fuse not only cuts the ignition, but it also cuts the fuel (at least on my car).
No need for all of these elaborate ways to prime the turbo. Just pull the freaking fuse and be done with it.
t
WolfPlayer is offline   Reply With Quote
Old 07-01-2009, 09:16 AM   #19
GreenLantern
Member#: 159372
2007 WRX (stage ++)
UGM
even thats stupidly hard. I think putting the gas pedal to the floor and starting the car (with no effect it just cranks over) is the easiest method.....its just like starting your car except with one extra foot involved.....
-GL
Old 07-01-2009, 09:46 AM   #20
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
-GL
Agreed. On DBW cars this is the easiest method.
Tony
Old 07-01-2009, 10:27 AM   #21
Member#: 51961
2005 STi
2012 WRX
Whether it cuts fuel or ignition doesn't matter, you're just turning the engine. Turning the engine mean turning the oil pump, turning the oil pump means pumping oil through the turbo. It doesn't matter if the reason the engine isn't firing is because there's no ignition, or no fuel, or neither.
Old 07-01-2009, 12:10 PM   #22
WolfPlayer
Member#: 65054
2005 Grannymobile
-GL
I don't agree with this method. Why? Simply put, when priming a turbo you want to minimize the RPMs of the turbo. Putting your foot to the floor opens the throttle to maximum allowing a maximum amount of air through the motor, out the exhaust, and spinning the turbo. If you keep your foot off of the pedal then you get LESS air through the motor and less air spinning the turbo. IMHO, don't put your foot to the floor.
t
Old 07-01-2009, 12:11 PM   #23
WolfPlayer
Member#: 65054
2005 Grannymobile
Tony
I disagree for the reason I specified above.
t
Old 07-01-2009, 12:21 PM   #24
STIBungy
Member#: 51684
I concur. I always pull the 30amp fuse.
I tried searching for a pic of the engine bay fuse box to point out which one it is but no bueno. Its the front-most 30 amp fuse when you're looking at the fusebox from the front of the car. I use this to reset the ecu and to prime my motor and whatever turbos I've installed in the past.
t
Old 07-01-2009, 12:32 PM   #25
WRX4eva
Member#: 103343
2004 2.5 Hybrid 6spd
Rotated Manifold/35R
t
Correct. Pull the fuse and prime the turbo. Just make sure the oil has reached the turbo and lines.
WRX4eva is offline   Reply With Quote
easiest way to prime turbo 2wickedWRX Factory 2.5L Turbo Powertrain 29 04-22-2008 10:50 PM
change my oil before prime turbo? simprezl25 Factory 2.0L Turbo Powertrain 3 11-07-2007 02:32 PM
trying to prime turbo, engine not cranking JDM 3SGTE Factory 2.0L Turbo Powertrain 6 03-15-2006 10:47 AM
priming turbo bradze Service & Maintenance 7 02-28-2006 02:08 AM
in the process of priming turbo. do i need to unplug all 4 coil pack? VajraTLR Factory 2.0L Turbo Powertrain 9 12-30-2005 09:05 PM
Message Board Statistics All times are GMT -4. The time now is 12:31 PM.
