Old 06-30-2009, 09:47 AM   #1
berdugo
Member#: 163108
07 EuroDM STi 2.5L
Default how to wire Weldon/external fuel pump
I've read a few posts saying the bosch 044 (external after surge tank) needs to run 100% all the time, and not controlled like the stock or walbro fuel pump.
I'll put Weldon instead of bosch, I wanna know if I can connect it to a relay triggered by ignition on, when connected that way, the ignition on power turns off when cranking the engine, will that affect the fuel flow? Does the stock or walbro intank fuel pump starts pumping during cranking? All I know is that it pumps just before cranking, I can hear it pumping then it stops even the key is in "ignition on"
berdugo is offline   Reply With Quote
Old 06-30-2009, 10:39 AM   #2
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
There are some "on" wires that go dead when you crank the car, and some that don't. Use one that doesn't.
Old 06-30-2009, 01:22 PM   #3
engineerx
Member#: 42614
0405 WRX STi/S2000
AspenWhite/Silverstone
Check out my post about wiring the pump I used. Same principle.
*Source +12vdc main power thru a relay straight from the battery
*Source relay triggers from the OEM pump controller: 2 wires, pump is negatively triggered by controller and it will prime & turn off if engine is not cranked within a couple of seconds. Works like a charm.
http://forums.nasioc.com/forums/show....php?t=1742830
refer to first 3 pics on Post#2, disregard the other pics about the Hydra wiring. The first 3 pics apply to all external pump wiring
engineerx is offline   Reply With Quote
Old 06-30-2009, 02:25 PM   #4
berdugo
Member#: 163108
07 EuroDM STi 2.5L
thanks a lot, will try that when I get all my parts here, shipping takes so long
Old 06-30-2009, 02:30 PM   #5
engineerx
Member#: 42614
0405 WRX STi/S2000
Well , you can start running your wiring in advance and splicing into the pump controller harness.
Use a multimeter or circuit tester to confirm what each of those 2 wires source at each of the positions on the IGN switch.
It's really not that difficult getting all the connections done.
Good luck!
F/S Weldon 2025A fuel pump bertune Engine/Power/Exhaust 2 12-17-2009 10:50 AM
Wiring in external fuel pump texas05sti Built Motor Discussion 0 02-25-2008 03:33 PM
How to install injectors and fuel pump? Cusson Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 10-25-2006 12:28 PM
anyone in Marlyand area know how to wire up a fuel pump controller? simprezl25 Mid Atlantic Impreza Club -- MAIC 8 06-25-2006 05:15 PM
How to tell if my fuel pump is bad? Evegan Service & Maintenance 3 04-14-2005 06:17 PM
