06-30-2009, 11:25 AM | #1 |
Member#: 62687
South East
Vehicle:2007 Its a Suby Yeah..its stock :) |
Coolant loss
HI,
Did a search and read up on coolant replacement etc. But could nto find anything on what would be normal amount of coolant loss. I have a 07 wrx with about 26k miles on it. The coolant level is at low in the resevoir tank. Is this normal for 26k miles? Wondering if the car is eating coolant becuase there are no leaks. Thank you
06-30-2009, 01:33 PM | #2 |
Member#: 140244
Vehicle:2002 bugeye still rippin' hard |
check the coolant level in your radiator, if its not full, add some. Leave the reservoir alone.
06-30-2009, 01:51 PM | #3 |
Member#: 80465
RMIC
Vehicle:2001 2.5RS Black Diamond Pearl |
why leave the reservoir alone?
06-30-2009, 02:33 PM | #4 |
Member#: 62687
South East
checked radiator....its full
checked the other coolant tank on top of the turbo...its full. Resevoir is on LOW. |
06-30-2009, 03:04 PM | #5 |
Member#: 140244
If the reservior is low when car is cold its good. Max is for when the car is in operating temperature, it will expand.
06-30-2009, 10:41 PM | #6 |
Member#: 62687
South East
How is the coolant system suppose to act?
On a cold engine, where is the level supposed to be? After a few miles drive, what level is it supposed to be on the expansion tank? Thank you |
07-01-2009, 10:59 AM | #7 |
Member#: 33868
Vehicle:2003 wrx srp |
Between min and max
Anywhere it wants (min < level < overflowing). Not that much gets pushed out with thermal expansion and it all gets sucked back in when cool. |
07-01-2009, 12:54 PM | #8 |
Member#: 62687
South East
o
ok. I filled it up to the full line with the engine warm last night. This morning it sits between low and full marks. Went for a drive to warm up the motor and it stills sits between low and full.
Ill keep my eye on it. Thank you |
07-08-2009, 12:38 AM | #9 |
Member#: 17626
Vehicle:2005 STI |
i had this happening and apparently had a tiny leak in one of the radiator hoses
Random Smoke and slight coolant loss | R6_rider | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 10-05-2008 12:01 AM |
Is any amount of coolant loss normal? | last lemming alive | Service & Maintenance | 26 | 03-28-2008 12:18 PM |
Coolant Loss Problem | ikoinu | Built Motor Discussion | 12 | 12-18-2007 01:27 AM |
Coolant loss from overflow | Toiletbrush | Service & Maintenance | 11 | 04-23-2007 08:42 PM |
slow coolant loss | prspect06 | Service & Maintenance | 32 | 10-23-2006 07:38 PM |
